POV-Ray : Newsgroups : povray.general : Render Statistics Server Time
29 Sep 2024 02:21:52 EDT (-0400)
  Render Statistics (Message 1 to 10 of 11)
Subject: Render Statistics
Date: 22 Feb 2018 07:45:12
Message: <5a8ebb58$1@news.povray.org>
I know it is a bit late in the day to ask. But I never got round to it.
I understand Max Level: but not the relevance of Smpls/Pxl:
Ray—>Shape Intersection and Shadow Ray Tests:
What if anything, are they telling me?
I have a mesh that when rendered using Blender's Pov exporter. Renders
so much slower than when rendered using PoseRay. I cut it down a bit and
the Max Level: was 1/5. So that shot down one theory. :-(
Regards
Subject: Re: Render Statistics
Date: 22 Feb 2018 16:58:16
Message: <5a8f3cf8@news.povray.org>
Max level 1/5 mean that no ray got reflected not refracted.
Smpls/Pxl is a ratio that inform you about how much over-sampling was
done during the render.
If it's close to 1, then, most pixel needed only a single sample to get
the final result. If it's somehing like 10 or more, that mean that, on
average, at least 10 subsamples where needed to compute every pixel of
the image. This don't take into acount partial reflection or chromatic
dispersion associated with refraction.
A large value may indicate that your antialiasing is to agressive,
probably from a threshold that is to low or set to zero. If you use
focal blur, then, that value can only be somewhere between the minimum
blur samples and the maximum, and can get pushed higher if also using
antialiasing or blured reflection, that you set in the camera.
Date: 23 Feb 2018 03:04:33
Message: <5a8fcb11$1@news.povray.org>
>> and the Max Level: was 1/5. So that shot down one theory. :-(
Thanks. I have a troublesome mesh that is taking ages to render and I am
looking for reasons.
What would a Smpls/Pxl = 0.04 signify?
Regards
Date: 23 Feb 2018 08:22:20
Message: <5a90158c$1@news.povray.org>
I sometimes look at Max Level results, but little else in that section
of output...
My understanding is Smpls/Pxl is usually 0.0 if anti-aliasing is off. If
AA is on it goes up, but can still be quite small for the overall image
- if not much super-sampling was needed for the image in total.
Are you asking about those particular outputs because you see a
significant difference in those particular results between the two
methods? If so, what are the values returned?
When you say 'mesh' do you mean just a single mesh as rendered to some
plain color via both tools? Or are you talking about a complete scene
via Blender vs PoseRay with textures and 'everything'?
If the former I'd look at the mesh file size as a first clue. Perhaps
too if a really simple scene whether bounding is on in both and what
those stats are. Should somewhere see the output :
Bounding boxes.......On
Bounding Box  <tests> <succeeded> <percentage>
If working with complete scenes from both tools, the render time
difference could be a great many things. Suppose I'd start by looking at
both sets of files looking for differences. Are there ini files where
one might have some expensive option on by default and the other not for
example?
Bill P.
Date: 23 Feb 2018 10:58:52
Message: <5a903a3c@news.povray.org>
>> am looking for reasons.
> of output...
Me to. I've never really understood the significance of them.
In that case this scene is not doing much super-sampling.
Minuscule. 0.0 Vs 0.04
Almost the latter. It is one Poser hair mesh. The type that uses
transparency maps.
It renders in seconds via PoseRay but when the obj file is imported to
blender. The Pov script took 17 hours and there were still 3 blocks
unfinished.
BTW Thanks for thinking about this.
Yes Bonding boxed were on:
Ray->Shape Intersection Tests      Succeeded        Percentage
Mesh            10030736            4135877           41. 23
Bounding Box    252706844           86379467          34. 18
I've started doing that. The files are large and I've had to butcher the
Mesh in Blender to get it to a state where I can see what is inside it.
I really need to get some better tools
> example?
I can't see much here:
Version=3.7
All_File=1
Input_File_Name='F:\Graphics\Poser\Blender
tests\BugReport\Cutdown\Cutdown01a3a1.pov'
Output_File_Name='F:\Graphics\Poser\Blender
tests\BugReport\Cutdown\Cutdown01a3a1.png'
Width=960
Height=540
Bounding_Method=2
Display=1
Pause_When_Done=0
Output_File_Type=N
Output_Alpha=1
Antialias=on
Antialias_Depth=3
Antialias_Threshold=0.3
Sampling_Method=2
Antialias_Gamma=2.5
Jitter=off
There are two methods I know of to import an Obj file into Blender.
The first is to use the standard import module which is what I have been
using. I don't have 100% confidence in it since I found a couple of
small bugs in the material importing side.
