POV-Ray : Newsgroups : povray.general : Override textures and materials? Server Time
23 Aug 2025 01:00:03 EDT (-0400)
  Override textures and materials? (Message 1 to 10 of 22)
Subject: Override textures and materials?
Date: 15 Jan 2016 23:54:20
Message: <5699ccfc$1@news.povray.org>
Is there a way to force an override of preconfigured textures and
materials of a scene? I would like to set the texture of my scene to a
special texture used to render ChromaDepth 3D images. However, I don't
want to go back and edit every single object in my scene. Thanks.
Mike
Subject: Re: Override textures and materials?
Date: 16 Jan 2016 03:10:44
Message: <5699fb04$1@news.povray.org>
My experience is that you will have to comment the old ones out or
delete them. Later textures do not override previous ones in a scene file.
Date: 16 Jan 2016 04:42:37
Message: <569a108d$1@news.povray.org>
Are you sure about that Thomas?
I use Bishop3D which does not support PovRay 3.7. So if I want to use
PovRay 3.7 textures I will use a 3.6 texture in the Bishop3D scene but
redifine the tecture before the object is declared.
Sample code generated by Bishop3D.
#version 3.7;
global_settings {
adc_bailout       0.0039
ambient_light     rgb <1.000,1.000,1.000>
assumed_gamma     1 //2.200
irid_wavelength   rgb <0.250,0.180,0.140>
max_trace_level   5
number_of_waves   10
noise_generator   3
charset           ascii
background { color rgb <0.000,0.000,0.000> }
// referenced scene items and forced visible scene items declaration begin
#declare Shadow_Clouds_Mid =
bozo
color_map {
[0.000 rgbft <0.850,0.850,0.850,0.000,0.000>]
[0.100 rgbft <0.750,0.750,0.750,0.000,0.000>]
[0.500 rgbft <1.000,1.000,1.000,0.000,1.000>]
rotate    <0.0,0.0,90.000>
rotate    <180.000,0.0,0.0>
scale     <1.000,6.000,6.000>
rotate    <-180.000,0.000,-90.000>
turbulence <0.650,0.650,0.650>
octaves 6
lambda 2.000
omega 0.700
#declare Shadow_Clouds_Bot =
bozo
color_map {
translate <0.000,-0.150,0.000>
octaves 6
lambda 2.000
omega 0.700
#declare Shadow_Clouds_Top =
color rgbft <0.196,0.600,0.800,0.000,0.000>
#declare Red_Texture =
color rgbft <1.000,0.000,0.000,0.000,0.000>
#declare Blue_White_Tiles2 =
checker
color rgbft <1.000,1.000,1.000,0.000,0.000>
color rgbft <0.000,0.502,1.000,0.000,0.000>
rotate    <0.0,0.0,180.000>
rotate    <-90.000,0.0,0.0>
scale     <-300.000,-300.000,-1000.000>
rotate    <90.000,0.000,-180.000>
rotate    <0.000,-180.000,0.000>
scale     <0.010,0.010,0.010>
#declare Camera0 =
perspective
location <-3.5,46.0,-195.0>
up y
right 1.333*x
angle 33.000
sky <0.0,1.0,0.0>
look_at < 0.000, 7.500, 0.000 >
// referenced scene items and forced visible scene items declaration end
union {
light_source {
< 0.00, 0.00, 0.00 >, color rgb <1.000,1.000,1.000>
fade_power 0.000
fade_distance 100.000
media_attenuation off
media_interaction on
translate <15.0,100.00,-200.0>
light_source {
fade_power 0.000
translate <-25.0,55.0,-200.0>
sky_sphere {
pigment{ Shadow_Clouds_Top }
pigment{ Shadow_Clouds_Mid }
pigment{ Shadow_Clouds_Bot }
plane {
y , 0
texture{ Blue_White_Tiles2 }
scale     <10.00,1.00,10.00>
//------- Sphere0 Raw Script Begin -------
     color rgbft <1.000,1.000,0.000,0.000,0.000>
//------- Sphere0 Raw Script End ---------
sphere {
0.0, 1.00
texture{ Red_Texture }
scale     <5.954000,5.954000,5.954000>
rotate    <90.00,0.00,0.00>
translate <0.00,5.6490,0.00>
camera{ Camera0 }
Regards
Date: 16 Jan 2016 04:55:00
Message: <web.569a132a40a8aed333c457550@news.povray.org>
I agree, that would be a *really* useful feature in POV-Ray. I've had need of
something like what you've described; but as Thomas says, the only way at
present is to (tediously) edit the scene file, then add a #default texture to
apply to all the objects. Or else pre-plan the entire scene with your final
results in mind from the very beginning (which, I admit, usually isn't
practical, when the effect you're looking to create might simply be an
afterthought or a 'what-if' experiment!)
Date: 16 Jan 2016 05:15:10
Message: <569a182e$1@news.povray.org>
Why not put your textures in an INC file then you could put your
alternative textures in another INC file. If they have the same names
you can select which set of textures to use by using the #include command.
Regards
Date: 16 Jan 2016 07:36:04
Message: <569a3934@news.povray.org>
>> file.
Yes, when you have an object already textured to which you apply a
second texture:
object{
   MyObject //with predefined texture
   texture {MyTexture}
This does not work.
You may get away with that provided you use identical texture names
declared /before/ the object is opened/used.
As you say in answer to Kenneth, using an alternative texture file can
do the trick, especially in typical mesh2 file builds.
#include "MyObjectTexture.inc"
#declare MyObject = mesh2{....}
As long as the texture names defined inside the alternative .inc file
are identical to those defined inside the mesh2 file.
Date: 16 Jan 2016 08:39:05
Message: <569a47f9$1@news.povray.org>
The problem in my case is that the individual textures are oriented to
the local coordinates of each object, whereas I need a texture that is
tied to the global coordinate system. I don't know how to compensate for
this.
Mike
Date: 16 Jan 2016 09:20:39
Message: <569a51b7@news.povray.org>
>> command.
> this.
> Mike
I misunderstood. I thought you wanted to swap between textures. Thomas
was right. (As usual.)
I just had a quick look at what Chromadepth is and it looks quite
interesting. Designing a scene where the depth information is in the
colour will be, as I said, interesting. With red being in front, and
blue being back.
I think you might be able to do it with a bit of jiggery pokery in the
way you write your textures and scene.
I’ll dwell on’t. ;-)
Regards
Date: 16 Jan 2016 13:10:05
Message: <569a877d$1@news.povray.org>
Mike, you mean something like discussed in the thread "NEW FEATURE:
Suggesting "aka" (Textures)" of the "p.beta-test" section of our
newsgroups here?
Date: 16 Jan 2016 13:34:20
Message: <569a8d2c$1@news.povray.org>
> newsgroups here?
I don't know... I wasn't able to understand your suggestion.
Is it possible to create an empty texture? In this case, I could swap
out the current textures and instead apply one texture to the entire
scene. Without too much effort on my part if it works.
Mike
