POV-Ray : Newsgroups : povray.general : Bell curves Server Time
28 Sep 2024 15:12:29 EDT (-0400)
  Bell curves (Message 1 to 10 of 11)
Subject: Bell curves
Date: 31 Aug 2009 17:22:38
Message: <4a9c3f1e$1@news.povray.org>
I would like to create a function for a heightfield that has a nice bell
curve shape, but can also be normalized between 0 and 1 along each axis.
I've looked at the normal distribution and beta distribution functions,
but they can only be normalized along one axis.
The sine wave can be normalized, but it is not "fat" enough (i.e. I
would like the peak to be wider than the trough). What other options are
there?
-Mike
Subject: Re: Bell curves
Date: 31 Aug 2009 17:59:55
Message: <4a9c47db$1@news.povray.org>
SharkD writes :
l
e
> there?
t in [0,2*Pi], y in ]-1,1[ then bell curve is
	"cos^2(t)+sin^2(t)=(4+ath(-y))^2"
ath() is hyperbolic arctangent means inverse of hyperbolic tangent th().
Does it suits you ?
Author of Eureka 2.12 (2D Graph Describer, 3D Modeller)
http://eureka.atari.org/
http://fon.gs/eureka/
Date: 31 Aug 2009 19:05:42
Message: <4a9c5746$1@news.povray.org>
> Does it suits you ?
> Regards,
Is this a correct transformation?
0 = tanh(sqrt(cos(t)^2 + sin(t)^2) - 4) + y
Date: 31 Aug 2009 19:08:23
Message: <4a9c57e7$1@news.povray.org>
I figured out how to normalize the beta distribution, but the formula
involves and integral and I don't know how to do that in POV.
-Mike
Date: 31 Aug 2009 21:55:01
Message: <web.4a9c7e1a687fa7e9958421d50@news.povray.org>
I don't know quite what you mean by normalizing a two-dimensional function along
one axis.  You can normalize the maximum of the function to 1.  You can
normalize the volume under the whole surface to one.  You can also normalize
the area under a cross-section, but which quantity do you want to normalize
along different axes?  What part of
exp(-((x/sigma_x)^2 + (y/sigma_y)^2) / 2)
makes it unsuitable for the purpose?  Please don't interpret the question
negatively; I just really don't understand the question.
 - Ricky
Date: 1 Sep 2009 07:27:48
Message: <4a9d0534$1@news.povray.org>
SharkD writes :
> Francois LE COAT writes :
>> Does it suits you ?
y = th( 4 - sqrt(x^2 + z^2) ) with x in [-8,8] and z in [-8,8]
That's correct, it looks like :-)
Date: 1 Sep 2009 14:11:31
Message: <4a9d63d3@news.povray.org>
> Hi,
> SharkD writes :
>> bell curve shape, but can also be normalized between 0 and 1 along
>> each axis. I've looked at the normal distribution and beta
>> distribution functions, but they can only be normalized along one axis
>> are there?
	You do know that "cos^2(t)+sin^2(t)" is 1 for all t do you?
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 1 Sep 2009 14:29:11
Message: <4a9d67f7$1@news.povray.org>
Please read the following reply. It's a mistake. You should
replace the formula with "x^2+y^2" like in the final equation.
The bell curve surface y=f(x,z) is described correctly.
Thanks,
Date: 1 Sep 2009 14:55:00
Message: <web.4a9d6d9b687fa7e9958421d50@news.povray.org>
Oh.  It took me a bit to realize what you meant, but why not just
exp(-x*x-y*y) * (x-1) * (x+1) * (y-1) * (y+1)
This just clamps the edges to zero while keeping the center at 1.  Still 'looks'
gaussian.
 - Ricky
Date: 1 Sep 2009 18:29:46
Message: <4a9da05a@news.povray.org>
> gaussian.
>  - Ricky
I ended up using this function:
#local BetaA = 3;
#local BetaB = 3;
#local ThingX = ((BetaA - 1) / (BetaB - 1 + BetaA - 1) - 1/2) * 2;
#local ThingY = pow(ThingX/2 + 1/2, BetaA - 1) * pow(1 - (ThingX/2 +
1/2), BetaB - 1);
function {pow(f_r(x,y,z)/2 + 1/2, BetaA - 1) * pow(1 - (f_r(x,y,z)/2 +
1/2), BetaB - 1) / ThingY}
It's basically the same as the beta distribution function, minus the
exponent (or beta function). I realized it was not necessary.
-Mike
