POV-Ray : Newsgroups : povray.general : Blurred light reflections Server Time
30 Jul 2024 16:22:25 EDT (-0400)
  Blurred light reflections (Message 1 to 4 of 4)
Subject: Blurred light reflections
Date: 4 Dec 2008 16:25:00
Message: <web.49384a32bd724263b246acf00@news.povray.org>
I'm trying to recreate this awesome scene:
http://darkaan.deviantart.com/art/Light-Balls-v-2-1680x1050-67946500
Any ideas on how to reproduce the blurred light relections / (phongs?) without
taking years to render would be appreciated.
I've modelled with a light source within each ball, but this is highly
processor-intensive, prob due to the large number of light sources.  Is there
any other way to acheive the effect?
Thanks,
Robin
Subject: Re: Blurred light reflections
Date: 4 Dec 2008 17:20:01
Message: <web.4938569e47efc89ff5dae140@news.povray.org>
From what I see, this is actually not a reflection, but a radiosity effect (or
similar, but radiosity should do the job). So use a texture map to equip your
spheres with those alternating bands of reflecting and white texture; for the
white bands, use a white pigment (what else :)) and set its ambient to 1 and
diffuse to 0. Be sure to set all other textures' ambient to 0 so they don't
emit light. Set the plane's diffuse to something > 0. Make sure you have an
ambient_lighting of 1, insert a radiosity block in your global settings, press
"Run", and and voila - happy rendering!
You won't need any conventional light sources at all.
Date: 4 Dec 2008 23:20:01
Message: <web.4938aaec47efc89fdef618250@news.povray.org>
As already said, it's radiosity.  In the case of this scene, radiosity is not
really the main CPU cruncher -- it calculates just fine and in a few minutes,
even in a modest machine as mine.  It's the reflections and focal blur that
really bring it to a crawl.  I wonder which software did the guy use and how
much time it took to render at that size with that quality... it's certainly
raytraced spheres...
Very nice scene.  It inspired me to try to reproduce it, though not quite there
yet -- I should probably better adjust the aperture and blur_samples as well as
trying perhaps some fresnel reflection and a better sphere distribution scheme.
If anyone is feeling courageous to try to match the scene, here's a start,
though I suggest you turn FOCAL_BLUR off first -- took 13 minutes a subpar
640x480 rendering on a P4 2.66:
http://img116.imageshack.us/img116/5341/blackspheresel2.png
code:
#local GI = on;
#local FOCAL_BLUR = on;
#local REFLECTIONS = on;
union {
plane { y, -1 pigment { rgb <.8,.8,1>/3 } finish { diffuse .56 ambient 0 } }
#local sph =
sphere { 0 1
  pigment { rgb <.8,.8,1> }
  finish { diffuse 0 ambient 3 }
 } texture {
  pigment { marble rotate z*90
   color_map { [0 rgb z/2][.7 rgb z/2][.75 rgbt 1][1 rgbt 1]} }
  finish { diffuse .6 ambient 0
   #if (REFLECTIONS) reflection .9 metallic .2 #end
//object { sph }
#local much = 17;
#local i = much; #while (i>-much)
object { sph rotate <30*i*i,40*i> translate 3*x*i+15*z*cos(30+i*30) }
#declare i = i-1; #end
 rotate -y*65
 rotate -x*3.5
 //translate z*12-x*2
 translate z*28-x*0
#if (!GI)
light_source { -z*5 1 }
global_settings {
 #if (GI)
 radiosity {
  brightness 2
  count 180
  gray_threshold .5
  error_bound .28
  pretrace_end .006
camera { angle 30
#if (FOCAL_BLUR)
 focal_point z*8.5-y*1+x aperture .06 blur_samples 50*5 confidence .98
Date: 9 Dec 2008 15:09:09
Message: <493ed065@news.povray.org>
robinmckenzie nous illumina en ce 2008-12-04 16:22 -->
> Thanks,
> Robin
When you create a scene that use several objects with blured reflection that can
reflect each other, you must be carefull.
You don't want to reflect a blured reflection from another blured reflection.
What to do?
Have each objects in double. One with only normal reflection and no_image, the
other with the blured reflection and no_reflection.
Whenever you directly see an object, you will see the one with the blured
reflection. Whenever you see the object in a reflection, you'll see the one with
the normal reflection.
But, the image you linked to, don't use blured reflection. It's a radiosity
scene. The bright parts glow by themselve using high ambient with a slightly
bluish pigment. The floor is a plain white plane. There are NO regular light_source.
   My wife's such a bad cook, the dog begs for Alka-Seltzer.
   	Rodney Dangerfield
