POV-Ray : Newsgroups : povray.general : Solidifying a Mesh Object Server Time
14 Jan 2026 11:44:12 EST (-0500)
  Solidifying a Mesh Object (Message 1 to 10 of 16)
Subject: Solidifying a Mesh Object
Date: 19 Aug 2017 03:04:57
Message: <5997e319$1@news.povray.org>
Intention:
Using the "Difference" function to create caves and tunnels inside a
square-shaped piece of Martian surface (a hollow mesh object).
What are your solutions, to transfer what is now a mesh, into a solid
object. I believe these objects need to be solid, in order to create
caves and tunnels through Difference into that body.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: Solidifying a Mesh Object
Date: 19 Aug 2017 04:00:10
Message: <5997f00a@news.povray.org>
On 19-8-2017 8:04, Sven Littkowski wrote:
> Intention:
Once thing you can do is an intersection with a slightly smaller box in
the horizontal directions, and as deep as you want downward. This
creates the subterranean world.
Date: 19 Aug 2017 04:23:59
Message: <5997f59f$1@news.povray.org>
On 19/08/2017 07:04, Sven Littkowski wrote:
> Intention:
You are thinking about it wrongly.
There are no solid mesh objects. The keyword "hollow" has nothing to do
with an object not being solid. It is used for media containers.
You should think in terms of the mesh not having any holes. Then you can
use it with csg without artefacts. In the animation below I intersected
the mesh of Ariel (the ghost) was intersected with a cub then filled
with media. The hollow keyword was used for that.
http://www.tc-rtc.co.uk/member/imagenewdisplay/index176.html
When I was creating the df3s for Dhalgren with Thomas. I had a lot of
trouble with the meshes when they had holes in them. (I had to manually
edit the slices that make up the image sequence.)
http://news.povray.org/povray.binaries.images/thread/%3C58343a6a@news.povray.org%3E/
Regards
Date: 19 Aug 2017 04:34:38
Message: <5997f81e$1@news.povray.org>
Am 19.08.2017 um 08:04 schrieb Sven Littkowski:
> Intention:
The solution has been mentioned multiple times already: In POV-Ray, a
`mesh` or `mesh2` object is considered solid if (and only if) it has a
(non-null) `inside_vector` parameter.
The parameter value needs to be a direction, but the actual value is
usually irrelevant as long as the mesh is closed.
If the mesh isn't closed and has holes, using an `inside_vector` will
cause artifacts in CSG operations: Essentially, any hole is extruded to
infinity in the direction opposite to the `inside_vector` direction,
except that these extrusions don't have visible surfaces and just
interact in CSG.
Date: 19 Aug 2017 04:44:03
Message: <5997fa53$1@news.povray.org>
It might be an idea to write it in German.
Regards
Date: 19 Aug 2017 07:04:57
Message: <59981b59$1@news.povray.org>
>> Intention:
After reading Clipka's answer below, you do not strictly need to do what
I suggested in the first place but it can help to show the
'subterranean' boundaries of the landscape mesh.
So, just make differences with any object you need: a cylinder for
instance as a tunnel entrance.
Date: 19 Aug 2017 07:42:11
Message: <59982413$1@news.povray.org>
Another point I forgot to mention: you may have noticed when in Poseray
or when rendering in POV-Ray, that the Martian landscape does not have
the usual left-handed orientation (X-right, Y-up, Z- screenwards) but a
right-handed one (X-right, Y-screenwards, Z-up). You can easily remedy
that in Poseray. After you recalculated the normals in the Groups
folder, first press the 'Flip Y-Z axis' button, then in the Transform
section, set Scale z to -1 and press the 'Transform' button. Finally,
export to POV-Ray.
Date: 19 Aug 2017 08:09:26
Message: <59982a76$1@news.povray.org>
>> Intention:
ray.org%3E/
Thanks. The first link requires a username and password, was not able to
see the animation just like that.
Nonetheless, good to know I can still work with division. Will give a try.
http://www.avg.com
Date: 19 Aug 2017 08:12:02
Message: <59982b12$1@news.povray.org>
>> Intention:
> interact in CSG.
Thanks. Yes, I remember to have read it before. Just, how to define such
a non-zero parameter? I never did that before. As I understand, the
location can be anywhere inside the mesh body.
And in case there are gaps, is there any program that can close any open
gaps in meshes, POV, obj, 3DS, whatever format?
http://www.avg.com
Date: 19 Aug 2017 10:49:50
Message: <5998500e$1@news.povray.org>
Am 19.08.2017 um 13:11 schrieb Sven Littkowski:
I repeat: `inside_vector` is NOT a location, but a direction.
That direction is used in a test to answer the question "is location P
inside the mesh?", but that location P is nothing /you/ need to worry
about: POV-Ray of its own accord will come up with plenty of values for
P that it will want to subject to this test.
As for wondering "how to define such a non-zero parameter", that's the
equivalent of searching the "any" key on your keyboard: Literally /any/
vector parameter other than `<0,0,0>` will do. For example:
    mesh2 {
      inside_vector y
Alternatively, instead of `y` you could also use `z`, or `x`, or
`<5,4,3>`, or `<sin(42*pi/180),-exp(23),4711>`. Anything for which
`vlength(V)` doesn't return zero. (Presuming, of couse, that your mesh
is properly closed. Otherwise, the best choice in your case is whatever
direction is considered to be "up" with respect to the mesh.)
I'm pretty sure meshlab is able to do that. Blender also surely provides
a way, though it might take you on a sightseeing trip through the entire
software. For very small gaps where the vertices of adjacent triangles
just don't meet up exactly, PoseRay also provides a tool.
