POV-Ray : Newsgroups : povray.general : 2-pass radiosity settings under 3.7 RC3 Server Time
30 Jun 2026 11:45:59 EDT (-0400)
  2-pass radiosity settings under 3.7 RC3 (Message 1 to 8 of 8)
Subject: 2-pass radiosity settings under 3.7 RC3
Date: 27 Sep 2011 10:19:52
Message: <4e81db88@news.povray.org>
It has been a long time since I used the 2-pass method, and not yet with
3.7, so what are the best settings nowadays? For my latest image  I have
added a media, so 2-pass render becomes necessary I guess. At this
moment and based on much earlier code, I use this, which is certainly
not the most efficient I guess:
//start code
     radiosity {
       #if (RadSave)
         pretrace_start 0.08
         pretrace_end   0.004
         count 50, 1000
         error_bound 0.5
         always_sample on
       #else
         pretrace_start 1
         pretrace_end   1
         count 50, 100
         error_bound 1
         always_sample off
       #end  //of RadSave
       brightness 1
       recursion_limit 2
       nearest_count 10, 5
       adc_bailout 0.01/2
       low_error_factor .3
       minimum_reuse 0.015
       maximum_reuse 0.1
       gray_threshold 0.0
       normal on
       media off
       //max_sample 1.0
//end code
During first pass, I switch off area light and any transparent textures.
Can I switch off the media too? I don't remember about that.
Subject: Re: 2-pass radiosity settings under 3.7 RC3
Date: 27 Sep 2011 16:46:11
Message: <4e823613@news.povray.org>
> //start code
> radiosity {
> #if (RadSave)
> pretrace_start 0.08
> pretrace_end 0.004
> count 50, 1000
> error_bound 0.5
> always_sample on
> #else
> pretrace_start 1
> pretrace_end 1
> count 50, 100
> error_bound 1
> always_sample off
> #end //of RadSave
> brightness 1
> recursion_limit 2
> nearest_count 10, 5
> adc_bailout 0.01/2
> low_error_factor .3
> minimum_reuse 0.015
> maximum_reuse 0.1
> gray_threshold 0.0
> normal on
> media off
> //max_sample 1.0
> //end code
> Thomas
An absorbing or scattering media does cast shadows. Emissive media
illuminate it's surounding. It's not neutral. Same thing for any fog,
it's not neutral.
If you use non-neutral media, you NEED media on in at least the first
pass, preferably in both.
You can remove emissive media if you never use media on.
If you turn off your media for the first pass and use it for the second
pass, then you realy need to do some pretrace steps in your second pass,
and need to keep the same error_bound.
Don't switch off transparent textures unless they are totaly, or close
to be, transparent, colourless (rgbt 1 or rgbf 1) and the object don't
have any ior.
count should be the same for both passes.
Date: 27 Sep 2011 17:55:01
Message: <web.4e8245ae4a39fb5a85de7b680@news.povray.org>
Thomas de Groot <tenDOTlnDOTretniATtoorgedDOTt> wrote:
>      radiosity {
>        #if (RadSave)
>          pretrace_start 0.08
>          pretrace_end   0.004
>          count 50, 1000
>          error_bound 0.5
>          always_sample on
In his Radiosity Voodoo articles (povray.text.tutorials), clipka recommends
setting always_sample to off.
>        #else
>          pretrace_start 1
>          pretrace_end   1
>          count 50, 100
>          error_bound 1
In 3.6, error_bound should be the same for both passes, otherwise the 2nd pass
would take eons.  I haven't tested this in 3.7.
>          always_sample off
>        #end  //of RadSave
>        brightness 1
>        recursion_limit 2
>        nearest_count 10, 5
In his Radiosity Voodoo articles, clipka recommends setting nearest_count to 1,
especially during the final render.  However, the current documentation suggests
that this would have poor results.  Although I can't recall the details, I
remember that I didn't get satisfactory results by tweaking this.
>        adc_bailout 0.01/2
>        low_error_factor .3
>        minimum_reuse 0.015
>        maximum_reuse 0.1
>        gray_threshold 0.0
>        normal on
>        media off
>        //max_sample 1.0
Date: 28 Sep 2011 00:37:45
Message: <4e82a499$1@news.povray.org>
Am 27.09.2011 23:52, schrieb Cousin Ricky:
> Thomas de Groot<tenDOTlnDOTretniATtoorgedDOTt>  wrote:
>>       radiosity {
>>         #if (RadSave)
>>           pretrace_start 0.08
>>           pretrace_end   0.004
>>           count 50, 1000
>>           error_bound 0.5
>>           always_sample on
Those recommendations are for using radiosity in a single render. When
using a simplified scene to generate & save radiosity data, to be loaded
& used later in a separate render, "always_sample on" is ok; the
pre-render's main phase is likely to suffer artifacts, but it is
discarded anyway, and this way it's still good for something (namely to
serve as yet another radiosity pretrace step).
>>         #else
>>           pretrace_start 1
>>           pretrace_end   1
>>           count 50, 100
>>           error_bound 1
It shouldn't be set /lower/ than in the first pass, but a higher value
should be ok. Some care is recommended though: Increasing error_bound
also increases the risk of light "leaking" through walls in corners.
>>           always_sample off
>>         #end  //of RadSave
>>         brightness 1
>>         recursion_limit 2
>>         nearest_count 10, 5
I'm not so sure about this recommendation any longer. For the main pass
in a 2-pass approach it doesn't actually matter much: In the main pass
pretrace, a pretrace_start and pretrace_end setting of 1 will make sure
that at most one single additional sample will be taken (if any
pretracing is done at all; I'm not perfectly sure about that right now),
which doesn't make much of a difference; and with always_sample off the
nearest_count setting is irrelevant during the render proper anyway.
Date: 28 Sep 2011 03:42:58
Message: <4e82d002$1@news.povray.org>
Thanks guys! Basically I seem to be on the right track then. Also
putting aa off in the first pass helps of course.
I was aware of Clipka's Voodoo, but was not sure about its use with a
2-pass render.
Date: 28 Sep 2011 04:24:56
Message: <4e82d9d8$1@news.povray.org>
> textures. Can I switch off the media too? I don't remember about
> that.
   I would, for sure. I also make simplified versions of complex textures
wich render slow (heavily layered ones, for example).
Jaime
Date: 28 Sep 2011 07:11:14
Message: <4e8300d2$1@news.povray.org>
>> that.
With what Alain says about scattering media, we could also use a very
low sample value during first pass and a high one during second pass,
couldn't we?
Date: 28 Sep 2011 13:59:53
Message: <4e836099@news.povray.org>
>>> that.
> couldn't we?
> Thomas
A low sample value for the media will miss most fine details, but, it's
OK as the shadow will be difuse and effectively hide the fine details.
samples 3 to 5 should be correct for the first pass. It defaults to 10,
and you may need more than 100 for the final render.