The other is to convert it to a Mesh2 with PoseRay and import it using
the PovRay importer. Unfortunately that is buggy to although I have put
in a bug report for that one.
I just wanted a clue from the stats to what was happening.
Regards
Date: 23 Feb 2018 14:00:58
Message: <5a9064ea$1@news.povray.org>
> transparency maps.
> unfinished.
Do the results look more or less the same for what is done? Might be
interesting if you can hack the Blender version so it is using opaque
textures.
Guessing you didn't get a final 'Max Level' report if it didn't finish?
A shot in the dark, but one thing I've had happen occasionally since the
3.7 change to not count rays through transparent surfaces toward the
'Max Level' limit is get run-away rays/blocks that take a VERY long time
to render. I recall a blob scene in particular - one of the blob-flat
arrangements with negative blob texturing for the visible results.
My best guess as to what was happening was a that small number of rays
ended up running right along the 'flat surface threshold' so as to be
bouncing in and out of the transparent shape a very large number of
times. If I added even the slightest tint/transparency<1.0, render times
improved dramatically. I believe with the surface not completely clear
the adc_bailout kicked in at some point to stop the run away rays.
I suspect we got rid of the black spots from such ray/shape skimming
situations at the expense of rays potentially bouncing about a long time
where the ray / surface relationship is unfortunate and the surface is
completely clear. Given what folks usually ran into with the black spots
it was a good trade off I think.
Aside: There was too an old (<3.7) scene that turned run-away as I
remember - where previously the scene had counted on the max_trace_level
kicking in on the clear transitions for the result. Barbell media sort
of thing.
I did think some about another kind of max_trace_level which would count
rays continued through a transparent surfaces at a lessor weight
(instead of a weight of zero as in 3.7) so there would still be some
limit. Just an untried idea though. I'm unsure whether it would offer
better run-away control in practice and it wouldn't come free CPU wise
in the general case as underneath we'd effectively have to maintain two
counters with the new one for transparent surfaces occasionally adding
to the main limiting one.
Bill P.
Date: 23 Feb 2018 22:07:50
Message: <5a90d706@news.povray.org>
>> transparency maps.
>> unfinished.
> textures.
> of thing.
> Bill P.
For plain, transparent surfaces, where there is no refection nor
refraction, then, trace_level don't increase. I did not check with irid.
Don't mather if it's filter or transmit, and the actual colour don't mather.
In all other cases, trace_level increase by 1 each times the ray
encounter the surface.
So, interior{ior 1.000000001} will force the trace count to increase.
So will reflection{e-12}.
Also, I found that, apparently, adding any colour fading into the
interior or some media to the object will also cause the trace count to
increase.
Another way to controll run away rays is to change adc_bailout to a
slightly larger value than the default. Keep that increase small. Be
carefull with that one as, in some cases, it may cause some unwanted
defects.
Date: 24 Feb 2018 07:08:12
Message: <5a9155ac@news.povray.org>
>> transparency maps.
>> unfinished.
> textures.
Lighting and tinkering with the textures considered. Yes it looks similar.
When I switch off the transparency uv mapping. The scene renders in 2
seconds. With transparency switched on. I stopped the render at 18%
after 20 minutes.
Well, I cut down the mesh until it was just displaying the slowdown and
PovRay returned a value of 1/5
Although looking at the actual mesh it looks like layers of curved
planer meshes. 77, I counted them.
I don't understand the low Max Level.
For the adc_bailout to noticeably affect the time. I had to change it to 0.4
I did not expect it to go that high before having an effect.
> of thing.
I wouldn't start on that for this problem. I've read that Blender's OBJ
importer has some problems with Poser meshes. And mr is looking at
Blender's PovRay importer. If he can get that working the Blender
importer can be bypassed. (No pressure MR :-) _
> Bill P.
Regards
Date: 24 Feb 2018 07:10:07
Message: <5a91561f$1@news.povray.org>
> mather.
> increase.
> defects.
Food for thought. Thanks Alain
Regards
Date: 24 Feb 2018 07:25:27
Message: <5a9159b7$1@news.povray.org>
> increase.
Thanks! Three good ideas I'd not tried when getting stuck with run-away
rays.
I'll add another that once worked for me - ever so slightly changing the
camera position.
Aside: The camera change idea has a variant I've used not with run-away
rays, but rather with solver artifacts. It works with occasional success
and better on lower resolution images. Namely, rendering with an odd
number of pixels in the direction perpendicular to an artifact
directionally aligned with a row or column of pixels. You can sometimes
move rays so the artifact / solver issue is 'hiding' between pixel rows
or columns.
Bill P.
