![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Greetings again!
I am searching for a way to have lights (ambient 1.0) only in shadow regions
of a planet. Does anyone know a way to do that?
At the moment, I have a made a planet out of three layers: the planet itself
(a sphere with a high-resolution image map), another sphere with a
semi-transparent PNG map at ambient 1.0 for the city lights, and a sphere
with a semi-transparent PNG map for the clouds.
Altogether, it looks quite okay, but with this technology there are lights
on the dayside of mother earth, as well. And I really would prefer if my
citizens would prefer to "save energy" on the dayside...
Any suggestions?
Greetings,
Sven
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Sven Littkowski" <sve### [at] jamaica-focus com> wrote:
> Greetings again!
You can do this with a texture_map, with the gradient pattern using the
vector from the centre of the Earth to the centre of the Sun. Sorry, I'm
too tired to write any code right now. :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That sounds pretty interesting!
I would like to consider that. If not now and today, can you post it
tomorrow? I, and for sure many others, would appreciate it a lot!
Best greetings,
Sven
"PM 2Ring" <nomail@nomail> schrieb im Newsbeitrag
news:web.447885df9215ab7e76ba2c900@news.povray.org...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Sven Littkowski" <sve### [at] jamaica-focus com> wrote in message
news:44788b00$1@news.povray.org...
Why not just use a hemisphere for the lights. You can orient that in the
same way.
If the hemisphere is centred at the origin you can just use reorient_trans()
to point the blunt end at the light source.
Chris B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm sure you can figure it out, Sven. :) I'm a bit busy, ATM, chasing
links...
> same way.
That sounds simpler, Chris.
And splitting the atmosphere into two hemispheres will also solve Sven's
problem with the nighside atmosphere glowing.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > same way.
Although the texture_map method isn't really that much more difficult to
implement. Also, it doesn't require the use of intersection (which can slow
things down), and it allows a smooth transition between night and day.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
