POV-Ray : Newsgroups : povray.general : Increasing calculation depth with the mandel pattern? Server Time
22 Dec 2025 02:04:26 EST (-0500)
  Increasing calculation depth with the mandel pattern? (Message 1 to 10 of 12)
Subject: Increasing calculation depth with the mandel pattern?
Date: 17 Mar 2010 21:35:49
Message: <4ba18375@news.povray.org>
High!
Inspired by my loved one who is a true fractal aficionado (he also wrote
his own fractal generation tool, using QBasic!), I reactivated an old
mandelbrot zoom script from 2001 (back then using POV-Ray 3.1). But
otherwise than stated in the manual, the calculation ends not at a 10^33
magnification, but merely at about 10^14, the pattern starts to look
"blocky".
Is it possible to increase this calculation depth without hacking
POV-Ray's source code? If not, would it be legal according to the POV
license to do so?
See you in Khyberspace!
Yadgar
Subject: Re: Increasing calculation depth with the mandel pattern?
Date: 18 Mar 2010 10:44:28
Message: <4ba23c4c@news.povray.org>
> But
> "blocky".
  A double-precision floating point value has a 53-bits wide mantissa, which
is able to represent approximately 15 significant digits of accuracy. Thus
the limit you are seeing.
  No. The accuracy of a double-precision floating point number is fixed in
hardware.
> If not, would it be legal according to the POV license to do so?
  You can do whatever modifications you want to it. It's publication which
has its limits.
  Note, however, that you won't be able to increase the accuracy unless you
use a multiple-precision floating point library which calculates the values
in software and will inevitably be extremely slow.
Date: 18 Mar 2010 18:06:19
Message: <4ba2a3db$1@news.povray.org>
Out of curiosity, while I often see "no, arbitrary-precision floats
won't be done in POV ever because they're way too slow", it's never
really indicated just how slow this would be.  Slower than hardware, to
be sure, but that's not much to go on.  Current *single* CPUs can do in
seconds what took hours or days fifteen years ago...in software.
I, for one, would be interested in seeing hard number comparisons.
Tim Cook
http://empyrean.freesitespace.net
Date: 18 Mar 2010 19:13:33
Message: <4ba2b39d@news.povray.org>
  I have first-hand experience. My FunctionParser library currently supports
many floating point and integer types as its basic data type. Among others,
it supports 'double' (which is a 64-bit floating point type which has a 53-bit
mantissa calculated in hardware, and the same that POV-Ray uses for most of
its calculations) as well as multiple-precision software floating point
numbers using the MPFR library.
  I have a comprehensive regression testbed program which runs over a hundred
tests on the library. It can run it with all the supported data types or
with just one. It uses 80 mantissa bits for the MPFR floating point values
(which is about 24 significant digits of accuracy, compared to the about 15
of double-precision floating point numbers; not much larger, but the speed
of the MPFR library decreases as more mantissa bits are used).
  Running all the current tests for the 'double' in my computer type takes
about 1.7 seconds, while running the same tests for the 80-bits-mantissa
MPFR type takes about 5 minutes.
  (Of course this tests many mathematical functions which wouldn't be
necessary to calculate the Mandelbrot set, which only requires additions
and multiplications, and the difference in speed would most probably not
be as drastic with those, but it gives a good idea of the overall difference
in speed when a wide range of mathematical functions and operations is used.)
Date: 18 Mar 2010 19:28:52
Message: <4ba2b734$1@news.povray.org>
Not sure if this is delving into the same direction as those GPU-POV
threads, but is there an effective way to split off and only use the
arbitrary-precision math when it falls outside the hardware capability?
Tim Cook
Date: 18 Mar 2010 19:45:09
Message: <4ba2bb05@news.povray.org>
  How do you tell when to "split off"?
  For example, how many mantissa bits are necessary to "accurately" depict
the number 0.1? (Note that 0.1 cannot be represented accurately by any
amount of mantissa bits, similarly to how 1/3 cannot be represented by
any amount of decimals in base-10 representation.)
Date: 18 Mar 2010 19:53:21
Message: <4ba2bcf1@news.povray.org>
Hmm...have a render argument flag as to whether to use
arbitrary-precision or not?
Tim Cook
Date: 18 Mar 2010 20:31:38
Message: <4ba2c5ea@news.povray.org>
  In order for the double-version not to suffer any speed overhead, you
would basically have to have two different versions of POV-Ray, one using
double and the other using multiple-precision floating point. So you could
just as well have to separate binaries. No need for a flag.
Date: 6 Apr 2010 21:10:00
Message: <web.4bbbda4acfdfbfd634d207310@news.povray.org>
The algorithm in povray arbitrarily shuts down with an iterations above 32767.
It could let you go to higher resolution with higher counts; it seems an
abritary choice.
Date: 7 Apr 2010 07:27:07
Message: <4bbc6c0b@news.povray.org>
> abritary choice.
  That doesn't affect the artifacts you get when you zoom beyond the
accuracy of double-precision floating point numbers.
