POV-Ray : Newsgroups : povray.general : PovRay limits (PovTree question) Server Time
28 Jan 2026 14:46:41 EST (-0500)
  PovRay limits (PovTree question) (Message 1 to 3 of 3)
Subject: PovRay limits (PovTree question)
Date: 18 Dec 2009 10:57:54
Message: <4b2ba682$1@news.povray.org>
If I generate a tree using PovTree I usually get very large files. Then I
plant trees (a lot of them) to achieve a wood. The more trees, the longer it
takes to compute, which is self-evident and not the point of the question.
My questions now, in the hope that some guru may enlighten this unworthy
disciple ;-)
How do I determine the maximum number of trees I can use in a PovRay scene?
Or better put: what are the limitations of objects in PovRay?
Is it better to use one tree and just modify size, orientation and rotation
or could I use multiple different trees (different outputs from PovTree)?
Or, more generally, does PovRay put an object like a tree in some kind of
cache and uses this one object to compute the thousand scaled, rotated and
translated clones?
What is the maximum number of different PovTrees you used in a scene (really
complex trees or other objects)?
Subject: Re: PovRay limits (PovTree question)
Date: 18 Dec 2009 11:38:22
Message: <4b2baffe@news.povray.org>
  Your RAM will probably become a limit sooner than the amount of possible
objects.
  If the tree is a #declared triangle mesh, then instantiating (with the
'object' keyword) is going to save memory because the triangle data will
be stored in memory only once. For other objects this is not the case.
Subject: Mesh vs. SDL
Date: 18 Dec 2009 13:07:22
Message: <4b2bc4da$1@news.povray.org>
Thank you, Warp. This is exactly the answer I was looking for.
In terms of processing speed, are there advantages to SDL over meshes?
I once built a wall out of bevelled stones (take one box for the stone, use
difference of 8 rotated boxes to bevel the edges). Then I wrote a macro to
build a wall out of these boxes, by putting one above the other like a mason
would do. Would it have been smarter to use a mesh for the bevelled stones?
