POV-Ray : Newsgroups : povray.general : Real water - inside and out? Server Time
13 Apr 2026 11:43:16 EDT (-0400)
  Real water - inside and out? (Message 1 to 6 of 6)
Subject: Real water - inside and out?
Date: 21 Jan 2006 15:10:30
Message: <43d29536$1@news.povray.org>
I'm trying to generate an animation of a dive site for a DVD video.
Basically, it's a "virtual tour" of the site, starting from shore.
Nothing fancy, just enough to give the viewers a basic idea of what the
topography is underwater.  I've generated the site using height_fields,
and have got most of the surrounding scenery finished and looking good.
Where I've come into some real troubles is getting water that looks good
from both "shore" and from "underwater".  Using some tutorials on the
internet I've managed to come up with some water which looks really nice
from the shore view, but is completely unrealistic from under water.
Basically, all of the scattering qualities I'd expect disappear when I
"submerge" the camera.
I suspect is the "interior" command is applied to the water when the
camera is on "land", but is being applied to the air when the camera is
"underwater".  Is this the case?  How do I fix this?
Code for water is attached below.
thanx
Bryan
plane {
  <0,1,0>, 0
    material {
         color rgbt <0.2, 0.7, 0.3, 0.5>
       } //end pigment
       finish {
         ambient 0.0
         diffuse 0.0
         reflection {
           0.0, 1.0
           fresnel on
         } //end reflection
         specular 0.4
         roughness 0.003
       }   //end finish
       normal {
         function {
           f_ridged_mf(x, y, z, 0.1, 3.0, 7, 0.7, 0.7, 2)
         } 0.8
         scale 20
       } //end normal
     } //end texture
     interior {
       ior 1.34
       media {
       scattering {
         2 <0.5, 0.65, 0.4>
         extinction 0.5
     } //end interior
Subject: Re: Real water - inside and out?
Date: 21 Jan 2006 17:55:54
Message: <43d2bbfa$1@news.povray.org>
news:43d29536$1@news.povray.org...
You forgot to put  the hollow statement in your plane object so no media
works in it.
plane {
  <0,1,0>, 0
hollow
    material {
BTW POV outputs a warning about that I think
Date: 23 Jan 2006 10:41:10
Message: <43d4f916$1@news.povray.org>
> works in it.
> plane {
>   <0,1,0>, 0
> hollow
>     material {
That has helped a little, but I'm still not getting exactly what I'm
looking for.  Now I get an error about my camera being inside of an
object filled with media, and that this may make the media not work
properly.  This is defiantly the case - my scattering media no longer
scatters, giving (in essence) unlimited visibility underwater.
Any suggestions?
Thanx
Bryan
Date: 24 Jan 2006 14:49:24
Message: <43d684c4@news.povray.org>
Untested for water, but just an idea, create a box under the plane
containing the media of choice large enough to cover the volume you need.
I've played with something similar for dusty air in a room illuminated
through a blue glass window.
Maybe:
box { <-10,-10,-10>,<10,0,10>
        pigment { color <1,1,1,0,1> }
       finish {
         ambient 0.0
         diffuse 0.0
         reflection 0.0
    interior {
       media {
       scattering {
         2 <0.5, 0.65, 0.4>
         extinction 0.5
"Bryan Heit" <bjh### [at] NOSPAMucalgaryca> wrote in message
news:43d4f916$1@news.povray.org...
<snip>
> Any suggestions?
> Thanx
> Bryan
Date: 24 Jan 2006 15:01:37
Message: <43d687a1@news.povray.org>
Found it. Of course the your choice of type 2 would probally be better for
water. The photons block is for my glass windows from my scene that
refracted the light coming through. Just another afterthough, you might be
able to use the density block to create thicker "clouds" in the water. I'm
not sure of your exacts goals of the scene, but I hope this helps.
#declare Dusty = box { <-21,0,-21>,<21,21,21> }
object { Dusty pigment { color rgbt 1 }
photons { pass_through }
hollow
interior {
media
     { scattering { 1, 0.07 extinction 0.01 }
       samples 30,100
Date: 25 Jan 2006 15:51:16
Message: <43d7e4c4$1@news.povray.org>
> hollow
> interior {
> media
>        samples 30,100
Thanx for the help; it looks great.  I now have another problem, but
that's another question.
Bryan
