POV-Ray : Newsgroups : povray.general : RGB color cube function? Server Time
25 Feb 2026 02:54:04 EST (-0500)
  RGB color cube function? (Message 1 to 6 of 6)
Subject: RGB color cube function?
Date: 28 Apr 2017 17:33:27
Message: <5903b527$1@news.povray.org>
I'd like to render some objects whose RGB color pigment is just the
coordinate of that surface point.
So, when I render a "unit cube" box{<0,0,0>,<1,1,1>} it is just a RGB
color cube, but when I cut some slices than the "inner colors" are visible.
How can this be made?
Lars R.
P.S.: I don't care for the colors outside of the unit cube. It might be
"saturating" or repeating or black or transparent, I just have objects
within that unit cube.
Subject: Re: RGB color cube function?
Date: 28 Apr 2017 20:35:01
Message: <web.5903df57a0a804b9acfa72180@news.povray.org>
I'm sure there's a way to do it with a pigment function, but perhaps mixing 3
different orthogonal pigments with the average directive is the way to go...
http://news.povray.org/povray.advanced-users/message/%3C5837408a%241%40news.povray.org%3E/#%3C5837408a%241%40news.povra
y.org%3E
Date: 29 Apr 2017 08:45:24
Message: <59048ae4$1@news.povray.org>
> Lars R.
If you are running with POV-Ray 3.7.1 or later there is the new
user_defined pattern for pigments where the channels are each controlled
directly by functions. See:
http://wiki.povray.org/content/Reference:User_Defined_Pattern
For what you want something like:
   user_defined {
     function { x },
     function { y },
     function { z },
should work I think.
Aside: I've played only a little with Christoph's new feature here, but
it's obvious already to me that it throws open the door - so to speak -
on what can be done with pigments. I'm also finding this method of
specifying pigments easy to use.
Bill P.
Date: 29 Apr 2017 08:56:44
Message: <59048d8c$1@news.povray.org>
On 4/29/2017 1:45 PM, William F Pokorny wrote:
> Aside:
Aside. Don't forget to vote in the second last TC-RTC Challenge.
Last day - tomorrow.
Regards
Date: 29 Apr 2017 17:42:08
Message: <590508b0$1@news.povray.org>
> pigment {
>   user_defined {
>     function { x },
>     function { y },
>     function { z },
Awesome! I didn't know that. It is not mentioned in the online docu,
yet, is it?
Absolutely! I have thousands if ideas what to do with that feature!
Thanks for that!
Lars R.
Date: 30 Apr 2017 07:22:03
Message: <5905c8db@news.povray.org>
> yet, is it?
The link above is part of the online wiki documentation(1) at:
http://wiki.povray.org/content/Documentation:Contents
The feature is not of course mentioned in the online documentation for
earlier fixed releases of POV-Ray posted at :
http://www.povray.org/documentation/
Bill P.
(1) The wiki documentation is always the most current available with
respect to in-development versions of POV-Ray.
