POV-Ray : Newsgroups : povray.general : POV 'Outline' capability Server Time
10 May 2026 18:46:19 EDT (-0400)
  POV 'Outline' capability (Message 1 to 10 of 20)
Subject: POV 'Outline' capability
Date: 13 Jun 2006 09:29:37
Message: <448ebdc1@news.povray.org>
As a newbie, this may seem like a strange question: Is there anyway to draw
an outline (say 1+ pixel) around objects while (possibly even after) drawing
them?  I know this seems contrary to what raytracing does (realistic
renderings), but I want to do the outline for effect.
Subject: Re: POV 'Outline' capability
Date: 13 Jun 2006 14:58:28
Message: <448f0ad3@news.povray.org>
> them?
  No.
Date: 13 Jun 2006 17:15:09
Message: <448f2add$1@news.povray.org>
news:448f0ad3@news.povray.org...
draw
drawing
> > them?
>   No.
But you can do some tricks, possibly above the knowledge of a self
proclaimed newbie. For instance, see Thibaut Jonckheere's recent "Edge macro
demo scene". Though it doesn't appear to be a general solution (requires
mesh objects?)
Also, did megapov have a edge detect postprocessing feature?
Date: 13 Jun 2006 18:54:19
Message: <448f421b$1@news.povray.org>
Ross nous apporta ses lumieres en ce 13/06/2006 17:14:
> draw
> drawing
>>   No.
>>                                                           - Warp
> mesh objects?)
A possibility is to surround the objects that you want to outline with a very slightly
larger,
transparent version of itself. That object is set to rgbt 1 pigment. The trick is to
use
fade_distance <small value>, fade_color rgb 0 and fade_power 999. The fade_distance
must be very
close, but larger, to the size difference, or thickness of the "shell".
Getting everything OK is prety tricky, as you can go from a nearly invisible shell to
an opaque one
with some very small changes.
I've tried it and it CAN work at least in some cases. Almost impossible to set up when
the object
have any reflection.
Communism: It's everybody's shit.
Date: 13 Jun 2006 19:08:01
Message: <448f4551$1@news.povray.org>
 > a very slightly larger, transparent version of itself. That object is
 > set to rgbt 1 pigment. The trick is to use fade_distance <small
 > value>,  fade_color rgb 0 and fade_power 999. The fade_distance must
 > be very close, but larger, to the size difference, or thickness of the
 > "shell".
 > invisible shell to an opaque one with some very small changes.
 > impossible to set up when the object have any reflection.
If you've already got the entire object in slightly larger size, it
might suffice to use texture and interior_texture : a transparent
texture, but a black interior_texture. Won't work that good for
reflections though, probably only for objects as seen from the camera.
Tim
aka "Tim Nikias"
Date: 13 Jun 2006 19:36:57
Message: <448f4c19$1@news.povray.org>
Tim Nikias nous apporta ses lumieres en ce 13/06/2006 19:08:
>  > "shell".
> Regards,
> Tim
Wont work for reflective or transparent objects. My solution does work with
transparent objects (as
per my first succesful tests) and can potentialy works with reflective ones (but I
never managed to).
But I thought YOU did the backups...
Date: 13 Jun 2006 22:13:16
Message: <448f70bc$1@news.povray.org>
>> draw
>> drawing
>> them?
>  No.
>                                                          - Warp
http://news.povray.org/povray.binaries.images/thread/%3C3d3edd19%40news.povray.org%3E/
http://news.povray.org/povray.binaries.images/thread/%3C3d3fd84f%40news.povray.org%3E/
http://news.povray.org/povray.text.scene-files/thread/%3C3d3eddb0%40news.povray.org%3E/
Warp likes to give up too easy ;)
He means "no you can't directly, but htere are options for post processing
methods"
-tgq
Date: 14 Jun 2006 03:41:56
Message: <PN8fdNADw7jEFwC9@econym.demon.co.uk>
Yes, post_processing find_edges. But it's only in MegaPOV v0, it didn't
get carried forward into MegaPOV v1.
Mike Williams
Gentleman of Leisure
Date: 14 Jun 2006 04:25:18
Message: <448fc7ee$1@news.povray.org>
I think it survived in Megapov v1, it is now inside the  larger
post-process macro. See
http://megapov.inetart.net/manual-1.2.1/inc_pprocess.inc.html, "3.5.1.5.
Finding edges"
Thibaut
Date: 14 Jun 2006 04:35:47
Message: <448fca63@news.povray.org>
To complete the answers and links given by the others, there are indeed
some methods to get object outline. In addition to the links given by
Trevor G Qayle, you can :
- use my edgemacro macro (I have posted the necessary includes recently
in p.b.scene-files). It works nicely for any geometry, but is limited to
mesh objects, and there is some work needed to be able to use it with a
given object.
- use megapov "find edges" post process (see the link above, in the
answer to Mike Williams). Works with any object and scene. Main weakness
: really slow (even for very simple scene), and it is difficult to get
rid of antialiasing for the outline
- use the "angle of incidence" technique (again requires megapov). This
method is quite simple to implement, and works well for smooth round
shapes, but it is difficult to get good results when you have more
complex shapes. You can see a nice image made by Lightbeam with this
technique at
http://news.povray.org/povray.binaries.images/thread/%3C41f7e1ab@news.povray.org%3E/
with the scene-file at :
http://news.povray.org/povray.binaries.scene-files/attachment/%3C41f9190a@news.povray.org%3E/us-ascii?ttop=216485&toff=50
Thibaut
