POV-Ray : Newsgroups : povray.general : Can you use the trace command on a heightfield? Server Time
28 Sep 2024 09:16:34 EDT (-0400)
  Can you use the trace command on a heightfield? (Message 1 to 10 of 23)
Subject: Can you use the trace command on a heightfield?
Date: 7 Apr 2010 21:20:25
Message: <4bbd2f59$1@news.povray.org>
Hi, as the title states, can you use the trace command on a heightfield?
I've been trying and trying and I cant get it to work.  I've successfully
used the trace() command on isosurfaces and simple boxes, spheres but I cant
for the life of me get this to work.
Just wondering if this actually does work or I'm barking up the wrong tree!
Cheers Dre
Subject: Re: Can you use the trace command on a heightfield?
Date: 7 Apr 2010 23:42:56
Message: <4bbd50c0@news.povray.org>
"Dre" <and### [at] gmailcom> wrote in message
news:4bbd2f59$1@news.povray.org...
> cant for the life of me get this to work.
> tree!
> Cheers Dre
Date: 7 Apr 2010 23:46:05
Message: <4bbd517d$1@news.povray.org>
> tree!
> Cheers Dre
Nevermind, I worked it out, that trace command has some weirdness about it.
This doesn't work:
#declare norm = <0, 0, 0>;
trace(object, <xPos, 10, zPos>, <xPos, -10, zPos>, norm>)
Yet this does:
#declare startPoint =<xPos, 10, zPos>;
#declare endPoint = <xPos, -10, zPos>;
trace(object, startPoint, endPoint, norm)
Unless I'm doing something wrong, that seems broken to me...
Version 3.6 btw.
Cheers Dre
Date: 8 Apr 2010 03:18:02
Message: <4bbd832a$1@news.povray.org>
"Dre" <and### [at] gmailcom> schreef in bericht
news:4bbd517d$1@news.povray.org...
>> tree!
>> Cheers Dre
> it.
> This doesn't work:
> Yet this does:
No, trace() is not broken. The following always works for me, with whatever
object as target:
    #declare Norm =  <0, 0, 0>;
    #declare Start = <my.x, 10, my.z>;
    #declare Pos = trace (Obj, Start, -y, Norm);
Start must be above the object, so adapt the y value; -y indicates the
direction of tracing.
Date: 8 Apr 2010 05:20:54
Message: <4bbd9ff6$1@news.povray.org>
Am 08.04.2010 05:46, schrieb Dre:
How does the failure-to-work manifest itself? Are we talking e.g. about
a parser error?
> This doesn't work:
> #declare norm =<0, 0, 0>;
> trace(object,<xPos, 10, zPos>,<xPos, -10, zPos>, norm>)
> Yet this does:
> #declare endPoint =<xPos, -10, zPos>;
Well, unless you introduced a typo when writing this posting, I'm not at
all surprised: In the non-working example, you have an extra ">" after
"norm". I'm not sure what the parser makes of this, but most likely not
what you expected.
Date: 8 Apr 2010 05:28:30
Message: <4bbda1be@news.povray.org>
Dre <and### [at] gmailcom> wrote:
> Yet this does:
  I don't think it does (well, not in the way you want). The third parameter
of trace() specifies a direction, not an endpoint.
  Probably you want the third parameter to be <0, -1, 0> because that's
the direction you are shooting the rays towards.
Date: 8 Apr 2010 18:39:44
Message: <4bbe5b30@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4bbd9ff6$1@news.povray.org...
>>> successfully
> How does the failure-to-work manifest itself? Are we talking e.g. about a
> parser error?
No it parses correctly, however none of the intersections are correct, they
are all either at <0, 0, 0> or some weird location.
>> This doesn't work:
>> Yet this does:
> what you expected.
Ooops!  Yes that extra bracket is a typo, sorry.
I just find it weird that it accepts the same vectors as variables, but not
as the actual vector itself...
Cheers Dre
Date: 8 Apr 2010 18:40:49
Message: <4bbe5b71$1@news.povray.org>
"Thomas de Groot" <tDOTdegroot@interDOTnlANOTHERDOTnet> wrote in message
news:4bbd832a$1@news.povray.org...
>>> successfully used the trace() command on isosurfaces and simple boxes,
>>> spheres but I cant for the life of me get this to work.
>>> tree!
>>> Cheers Dre
>> it.
>> This doesn't work:
>> Yet this does:
> whatever object as target:
> Thomas
Yes that format works for me too, now try your example without the
variables, put the actual vectors in your Pos declaration and see if you get
the same results.  I dont.
Cheers Dre
Date: 8 Apr 2010 18:48:17
Message: <4bbe5d31$1@news.povray.org>
news:4bbda1be@news.povray.org...
>> Yet this does:
> parameter
>                                                          - Warp
Well it does to what I want now that I changed the way I coded it to the
example above.  I then modified the norm as you stated but it didn't make
any difference at all.  Both my norm and yours are below my start point so
they are essentially shooting the rays in the same direction.
Cheers Dre
Date: 9 Apr 2010 01:48:32
Message: <4bbebfaf@news.povray.org>
> >> Yet this does:
> > parameter
> >                                                          - Warp
  The normal is the *fourth* parameter. I was talking about the *third*
parameter, which is the direction. That should be <0, -1, 0>.
