POV-Ray : Newsgroups : povray.general : POV-ray (text) editor for beginners Server Time
30 Jul 2024 18:20:32 EDT (-0400)
  POV-ray (text) editor for beginners (Message 1 to 10 of 26)
Subject: POV-ray (text) editor for beginners
Date: 13 Nov 2008 20:12:24
Message: <491cd078@news.povray.org>
Hi, every night before going to bed I teach a little bit of POV-ray to
my wife.
The most annoying problem is that everytime she wants to see the scene
she has to save, go to the shell, issue the povray command with some
(for her) cryptic options and then open up an image viewer (or
imagemagick's "display") to see the result. For an animation, it's even
more complicated.
Because my target here is not teach her how to script in bash but how to
write scenes in POV-ray, I would feel much better if there was an
"integrated" editor for POV-ray with buttons to select options and start
rendering.
Any suggestion? PS I do *not* want a CAD-like or "visual" editor...
bye
as
Subject: Re: POV-ray (text) editor for beginners
Date: 13 Nov 2008 20:30:01
Message: <web.491cd42e34cbc438849303c80@news.povray.org>
> my wife.
> more complicated.
> rendering.
> bye
> as
Are you using Windows?
-Mike
Date: 13 Nov 2008 22:47:00
Message: <491cf4b4$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.491cd42e34cbc438849303c80@news.povray.org...
>> my wife.
>> more complicated.
>> rendering.
>> bye
>> as
> -Mike
From the BASH comment I assume he's in Linux of some sort.
You could try the windows version under Wine, I'm not sure
but it probably would work.
There's also POVclipse... that's a POV syntax version of Eclipse,
you could give that a try.
Date: 14 Nov 2008 02:38:40
Message: <491d2b00@news.povray.org>
Hash: SHA1
> my wife.
> more complicated.
> rendering.
> bye
> as
	You might want to try XPE: http://nextpe.sourceforge.net/
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkkdK0IACgkQd0kWM4JG3k8SfgCfQlzkkemJVEG8pyoy5N0fOntq
a6oAmwVXFPzjZHls2fzl6OqFoQvFwQht
=0BAg
-----END PGP SIGNATURE-----
Date: 14 Nov 2008 10:38:49
Message: <491d9b89@news.povray.org>
  It doesn't have to be so complicated. When I edit a povray file and want
to make a test render of it, it happens like:
- Save by pressing the saving shortcut key in the text editor.
- Alt+tab to switch to the terminal where I have been running povray.
- Up+enter (assuming I have already run povray in that terminal).
  That's it. POV-Ray shows the rendered image on an X window while it
renders it. When it's done (or I want to interrupt it), I:
- Press q to stop povray.
- Alt+tab to get back to the editor.
  If your version of povray doesn't display the image it's rendering,
you should get one which does.
Date: 14 Nov 2008 10:46:29
Message: <491d9d55$1@news.povray.org>
It's not even complicated with emacs (at least in linux).  If I have a shell window
running tcsh and an emacs window, I do:
in emacs window: cntl-S
in shell window (to repeat my last render command): !pov enter  (!p if I've not issued
any other p... commands)
    or "cntl-p" until I reach the last pov command, then enter
Lightning fast.  Well under one second.
The shell can be within an emacs window, if I prefer (which I don't).
That's it.  It's not worth worrying about shortcuts.
Dan
Date: 14 Nov 2008 10:51:26
Message: <491d9e7e$1@news.povray.org>
whoops: cntl-X cntl-S.
My fingers know what to do, anyway.. :)
Date: 14 Nov 2008 11:06:08
Message: <5395A4F713BF447391EFC1410A489558@HomePC>
Isn't there one called KPov or something for KDE?
And I believe SciTE is able to launch POV-Ray directly with a
button-press, and it does great syntax highlighting.  Configure POV to
display the output as it renders.
...Ben Chambers
www.pacificwebguy.com
Date: 14 Nov 2008 11:35:34
Message: <491da8d6$1@news.povray.org>
Dan Connelly escreveu:
An experienced emacs user going bloppers.  Just imagine a novice... :P
Date: 14 Nov 2008 11:39:53
Message: <491da9d9$1@news.povray.org>
Alessio Sangalli escreveu:
> my wife.
Ever heard of bash history?  Up arrow key to access the last command, or
CTRL+R + "word" to search for "word" in the history.  more CTRL+R to see
older entries.
Why not?  Why impose such command line pain to your wife?  Women would
certainly enjoy modelling with curves visually rather than typing like a
geek.
