POV-Ray : Newsgroups : povray.general : mesh2 syntax query Server Time
28 Sep 2024 17:30:12 EDT (-0400)
  mesh2 syntax query (Message 1 to 9 of 9)
Subject: mesh2 syntax query
Date: 7 Dec 2013 08:26:01
Message: <52a321e9$1@news.povray.org>
I have a really frustrating issue. I have a tool that emits mesh2
objects with embedded texture indices.
vertex_vectors {
	4,
face_indices {
	4,
	<...>, 0, 1, 2
This is then being loaded by a Povray file:
object {
	mesh2 {
		#include "thing.inc"
	translate <...>
I want the texture list to be in the Povray file, not in the machine
generated include file, because it's source code. But the syntax appears
to be insisting that the texture_list clause goes *between* the
vertex_vectors and face_indices clause. In order to emit it there, my
tool needs to know stuff about the structure of the Povray file that it
really shouldn't know.
I've tried defining the texture list with #declare, but that doesn't
work because texture_list isn't an rvalue and can't be assigned to a
variable.
Is there any wrinkle of syntax that will allow me to get the texture
list out of the include file?
┌─── dg@cowlark.com ─────
http://www.cowlark.com ─────
│ "There does not now, nor will there ever, exist a programming
│ language in which it is the least bit hard to write bad programs." ---
│ Flon's Axiom
Subject: Re: mesh2 syntax query
Date: 7 Dec 2013 08:52:49
Message: <52a32831@news.povray.org>
Am 07.12.2013 14:26, schrieb David Given:
> variable.
There is indeed: While the documentation claims that the texture_list
must go between vertex_vectors and face_indices, the actual
implementation also allows it to be placed /before/ vertex_vectors.
Date: 7 Dec 2013 10:58:00
Message: <52a34588@news.povray.org>
>> variable.
better? ... http://wiki.povray.org/content/Reference:Mesh2
Date: 7 Dec 2013 13:24:03
Message: <52a367c3$1@news.povray.org>
Not quite --- it needs this patch:
diff --git a/source/backend/parser/parse.cpp
b/source/backend/parser/parse.cpp
index 7268519..5671853 100644
--- a/source/backend/parser/parse.cpp
+++ b/source/backend/parser/parse.cpp
@@ -4123,7 +4123,6 @@ ObjectPtr Parser::Parse_Mesh2()
                        Parse_End();
-                       EXIT
                END_CASE
                OTHERWISE
Here is a non-working example which this patch makes work:
mesh2
	texture_list
		2,
		texture { pigment { rgb <1, 0, 0> } }
		texture { pigment { rgb <0, 1, 0> } }
	vertex_vectors {
		8,
		<-2719.2913915965546039, -893.33239410140299697, -767.54170874189844653>,
		<-2718.0920180748885286, -892.13302057973692172, 1237.4785220361964093>,
		<-2721.7475964839522931, 1115.3434150857556233, 1241.1341004452601737>,
		<-711.99363163820544287, 1113.9653658569463914, 1239.7560512164509419>,
		<-713.22223976959799074, -893.18194162859867902, 1238.527443085058394>,
		<-712.90481070357554927, -893.49937069462112049, -767.70868533511657006>,
		<-713.65531061695128301, 1112.3036868782005513, -766.95818542174083632>,
		<-2718.5600943257700237, 1112.155912927573354, -766.81041147111363898>
	face_indices {
		12,
		<0, 1, 2>, 1, 0, 1,
		<3, 4, 5>, 1, 1, 1,
		<5, 6, 3>, 1, 1, 1,
		<3, 2, 1>, 1, 1, 0,
		<1, 4, 3>, 0, 1, 1,
		<6, 5, 0>, 1, 1, 1,
		<0, 7, 6>, 1, 1, 1,
		<2, 3, 6>, 1, 1, 1,
		<6, 7, 2>, 1, 1, 1,
		<1, 0, 5>, 0, 1, 1,
		<5, 4, 1>, 1, 1, 0,
		<2, 7, 0>, 1, 1, 1
	inside_vector CameraSky
	translate <1716.181589446674252, -109.77740804847752543,
-235.56809340798210428>
│ Flon's Axiom
Date: 7 Dec 2013 14:45:56
Message: <52a37af4$1@news.povray.org>
On 07/12/13 18:24, David Given wrote:
> 	face_indices {
> 		12,
> 		<0, 1, 2>, 1, 0, 1,
Arrgh --- I hadn't twigged that the texture values here are *integers*
--- indices into the texture list. Interpolation isn't done if you
supply a fractional value.
So instead I've wedged my texture values into the u channel of the uv
mapping, and am then doing this:
	object
		mesh2
			#include "/tmp/mesh.inc"
		scale km
		uv_mapping texture
			gradient x
			texture_map
				[0.0 pigment { rgb <1, 0, 0> }]
				[1.0 pigment { rgb <0, 1, 0> }]
Simple, easy, effective, and doesn't need face_indices at all.
In fact this has shown up a fundamental flaw in my logic, which is that
by using a simple linear range of textures like this I can't interpolate
from texture #0 to texture #10 without going through all the textures in
between, which would look a bit odd. So I'm going to have to rethink my
reasoning from the ground up.
│ Flon's Axiom
Date: 7 Dec 2013 15:02:48
Message: <52a37ee8$1@news.povray.org>
Am 07.12.2013 19:24, schrieb David Given:
>                          Parse_End();
> -                       EXIT
>                  END_CASE
>                  OTHERWISE
Dang, you're bloody well right.
Date: 8 Dec 2013 07:11:54
Message: <52a4620a@news.povray.org>
>>                          Parse_End();
>> -                       EXIT
>>                  END_CASE
>>                  OTHERWISE
LOL ... so now you're going to change source to match docs ... right?
Date: 8 Dec 2013 09:12:28
Message: <52a47e4c$1@news.povray.org>
Am 08.12.2013 13:11, schrieb James Holsenback:
>>>                          Parse_End();
>>> -                       EXIT
>>>                  END_CASE
>>>                  OTHERWISE
I guess so. A bit of flexibility in the syntax doesn't hurt.
Date: 9 Dec 2013 07:41:45
Message: <52a5ba89$1@news.povray.org>
>>> variable.
should I roll back this change?
