POV-Ray : Newsgroups : povray.general : Patch objects not allowed in intersection. Server Time
11 Apr 2026 01:54:00 EDT (-0400)
  Patch objects not allowed in intersection. (Message 1 to 9 of 9)
Subject: Patch objects not allowed in intersection.
Date: 10 Dec 2010 05:16:12
Message: <4d01fdec$1@news.povray.org>
PovRay gives a warning when Patch objects are used in a Difference or
Intersection. (Ver 3.6 & 3.7)
Parse Warning: Patch objects not allowed in intersection.
3.4.2  Finite Patch Primitives
There are six totally thin, finite objects which have no well-defined
inside. They are bicubic patch, disc, smooth triangle, triangle, polygon
and mesh / mesh2. They may be combined in CSG union but cannot be used
in other types of CSG (or inside a clipped_by statement).
except for differencing a patch from a primitive when the use of the
inverse keyword in the CSG helps.
relevant?
Regards
Subject: Re: Patch objects not allowed in intersection.
Date: 10 Dec 2010 05:23:31
Message: <4d01ffa2@news.povray.org>
> I???ve found that all four operations work well with the Bicubic_Patch,
  I don't understand how it could work ok with a bicubic patch, because
a bicubic patch has no well-defined interior.
  (Meshes don't have one either, by default, but an interior calculation
for closed meshes can be turned on with the 'inside_vector' feature.
IIRC discs work like planes in that they divide the space into two parts:
the outside and the inside. However, because the visible surface does not
cover the entire partition, they will cause odd behavior when used in CSG.)
Date: 10 Dec 2010 06:13:54
Message: <4d020b72@news.povray.org>
That is my understanding too but I did a couple of tests before posting.
In the cases I tried it gave me the results I expected. (Assuming that a
patch can be used in a difference or intersection.)
That is true, discs do cause odd behavior when used in CSG.
Regards
Date: 10 Dec 2010 11:27:21
Message: <4d0254e9$1@news.povray.org>
>> CSG.)
You may difference FROM a patch. It will only cut the parts of the patch
that are not inside the solid object.
An intersection should give the same result: Only the part of the patch
that intersects the solid object if the patch is the first object.
The message is mostly a warning as the result may not be what you expect.
Date: 11 Dec 2010 09:01:37
Message: <4d038441$1@news.povray.org>
I think that Jim H should update the documentation. If he has nothing
else to do. :-P
Maybe the warning should say something like:
Regards
Date: 11 Dec 2010 12:31:39
Message: <4d03b57b$1@news.povray.org>
howz zat ...
http://wiki.povray.org/content/Documentation:Reference_Section_4.1#Finite_Patch_Primitives
Date: 11 Dec 2010 13:21:40
Message: <4d03c134$1@news.povray.org>
> howz zat ...
That was quick, Jim. :-D
I actually thought that, that message should be the Pov-Ray warning.
What I think the documentation should say is along the lines of.
Solids may be differenced from bicubic patches with the output giving
the expected results. That is the solid object cuts a hole in the patch.
Differencing a bicubic patch from a solid may give unexpected results,
especially if the inverse keyword is used.
Intersecting a solid and a bicubic patch will give the expected results.
That is the parts of the patch that intersect the solid object will be
visible.
Merging a solid and a bicubic patch will remove the parts of the bicubic
patch that intersect the solid.
<end>
It is a bit wordy and could use some sub-editing.
Regards
Date: 11 Dec 2010 14:33:56
Message: <4d03d224$1@news.povray.org>
more better?
Date: 11 Dec 2010 15:55:33
Message: <4d03e545$1@news.povray.org>
> more better?
Much more gooder, actualy :-)
I just hope I'm right. :lol:
Regards
