POV-Ray : Newsgroups : povray.general : Using POV to render only Server Time
12 Apr 2026 09:24:06 EDT (-0400)
  Using POV to render only (Message 1 to 10 of 16)
Subject: Using POV to render only
Date: 15 Nov 2007 19:04:29
Message: <473cde8d$1@news.povray.org>
I have an app that needs to render a quick object and display it on it's
screen.
I have managed to get pvengine.exe to open up and render the bmp for me
but it tosses up a splash screen.  how do I do this in a completely
invisible way?
C# code
Process POVRay = new Process();
POVRay.StartInfo.FileName = "C:\\Program Files\\POV3.6\\bin\\pvengine.exe";
POVRay.StartInfo.Arguments = "+IC:\\temp\\demo.pov +OC:\\temp\\demo.bmp
+w320 +h200 -P -D /EXIT";
POVRay.StartInfo.WindowStyle = ProcessWindowStyle.Hidden;
POVRay.Start();
POVRay.WaitForExit();
Bryan Valencia
"I'd rather live with false hope than with false despair."
Subject: Re: Using POV to render only
Date: 15 Nov 2007 19:19:32
Message: <473ce214$1@news.povray.org>
> screen.
> invisible way?
Compile your own POV-Ray without GUI :) Or, talk to an existing POV-Ray
instance using a GUI extension.
Date: 15 Nov 2007 19:21:50
Message: <473ce29e$1@news.povray.org>
>> me but it tosses up a splash screen.  how do I do this in a completely
>> invisible way?
Or use Linux, where there is no integrated editor at all :)
Date: 16 Nov 2007 07:15:01
Message: <web.473d895054ece7ebd141b3240@news.povray.org>
> screen.
> invisible way?
Well i tried the same in a java servlet under WindowsXP, and the splash screen
appeared. I think that you can use the /EXIT parameter in the same command line
when you invoke Povray. Then when pov finish the image you can show it on your
own window, i think ...
After some efforts povray crashed and I cant execute it and cant reinstall it
.... Windows XP ...
Hope it helps.
            Manuel Mata
Date: 17 Nov 2007 15:07:21
Message: <473f49f9$1@news.povray.org>
Linux? are you nuts?  I am obviously in a Windows App, please!
Compiling my own POV-Ray... how hard is that?
Isn't there a way to tell POV to render in the task tray?  That would be
acceptable.
What I am doing is accepting inputs from a user and based on them,
creating a quick scene and displaying it in a panel on the winform.  So
in this case, having the splash screen come up whenever the user changes
anything is - how shall I say - too damned annoying.
Date: 17 Nov 2007 17:01:41
Message: <473f64c5@news.povray.org>
> be acceptable.
There is, click the Tray button on the toolbar :) But if your app
restarts POV-Ray again for each render, the splash window can't be
avoided. If you want that, you need to write a GUI Extension (in C) that
controls a single instance of POV-Ray. You start POV-Ray once, minimize
it to tray, and let your app control it.
I'll do it for you. I don't want to compile an unoptimized version! What
CPU do you have? Get CPU-Z or some similar tool to find out what
instruction sets your computer supports.
Date: 17 Nov 2007 17:43:51
Message: <473f6ea7$1@news.povray.org>
Well, here you go. Compiled with -msse2 -msse -mmmx -march=pentiumpro
-mtune=pentium4 -ffast-math. So, should have MMX, SSE, SSE2, run
somewhat faster on pentium4 and still be compatible with pentiumpro and
higher.
http://www.wikifortio.com/733640/povray.exe.zip
Date: 17 Nov 2007 18:03:10
Message: <473f732e$1@news.povray.org>
> and higher.
Eh, looks like wikifortio screwed my upload. Try this (slow!)
http://stuff.povaddict.com.ar/povray.zip
PS: it's 3.6.1. I merged the Windows config and makefiles with the unix
3.6.1 code, since there is no 3.6.1 win code yet.
Date: 18 Nov 2007 00:13:10
Message: <473fc9e6@news.povray.org>
> higher.
  SSE2 was introduced with Pentium4, so if the compiler really generated SSE2
instructions it won't work with anything older.
Date: 18 Nov 2007 00:14:21
Message: <473fca2d@news.povray.org>
  Btw, are you sure your distribution above complies with the POV-Ray
distribution license?
