POV-Ray : Newsgroups : povray.general : location dependant refractive index Server Time
30 Jul 2024 18:23:02 EDT (-0400)
  location dependant refractive index (Message 1 to 10 of 24)
Subject: location dependant refractive index
Date: 31 Oct 2008 10:55:00
Message: <web.490b1bcd2c217504934be4af0@news.povray.org>
hi all,
I want to make an animation about the so-called "mirage effect" on a heated
surface with a sphere present. (what is the mirage effect:
http://www.physlink.com/Education/askExperts/ae428.cfm)
Basicly the effect is created by a difference in refractive indix of a hot and a
cold medium (water). Is it possible in PORAY to create a location dependant
refractive index?
Regards, Ruud
Subject: Re: location dependant refractive index
Date: 31 Oct 2008 15:25:16
Message: <490b5b9c$1@news.povray.org>
feestje wrote:
> hi all,
> refractive index?
> Regards, Ruud
You cannot give an object a variable index of refraction, sorry. But you
*can* stack many transparent objects onto each other, each having a
different ior. It might work for the mirage effect. The render times
using this method are slooow, even on faster computers.
Or you could try modeling a microsphere atmosphere, but this would
render even more slowly, I'm pretty sure.
Sam
Date: 31 Oct 2008 16:23:32
Message: <490b6944$1@news.povray.org>
I've found when stacking translucent objects with internal media, I need to be REALLY
careful about separating surfaces, or I get spotty artifacts.
Dan
Date: 31 Oct 2008 17:31:52
Message: <490b7948$1@news.povray.org>
Dan Connelly wrote:
>> you *can* stack many transparent objects onto each other, each having
>> a different ior. It might work for the mirage effect. The render times
> to be REALLY careful about separating surfaces, or I get spotty artifacts.
Oh no, with media in the equation, the scene might take months to
render! I don't think media is really needed for this effect.
Oh yeah, the poster may want to give the stacked objects no_shadow to
help speed things up somewhat.
Sam
Date: 31 Oct 2008 19:10:25
Message: <490b9061$1@news.povray.org>
stbenge nous illumina en ce 2008-10-31 15:25 -->
> feestje wrote:
>> hi all,
>> heated
>> hot and a
>> dependant
>> refractive index?
>> Regards, Ruud
> Sam
You may not need many stacked objects. Just one or two thin boxes, or strongly
flattened spheres or cylinders, with a clever normal may be enough. Just
remember to keep the ior close to 1.
Start with 1. Do some test renders altering the ior and normal. Then, if needed,
add a second one. Tewak only that added object to adjust as needed. The second
object should have an ior closer to 1 than the first.
'hAS ANYONE SEEN MY cAPSLOCK KEY?'
Date: 2 Nov 2008 07:30:01
Message: <web.490d9c83a1a1577518112fe00@news.povray.org>
hi all,
thank you for your responses! I thought of the stacked box methos myself but I
hoped ther ewould be something much more easier! well anyway: he is what I
accomplished so far:
 #include  "colors.inc"
sphere {   // IOR < 1
     <0,0,0> ,1.5
          color Black
plane{
     < 0, -1, 0>,           2
          color White
     finish {
          ambient 0.7
          diffuse 0.7
             box {
     < -20, -2, 15 >,
     < 20, -1.9,    -15 >
          color White filter 1
     finish {
          phong 1
          refraction 1.0
     interior {
          ior        1.1
                                      box {
     < -20, -1.9, 15 >,
     < 20, -1.8,    -15 >
     finish {
          phong 1
          refraction 1.0
     interior {
          ior        1.2
             box {
     < -20, -1.8, 15 >,
     < 20, -1.7,    -15 >
     finish {
          phong 1
          refraction 1.0
     interior {
          ior        1.3
             box {
     < -20, -1.7, 15 >,
     < 20, -1.6,    -15 >
     finish {
          phong 1
          refraction 1.0
     interior {
          ior        1.4
             box {
     < -20, -1.6, 15 >,
     < 20, -1.5,    -15 >
     finish {
          phong 1
          refraction 1.0
     interior {
          ior        1.5
              box {
     < -20, -1.5, 15 >,
     < 20, 100,    -15 >
     finish {
          phong 1
          refraction 1.0
     interior {
          ior        1.6
                     background {
     color  SkyBlue
     location  -1.5*y - 20*z
     direction 1.3*z
     up        y
     right 4/3*x
     look_at   0*x
light_source {
    20*z
     color White
I know it doesn't look pretty yet! :(I'll keep trying to improve it. especially
the lighting; is there a trick for making a diffuse light source? If someone
has any suggestions I would appriciate it!
Date: 2 Nov 2008 08:25:03
Message: <490daa2f$1@news.povray.org>
feestje wrote:
> hi all,
I'd use a loop for the slices.
Date: 3 Nov 2008 04:25:00
Message: <web.490ec2e3a1a15775934be4af0@news.povray.org>
I dind't know using loops was an option. I will look for a tutorial somewhere
and try it. unless someone wants te show me how to do it offcourse ;)
Date: 3 Nov 2008 07:10:01
Message: <web.490ee8fda1a15775934be4af0@news.povray.org>
I made a version with loop. I believe it will work. only problem i heve is with
the lighting. I want to use a plane that emits light. This is the codeI am
using:
light_source
{ <0,0,0>, 1
  looks_like {
  plane {
     z, 1000
         color White  }
             finish {
          ambient 1 }
it seems the only light production from this code is because of the ambient
statement.
is it even possible to have a plane emit light?
Regards, Ruud
Date: 3 Nov 2008 07:10:02
Message: <web.490ee945a1a15775934be4af0@news.povray.org>
btw: the entire code is:
global_settings { max_trace_level 100 }
object {
 sphere { <0,0,0>,10 }
  color  Black
 finish {
  phong 1
  phong_size 10
#declare Index = 1;
#declare Indexmax=20;
#declare lower_ior = 1;
#declare upper_ior = 2;
#declare hight_boundarylayer = 7;
#declare surface=15;
#while(Index <= Indexmax)
// hotter medium
box {
     < -50,(-surface+(Index-1)*hight_boundarylayer/Indexmax) , -20 >,    //
lower-left corner
     <  50, (-surface+(Index)*hight_boundarylayer/Indexmax) ,  20 >     //
upper-right corner
     interior {
          ior (lower_ior+((upper_ior-lower_ior)/Indexmax)*Index)
      #declare Index = Index + 1;
//normal medium
box{
<-50,-20+hight_boundarylayer,-20>
<50,50,20 >
     interior {
          ior upper_ior
//surface (heater)
 box{
<-50,-surface,-20>
<50,-50,20 >
          color Blue      }
           finish {
          ambient 0.3 }
light_source
{ <0,0,0>, 1
  looks_like {
  plane {
     z, 1000
         color White  }
             finish {
          ambient 1000 }
     location  -10*y- 1000*z
     direction 50*z
     up        y
     right 4/3*x
