POV-Ray : Newsgroups : povray.general : Transparent PNGs Server Time
15 Jul 2025 17:43:14 EDT (-0400)
  Transparent PNGs (Message 21 to 30 of 44)
Subject: Re: Transparent PNGs
Date: 11 Oct 2017 02:55:01
Message: <59ddc045$1@news.povray.org>
On 10-10-2017 16:10, clipka wrote:
> Am 10.10.2017 um 09:27 schrieb Stephen:
>>> I seem to remember to have had problems generating transparent png
>>> images while I never had problems with tga.
>> I recognised the form of the spell. I had the same problem donkey's
>> years ago.
>> There was a time when PNGs behaved badly. I think it was not writing the
>> Alpha values in the output.
> If I may clarify:
> PNG output in POV-Ray v3.6 had the alpha mode wrong - i.e. how the alpha
> channel is supposed to interact with the colour channels.
> The PNG specification mandates so-called "straight alpha", i.e. the
> colour channels should hold the colour as if the image was fully opaque,
> and blending should be done entirely by the display software, using
> Alpha:(1-Alpha) as the ratio between stored colour and background. This
> is akin to the way in which semi-transparent pigments are specified in
> POV-Ray's SDL.
> However, POV-Ray's internal computations yield colour channel values
> that already take opacity into account, which is akin to so-called "gay
> alph..." uh, I mean, "associated alpha" aka "premultiplied alpha", in
> which the display software is only responsible for the background
> portion of the blending, using 1:(1-Alpha) as the ratio between stored
> POV-Ray v3.6 neglected the issue of alpha mode entirely: In file output
> it directly wrote the computed colour values, thus always writing in
> associated alpha mode (which happens to be wrong for PNG files). In file
> input, on the other hand, it interpreted the colour values in much the
> same way as in SDL, thus always reading in straight alpha mode (which
> happens to be correct for PNG files but wrong for certain other files).
> So not only was POV-Ray v3.6 in violation of the PNG file format specs,
> it also was inconsistent in itself.
> In POV-Ray v3.7, a proper alpha handling framework was implemented, and
> the problem fixed for PNG files.
> (Interestingly, even though the modes are referred to as "associated
> alpha" and "straight alpha", it's not actually the alpha channel that's
> different between the two modes -- the value stored is actually
> identical for both modes -- but the colour channel.)
> The advantage of "straight alpha" is that you can display an opaque
> version of the image simply by ignoring the alpha channel.
> The advantages of "associated alpha" are that (a) it takes less
> computational effort to display, and (b) it can account for situations
> where bright light is to be shown against a highly transparent
> background (e.g. a transparent sphere with highlights).
It comes back now, yes. Thanks for the reminder. Interesting to notice
how it is former bad behaviour that sticks in the memory rather than the
later correction. Survival adaptation, no doubt ;-)
Date: 11 Oct 2017 06:26:04
Message: <59ddf1bc$1@news.povray.org>
>> years ago.
> If I may clarify:
> POV-Ray's SDL.
Interesting insight, thanks. :-)
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 11 Oct 2017 06:31:12
Message: <59ddf2f0@news.povray.org>
On 09.10.2017 06:56, Sven Littkowski wrote:
> Hi
> is it possible to create a scene where the rendered items are visible
> but the entire empty background becomes transparent, if the output image
> is a PNG?
> http://www.avg.com
I want to mention another problem that I have since I switched monitors
(now using a 16:9 monitor): the object of the scene has shifted to the
right side.
I tried to create a better camera, but still fail to get the 0.0 center
of the scene as center of the camera. Any assistance?
This is what i have now:
camera
 location < 0.0,  0.0, -50.0 >
 look_at  < 0.0,  0.0,   0.0 >
 right 1.77*x
Date: 11 Oct 2017 06:49:58
Message: <59ddf756$1@news.povray.org>
Am 11.10.2017 um 12:31 schrieb Sven Littkowski:
> right side.
> camera
>  right 1.77*x
That should work just fine -- at any resolution.
Are you sure it's not just your display software?
A test scene might be helpful.
(Also, I'd recommend using `right x*16/9` rather than the fudgy factor
of 1.77; with full-resolution renders it does make a difference of
something in the order of 10-20 pixels. Or use `right
x*image_width/image_height` to be independent of output image aspect ratio.)
Date: 11 Oct 2017 08:38:28
Message: <59de10c4$1@news.povray.org>
On 11.10.2017 06:49, clipka wrote:
> right
Thanks. :-)
http://www.avg.com
Date: 11 Oct 2017 08:41:33
Message: <59de117d$1@news.povray.org>
Okay, here is the latest problem and also the scene code.
The value "AmountLines" allows me to set the amount of oar lines above
each other, but strangely, I always get just one line. I am very sure,
the fault is with me: "I am not seeing the forest because of all the
trees in my eyesight". Means, I am looking at the scene code, and just
can't discover the error in thinking/writing. Can you help?
