POV-Ray : Newsgroups : povray.general : Ovus Server Time
19 May 2024 20:33:15 EDT (-0400)
  Ovus (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Ovus
Date: 5 May 2016 09:15:47
Message: <572b4783$1@news.povray.org>
On 05/04/2016 03:19 PM, clipka wrote:
> Am 04.05.2016 um 18:14 schrieb Le_Forgeron:
> (*) On the other hand, it could still be considered an extension to the
> ovus, as in "an ovus, but don't give me the spheres because I already
> have them"; most notably, the parameterization, as you envision it,
> would still be based on the concept of an ovus; also, it would make a
> lot of sense in terms of implementation, because all you'd have to do
> would be to suppress the spherical portions.
My thoughts - while probably not following you both completely. Also
being more interested in getting at the inner citrus shape than having
more flexible egg/ovus shapes.
I vote for providing access to the citrus shape as an extension to the
ovus given we have the ovus today - at least as seen by us users.
Perhaps too we should continue calling it the citrus shape of the ovus
given it has been introduced as such already. Though certainly other
names, like those suggested, would be more descriptive for such a shape
standing apart.
Aside: I played some with this inner shape as an isosurface some while
back on seeing the ovus introduced. It looked a useful base
shape/function. However, the sharp points on the end drive up the
isosurface time considerably, so having other access to this shape would
be cool.
When we want:
1) the full citrus shape. Would we specify a length directly or do this
by specifying the distance between the two spheres and both radii as
zero or nearly zero?
2) the citrus shape clipped equally on both ends - the barrel shape.
Would we specify a distance between spheres, both radii the same and
then to drop both spheres from the result?
3) the citrus shape clipped at one end -an ogive or bullet. We'd do
something like (2), but be able to drop just the larger sphere while the
other sphere stays with a near zero radius out at the end of the citrus?
4) the citrus shape clipped unequally... Is this doable at all as a
give-me-the-citrus extension to the ovus? It looks to me like the clip
to the larger sphere happens perpendicular to the origin of that sphere,
but the clip to the smaller sphere is somehow calculated & not clear to
me how?
Bill P.
Subject: Re: Ovus
Date: 5 May 2016 11:53:27
Message: <572b6c77$1@news.povray.org>
Am 05.05.2016 um 15:15 schrieb William F Pokorny:
> standing apart.
I can only assume that the term "citrus" was introduced as a
description, not a technical term, and I strongly discourage its use in
this sense. As a matter of fact, in mathematics the term "citrus" is
already in use for a different shape.
The proper technical term would be "lemon", while I've been using the
term "spindle" instead, owing to the fact that it is the inside surface
of a "spindle torus".
> When we want:
For the full shape, you would simply use
    torus { R1, R2 intersection }
with classic torus parameters for R1 and R2 (with R2>R1). Some
trigonometry may be required to compute these from some other
parameterization such as the distance between the tips and the "equator"
radius.
This syntax will be supported in 3.7.1, and has already been available
in dev releases for quite a while (though I think I didn't make much
noise about it).
That depends on what syntax we eventually end up with ;)
I'm quite sure that would be a special case of 2).
> me how?
In the current ovus implementation, the transition between the lower
sphere and the lemon actually does /not/ coincide with the equator of
the lower sphere (except for very specific selections of parameters),
even though /some/ of the sample images seem to imply that.
Subject: Re: Ovus
Date: 5 May 2016 15:48:45
Message: <572ba39d$1@news.povray.org>
Le 04/05/2016 17:42, clipka a écrit :
>>> (1) Can you update the documentation to include...
>>> >> (1.a) how the radius of the spindle is computed;
>>> >> (1.b) the fact(?) that the bottom sphere is always placed at <0,0,0>
>> > the documentation is in the wiki, right ? So anyone could update it to
>> > add these element. I thought 1.b was already in the documentation.
> Guess what -- I'm a bit busy documenting all the stuff I've added since
> 3.7.0 ;)
> Also, I thought you might have produced the original 2D sketch, and
> might be the person most fit to add the minor spindle radius to it.
> You're right about 1.b though.
I updated the wiki to drop "citrus", both on text and 3D image.
For the 2D sketch, I would need to remake it from scratch to better illustrate the
point
of the center being elsewhere... as well as the connection being not on the x-axis.
I might actually illustrate that better
with a large picture, I'm afraid.
Subject: Re: Ovus
Date: 6 May 2016 07:25:00
Message: <web.572c7e67c7c0b2e35e7df57c0@news.povray.org>
Maybe it should be called the "rind"    :D
Subject: Re: Ovus
Date: 6 May 2016 07:51:13
Message: <572c8531$1@news.povray.org>
I would go for the Scots word "Peerie" as in whip and peerie (a child's
spinning top).
It can also mean small.
Regards
Subject: Re: Ovus
Date: 6 May 2016 08:01:29
Message: <572c8799$1@news.povray.org>
Thanks Christoph. I wrongly assumed it was the citrus surface in use
with the ovus due the documentation's use of the term. I used for my
isosurface play the citrus surface equation at:
  http://mathworld.wolfram.com/Lemon.html
not the lemon surface.
Bill P.
Subject: Re: Ovus
Date: 6 May 2016 10:15:01
Message: <web.572ca681c7c0b2e3b488d9aa0@news.povray.org>
Correct me if I'm wrong, but does Wolfram have the 2D cross-sectional diagrams
(on the right) switched for the spindle and horn tori?
http://mathworld.wolfram.com/SpindleTorus.html
http://mathworld.wolfram.com/HornTorus.html
Subject: Re: Ovus
Date: 6 May 2016 10:24:10
Message: <572ca90a@news.povray.org>
Yes, you are correct. the slice is correct, but the 3D in the middle are
switched.
Subject: Re: Ovus
Date: 25 May 2016 08:06:39
Message: <5745954f$1@news.povray.org>
Le 04/05/2016 à 17:42, clipka a écrit :
>> > About being doable, yes, I can (but there will be additional constraints
>> > on the values, such a minimal minor radius function of the three other
>> > distances under which you would get an error)
> Of course such constraint checks would be part of the deal.
>> > And do you expect default values for some parameters too ? (yet more
>> > syntax sugar... )
> Since I'd advocate to put it into the ovus primitive, of course the
> default values would be Bottom_radius for the Y coordinate of the top
> sphere, and 2*max(Bottom_radius,Top_radius).
back to that subject... finding a suitable syntax, backward compatible
with existing syntax.
So far :
   ovus { Bottom_radius, Top_radius }
0 <= Bottom_radius
0 <= Top_radius <= 2*Bottom_radius
(when TopRadius > 2*BottomRadius, object is replaced by a sphere)
Additional parameters:
   InnerRadius (default to 2 * max( Bottom_radius, Top_radius )
   Distance_between_spheres (default to Bottom_radius )
0 <= Bottom_radius
0 <= Top_radius
0 <= Distance_between_spheres (Bottom is at <0,0,0>,
   but Top is at <0, Distance_between_spheres, 0> instead
   of <0, Bottom_radius, 0>
complex relation for InnerRadius vs its minimal value.
If it was only for one additional parameter the obvious syntax would
have been:
   ovus { Bottom_radius, Top_radius [, extra_value ] }
Please provide some suggestions about an acceptable syntax.
Subject: Re: Ovus
Date: 25 May 2016 14:05:15
Message: <5745e95b$1@news.povray.org>
Am 25.05.2016 um 14:06 schrieb Le_Forgeron:
> have been:
How about
    ovus { Bottom_radius, Top_radius [, extra_value1, extra_value2 ] }
