POV-Ray : Newsgroups : povray.general : Potential Bug Server Time
14 Jan 2026 05:50:51 EST (-0500)
  Potential Bug (Message 1 to 3 of 3)
Subject: Potential Bug
Date: 21 Mar 2006 19:31:14
Message: <44209ad2$1@news.povray.org>
I have been trying to use the "Subset_Start_Frame" and
"Subset_End_Frame" commands in a .ini file to subdivide my animations
such that I can render portions of them on different computers.  During
this process I have identified a potential bug in the implementation of
this command.
What happens is when I use the "Subset_End_Frame" in my .ini file the
value for "Subset_End_Frame", not the value for "Final_Frame", gets
reported when I use the built in variable "final_frame" within the .pov
file.  This does not seem to be how the command should be set up, and
conflicts with the documentation.
I've included some sample code below - if you remove the
"Subset_Start_Frame" and "Subset_End_Frame" from the .ini file the
animation will produce 2 frames with red balls, 2 frames with green
balls, 2 blue, 2 yellow and 2 purple.  If you add in the subset commands
you should get 1 green, 2 blue and 2 yellow (i.e. frames 4-8).  Instead,
you get 1 blue, 2 yellow and 2 purple (i.e. the animation gets
recalculated, using frame 8 as the last frame, not frame 10).  This is
confirmed by the error file which is generated.
I'm using PovRay 3.6, 32-bit.  WinXP, 512meg RAM, Pentium M @1.60GHz.
I've also tried this using the same version of povray, WinXP, 256meg
RAM, Celeron something-or-other with the same result.
Bryan
POV file:
light_source {
   <0,500,-500>
   color rgb <1,1,1>
   location <0,0,-10>
   look_at <0,0,0>
   angle 30
sphere {
   <0,0,0>, 1
   #if ((frame_number/final_frame) <=1)
     pigment { color rgb <1,0,1> }
   #if ((frame_number/final_frame) <= 0.8)
     pigment { color rgb <1,1,0> }
   #if ((frame_number/final_frame) <= 0.6)
     pigment { color rgb <0,0,1> }
   #if ((frame_number/final_frame) <= 0.4)
     pigment { color rgb <0,1,0> }
   #if ((frame_number/final_frame) <= 0.2)
     pigment { color rgb <1,0,0> }
#debug concat("Final Frame  : ",str(final_frame,3,3),"\n")
#debug concat("Initial Frame: ",str(initial_frame,3,3),"\n")
#debug concat("Frame Number : ",str(frame_number,3,3),"\n")
Ini file:
Input_File_Name=ani.pov
Output_File_Name=images\
Initial_Frame=1
Final_Frame=10
Initial_Clock=0
Final_Clock=1
Debug_File=C:ani.txt
Subject: Re: Potential Bug
Date: 22 Mar 2006 20:30:00
Message: <web.4421f90b37244631a461adc20@news.povray.org>
Is it possible that you get what you want with Final_Frame=11?
11 frames gets ya  0.0, 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0
10 frames gets a   0/9, 1/9, 2/9, 3/9, 4/9, 5/9, 6/9, 7/9, 8/9, 9/9
Date: 23 Mar 2006 10:22:06
Message: <4422bd1e$1@news.povray.org>
That was example code, the actual animations I'm working on consist of
thousands of frames.  The whole idea of the subset commands is to allow
the user to split up large animations like that between computers (i.e.
computer 1 renders frames 1-500, computer 2 501-1000, etc).  The problem
is that as it is currently implemented, the subset commands only work to
allow you to render from one specific point to the end of the animation.
  Not very useful if I want to split up a 15,000 frame animation between
5 or 6 computers...
Bryan