---SCENE-------------------------------------------------------
#local Temp_version = version;
#version 3.7;
#declare MyRadiosity = off;   // on
global_settings
 #if(MyRadiosity)
  radiosity
   media on
   pretrace_start 0.08
   pretrace_end   0.001
   count 400
   error_bound 0.75
   recursion_limit 1
   normal on
 subsurface        {}
 adc_bailout       0.0039
 ambient_light     rgb < 0.000, 0.000, 0.000 >
 assumed_gamma     1.000
 irid_wavelength   rgb < 0.250, 0.180, 0.140 >
 max_trace_level   5
 number_of_waves   10
 noise_generator   3
 charset           ascii
camera
 location < 7.0,  0.0, -50.0 >
 look_at  < 7.0,  0.0,   0.0 >
light_source
 < -50000.0, 50000.0, -50000.0 > //light position
 color rgb < 1.0, 1.0, 1.0 > * 1.0
 parallel
 point_at < 0.0, 0.0, 0.0 >
#include "textures.inc"
#declare UpperOar = texture
 DMFDarkOak
 pigment { color rgb < 1.0, 1.0, 1.0 > }
 normal { wood 0.5 scale 0.3 turbulence 0.1 }
 finish { phong 1 }
 rotate< 90.0, 0.0, 0.0 >
 scale 0.25
#declare LowerOar = texture
 DMFDarkOak
 pigment { color rgb < 0.3, 0.01, 0.0 > }
 finish { phong 1 }
 scale 0.25
#declare TotalLength      = 10.0;   // length of oars of the lowest line
#declare AmountOarsInLine = 30;
#declare AmountLines      = 3;
#declare LineLeftShift    = 0.5;    // shift towards the left side for
additional lines
#declare LineHeightShift  = 0.5;    // distance to line below
#declare MyVariance       = 4.0;    // human irregularity
#declare MyHeightMore     = 0.50;   // upper lines need longer oars
#declare GeneralAngle     = 40;     // the angle of each oar from hull
towards water
#declare BladeAngle       = 85.0;   // the angle of the blade when
touching water
#declare ForwardAngle     = 05.0;   // to equalize the ends of each line
to the eye
#declare R1 = seed(1);
#declare R2 = seed(2);
#declare R3 = seed(3);
#macro MyOar(MyHeightMoreThis)
 union
  union
   cone
    < 0.0, -10.0, 0.0 > 0.000 < 0.0, -9.9, 0.0 > 0.250
   cone
    < 0.0, -9.9, 0.0 > 0.250 < 0.0, -5.5, 0.0 > 0.000
   texture { LowerOar }
   scale < 1.0, 1.0, 0.1 >
  union
   cone
    < 0.0, -9.5, 0.0 > 0.020 < 0.0, -5.5, 0.0 > 0.075
   cylinder
    < 0.0, -5.5, 0.0 > < 0.0, 0.0, 0.0 > 0.075
   #if(MyHeightMoreThis>0)
    cylinder
     < 0.0, MyHeightMoreThis, 0.0 > < 0.0, 0.0, 0.0 > 0.075
    translate < 0.0, -MyHeightMoreThis, 0.0 >
   texture { UpperOar }
  }  no_shadow
#declare MyNumber = 0;
#macro MyOarLine(AmountOarsInLine,MyHeightMoreThis)
 union
  #while(MyNumber<AmountOarsInLine)
   #declare MyAngleWater     = (rand(R1)*MyVariance)+GeneralAngle;
   #declare MyAngleHands     = (rand(R2)*MyVariance)+BladeAngle;
   #declare MyAngleDirection = (rand(R3)*MyVariance)+ForwardAngle;
   object
    rotate < 0.0, MyAngleHands, 0.0 >
    rotate < MyAngleWater, 0.0, 0.0 >
    rotate < 0.0, 0.0, MyAngleDirection >
    translate < (MyNumber*0.925), 0.0, 0.0 >
   #declare MyNumber = MyNumber+1;
union
 #declare ThisLine = 0;
 #while(ThisLine<AmountLines)
  object { MyOarLine(AmountOarsInLine,MyHeightMore*ThisLine) translate <
-((AmountOarsInLine*0.925)/2)+0.925-(LineLeftShift*ThisLine),
LineHeightShift*ThisLine, 0.0 > }
  #declare ThisLine=ThisLine+1;
 box
  < -20.0, -15.0, 0.0 > < 20.0, 15.0, 0.1 >
 box
  < -1.0, -25.0, 2.0 > < 1.0, 25.0, 2.1 >
  pigment { color rgb < 0.5, 0.5, 0.5 > }
 translate < 0.0, 0.0, 0.0 >
http://www.avg.com
Date: 11 Oct 2017 09:35:00
Message: <web.59de1d6bc5de9ff4c437ac910@news.povray.org>
You never have a line that increments ThisLine.
Add
#declare ThisLine = ThisLine + 1;
or use a
#for (ThisLine, 1, 3)
loop.
Date: 11 Oct 2017 10:04:05
Message: <59de24d5$1@news.povray.org>
Am 11.10.2017 um 15:32 schrieb Bald Eagle:
Actually he does.
Date: 11 Oct 2017 10:15:00
Message: <web.59de2659c5de9ff4c437ac910@news.povray.org>
grrr.
Sorry, I was in the middle of handling a few thousand pounds of stuff and
clicked before I triple-read your code.
Now that I have a proper break:
Of course you had to have that increment, otherwise you'd have an infinite
loop...
But I do notice you're translating based on that value times 0.5.  Is that
supposed to be 0.5 times --- some absolute height value?   Maybe your vertical
translation is too small.
What if you create an array for your oar texture, and have each successive line
of oars be a different color - then it might be easier to see what's going on /
going wrong.
maybe output the location of the bounding boxes to the #debug stream as well...
Date: 11 Oct 2017 10:17:06
Message: <59de27e2$1@news.povray.org>
Am 11.10.2017 um 14:41 schrieb Sven Littkowski:
>  union
>    object
>   #end
> #end
You need to set `MyNumber = 0` each time you're running the macro (i.e.
the `#declare` should be inside the macro. Also, I'd suggest using
`#local` instead; it's good practice for macros, unless you want to pass
values out of the macro via global variables.)
