![](/i/fill.gif) |
I have been trying to use the "Subset_Start_Frame" and
"Subset_End_Frame" commands in a .ini file to subdivide my animations
such that I can render portions of them on different computers. During
this process I have identified a potential bug in the implementation of
this command.
What happens is when I use the "Subset_End_Frame" in my .ini file the
value for "Subset_End_Frame", not the value for "Final_Frame", gets
reported when I use the built in variable "final_frame" within the .pov
file. This does not seem to be how the command should be set up, and
conflicts with the documentation.
I've included some sample code below - if you remove the
"Subset_Start_Frame" and "Subset_End_Frame" from the .ini file the
animation will produce 2 frames with red balls, 2 frames with green
balls, 2 blue, 2 yellow and 2 purple. If you add in the subset commands
you should get 1 green, 2 blue and 2 yellow (i.e. frames 4-8). Instead,
you get 1 blue, 2 yellow and 2 purple (i.e. the animation gets
recalculated, using frame 8 as the last frame, not frame 10). This is
confirmed by the error file which is generated.
I'm using PovRay 3.6, 32-bit. WinXP, 512meg RAM, Pentium M @1.60GHz.
I've also tried this using the same version of povray, WinXP, 256meg
RAM, Celeron something-or-other with the same result.
Bryan
POV file:
light_source {
<0,500,-500>
color rgb <1,1,1>
location <0,0,-10>
look_at <0,0,0>
angle 30
sphere {
<0,0,0>, 1
#if ((frame_number/final_frame) <=1)
pigment { color rgb <1,0,1> }
#if ((frame_number/final_frame) <= 0.8)
pigment { color rgb <1,1,0> }
#if ((frame_number/final_frame) <= 0.6)
pigment { color rgb <0,0,1> }
#if ((frame_number/final_frame) <= 0.4)
pigment { color rgb <0,1,0> }
#if ((frame_number/final_frame) <= 0.2)
pigment { color rgb <1,0,0> }
#debug concat("Final Frame : ",str(final_frame,3,3),"\n")
#debug concat("Initial Frame: ",str(initial_frame,3,3),"\n")
#debug concat("Frame Number : ",str(frame_number,3,3),"\n")
Ini file:
Input_File_Name=ani.pov
Output_File_Name=images\
Initial_Frame=1
Final_Frame=10
Initial_Clock=0
Final_Clock=1
Debug_File=C:ani.txt
![](/i/fill.gif) |
![](/i/fill.gif) |
Is it possible that you get what you want with Final_Frame=11?
11 frames gets ya 0.0, 0.1, 0.2, 0.3, 0.4, 0.5, 0.6, 0.7, 0.8, 0.9, 1.0
10 frames gets a 0/9, 1/9, 2/9, 3/9, 4/9, 5/9, 6/9, 7/9, 8/9, 9/9
![](/i/fill.gif) |
