POV-Ray : Newsgroups : povray.general : Photoshop Question (needed for texture) Server Time
16 May 2026 20:41:00 EDT (-0400)
  Photoshop Question (needed for texture) (Message 1 to 10 of 12)
Subject: Photoshop Question (needed for texture)
Date: 29 Jul 2017 03:39:48
Message: <597c3bc4$1@news.povray.org>
Is anyone here who uses Photoshop? I have a question in regards to the
texture of my current POV-Ray project.
Is there a way in Photoshop (I use the older 7 version) to get the
average color of a selected image area? Maybe even to colorize that
selected image area with that average color? A plugin?
Example: I selected an area within a photo (a rectangular marquee), that
shows many items in bright yellow, and a few items in orange. The
average color would be a warm slightly orangish yellow...
Ideally, there would be also a way to replace all contents of that
selected photo area with just that color alone, resulting in a
warm-yellow rectangle.
Any advises for a plugin or procedure?
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: Photoshop Question (needed for texture)
Date: 29 Jul 2017 14:20:03
Message: <web.597cd0c5f28314b883fb31c0@news.povray.org>
Would you believe that I *just* wrote such a macro, in POV-ray itself?!
(Photoshop isn't required.) I made it for my 'city building' generator-- and had
planned to post it, but got side-tracked. It does exactly what you need: finding
the overall average color from the many colors in an image_map.
Give me a day to double-check the code, and I'll post it ASAP. Can't do it
today; I'm temporarily too busy with 'real life'...  :-/
Date: 29 Jul 2017 14:45:01
Message: <web.597cd673f28314b883fb31c0@news.povray.org>
As an experiment (in Photoshop)  you might try using *heavy* Gaussian Blur on
the image-- so that it's completely blurred-out--then finding the color of a
pixel somewhere near the center of the image. I don't know if this would work
accurately, as I've never tried it.
Date: 30 Jul 2017 05:49:43
Message: <597dabb7@news.povray.org>
No, these two options would not work for me.
1
Gaussian Blur, even within a marquee (selection) would still catch color
from the neighboring areas, I already tried it.
2
I need this on an image, true. But the marquees (selections) are not
square, but like a pie-piece. And all are also different from each
other. I really need a Photoshop solution. I really wished, I could use
your POV-Ray macro.
I need it for the latest version of my "Question: Bump Not Showing"
balloon texture file, inside the IMAGES group here. I am posting that
texture file as very last posting within that thread, using your name
inside the posting thread. When looking at that texture file, you will
see the dark borders within. And I need a color averaging for each field
of that texture.
http://www.avg.com
Date: 30 Jul 2017 07:20:20
Message: <597dc0f4$1@news.povray.org>
> of that texture.
I looked at the image you posted. It looks completely black.
PaintShopPro tells me that there are 6 unique colours in it. I can see
no detail in it at all. Even after adjusting brightness, contrast etc.
Now when I used an edge enhance function three times I did get a result.
I's very faint.
Regards
Date: 31 Jul 2017 08:05:00
Message: <web.597f1caef28314bc437ac910@news.povray.org>
Maybe if you just use eval pigment to sample all the rgb values, average them
and then place a box at that point, using only povray.
Sorry I don't have too much more - I'm at work  ;)
Date: 31 Jul 2017 15:20:01
Message: <web.597f8270f28314bc437ac910@news.povray.org>
#version 3.71
global_settings {
 assumed_gamma 1.0
// example scene to average pigment values in a box
// x and y ranges are -0.5 to 0.5
// Bill Walker "Bald Eagle"  2017
#include "functions.inc"
#include "rand.inc"
  orthographic
  location <0,0,-1>    // position & direction of view
  look_at  <0,0,0>
  right 1*x            // horizontal size of view
  up 1*y               // vertical size of view
#declare Rseed = seed (123);
#declare Gseed = seed (456);
#declare Bseed = seed (789);
#declare Pig =
     cells
     color_map {
      #for (E, 0, 1, 0.1)
       #local R = rand (Rseed);
       #local G = rand (Gseed);
       #local B = rand (Bseed);
       [E  color red R green G blue B]
    #end // end for E
   } // color_map
   scale 0.01
    } // end pigment
box {                  // this box fits exactly in view
 <-0.5, -0.5, 0>, <0.5, 0.5, 0>
 pigment {Pig}
} // end box
#declare YS = 1/image_height;
#declare XS = 1/image_width;
#declare ymin =  0.12;
#declare ymax =  0.25;
#declare xmin = -0.11;
#declare xmax =  0.15;
#declare AVG = 0;
#for (Y, ymin, ymax, YS)
 #for (X, xmin, xmax, XS)
  #declare Shade = eval_pigment (Pig, <X, Y, 0>);
  #declare AVG = AVG + Shade;
 #end // end for X
#end // end for Y
#declare AVG = AVG / ( ((xmax-xmin)/XS) * ((ymax-ymin)/YS) );
 <xmin, ymin, -0.01>, <xmax, ymax, -0.01>
 texture {pigment {color rgb AVG}}
} // end box
Gives a gray box over the "cells" pattern.
I'm aware of the redundancy of generating the random colors for the cells
pattern - but I wanted that code block in there with the color map...
Date: 31 Jul 2017 19:43:16
Message: <597fc094$1@news.povray.org>
On 31.07.2017 15:18, Bald Eagle wrote:
 them
> #version 3.71
> global_settings {
>  assumed_gamma 1.0
> #include "rand.inc"
> camera {
>   orthographic
>   look_at  <0,0,0>
> #declare Pig =
>     pigment {
>      cells
>      color_map {
>       #for (E, 0, 1, 0.1)
>     #end // end for E
>    } // color_map
>    scale 0.01
>     } // end pigment
>  pigment {Pig}
> } // end box
> #declare AVG = 0;
>  #end // end for X
> #end // end for Y
> } // end box
Thanks. Actually, there is a related thread inside the IMAGE group,
there you can see the texture file and its many pie-shaped areas, which
I want to transform to the individual average color of each section.
http://www.avg.com
Date: 1 Aug 2017 00:45:01
Message: <web.5980069af28314b9c5d6c810@news.povray.org>
--->8---
> #declare Pig =
>     pigment {
>      cells
>      color_map {
>       #for (E, 0, 1, 0.1)
>     #end // end for E
>    } // color_map
>    scale 0.01
>     } // end pigment
>  pigment {Pig}
> } // end box
> #declare AVG = 0;
>  #end // end for X
> #end // end for Y
> } // end box
That's a nifty way of going about it, even if I can't think of a way to use it
for myself someone might. Good work.
Date: 1 Aug 2017 21:12:10
Message: <598126ea$1@news.povray.org>
I went to a place where a newer version of Photoshop is installed, and
got what I wanted. Thanks to everyone!
http://www.avg.com
