POV-Ray : Newsgroups : povray.general : Linux framebuffer patch version 0.3 released Server Time
1 Oct 2024 03:16:25 EDT (-0400)
  Linux framebuffer patch version 0.3 released (Message 1 to 1 of 1)
Subject: Linux framebuffer patch version 0.3 released
Date: 18 Aug 2005 09:47:50
Message: <43049186$1@news.povray.org>
The version 0.3 of the Linux framebuffer patch to povray-3.6.1 for Unix
is available for download here:
http://pov4grasp.free.fr/download/povray-3.6.1-fb-0.3.0.tar.bz2
	List of changes from version 0.2 to 0.3:
- add support for 15/16/24/32 bpp directcolor visuals (rgb colormaps)
- add support for (user-supplied) background image a la X Window
- add support for alpha transparency in rendering and background image
- add custom positioning of the display with $POV_FB_GEOMETRY
- fix info message for 32 bpp color depth reported as 24 bpp
- fix finished message sent to stdout instead of stderr
- fix dump screen to use povray iostreams
- more code reorganisation
	Notes:
- Directcolor visuals were tested with the rather old aty128fb framebuffer
   driver in 8/15/24/32 bpp color depths (16 bpp is handled as 15 bpp).
- The background image feature is similar to that found in the X Window
   display capability of povray.  Usage is explained in the doc/README.unix
   file of the official povray-3.6.1 for Unix distributions.  Basically
   the background behind the display is filled with a checker pattern by
   default, or the ~/.povray/3.6/background.ext image file (where "ext"
   is either "jpg", "jpeg", "png", "ppm", "tga" or "gif").  The difference
   here is that alpha channel is supported; thus an empty background can be
   obtained using a fully transparent (1-pixel) image.  Tested with png
   files only (transparency might not work with gif files yet).
- The display can now be arbitrarily positionned anywhere on- or off-screen.
   Its position and maximum size are controlled by the POV_FB_GEOMETRY
   environment variable, which value is in the form:
     MAXWIDTHxMAXHEIGHT+XOFFSET+YOFFSET
   where MAXWIDTH and MAXHEIGHT are positive integers to set the maximum
   display width and height, XOFFSET and YOFFSET are integers to specify
   the display offset compared to the screen borders.  The '+' sign can be
   replaced by '-' to tell which screen border to account for.  This notation
   basically follows the same rules as the -geometry option found in most
   X Window applications; see the X manual.  The difference is that the
   width and height set a maximum allowed size while keeping the display
   aspect ratio.
   For instance:
   export POV_FB_GEOMETRY=640x480-0+0
   povray abyss.pov +w2048 +h768
   will display the image with a maximum width of 640 pixels on the top
   right corner of the screen.
	Sample images are available in p.binaries.images (same subject).
	- NC
Subject: Re: Linux framebuffer patch version 0.3 released
Date: 18 Aug 2005 10:21:36
Message: <43049970@news.povray.org>
Note: installation instruction (as for version 0.2)
	To apply the patch, untar the archive and copy all the files from the
newly created povray-3.6.1-fb-0.3.0/ directory to the corresponding locations
in the source distribution of povray-3.6.1.  Then run the ./configure script
as usual, and 'make check' to build and run a test render.  The tarball contains
only the new and modified files, as compared to the official povray-3.6.1 for
Unix source archive.
(From version 0.2 to 0.3 only the unix/fbb.cpp file was actually changed.
Thus it should be safe to copy that file alone if you already applied the
previous version of this patch to povray-3.6.1.)
	- NC
Date: 18 Aug 2005 10:45:02
Message: <de26q0$trs$1@chho.imagico.de>
You know i have been somewhat reluctant about the user supplied
background (using the core code image reading functions for something
there were't intended for...)
But of course using libxpm isn't an option here. :-)
Maybe we should just write a simple PPM reader that can be used by all
display modes for reading the background image.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 18 Aug 2005 11:09:16
Message: <4304a49c$1@news.povray.org>
	... and you know that looking at the code will tell you that
those core functions aren't badly hijacked: it's actually quite clean
	PPM can't handle transparency (gimp says).  Can it?
	- NC
Date: 18 Aug 2005 12:05:02
Message: <de2bi2$uvg$1@chho.imagico.de>
Well - this is not the point.  The problem is that when making changes
to the core code possible requirements of the frontend using the code
for a different nonstandard purpose are no concern.  In other words: The
interfaces between core code and platform specific frontend should be
well defined for both directions and currently this is not the case for
using the image reading functions in the frontend.
No but what use has transparency except having a totally transparent
image (which does not need to be an image anyway).  Note you can of
course also implement a PNG reader but this would require libpng.
Date: 18 Aug 2005 13:45:02
Message: <de2hb1$6i$1@chho.imagico.de>
>     This patch is against pov 3.6, for which I doubt there will be any
> such core change.
For integrating this patch into MegaPOV we have to consider
maintainability.  It is quite possibe that there will be patches
changing the way images are read in the future.  To add some feature not
actually extending program usability, just adding some gimmick, at this
cost is not very good.  So when adding this patch to MegaPOV (which i
seriously consider - the patch itself is a very interesting and useful
one) i will most likely remove this part.
>> image
>     That's precisely the point.
>     I'd be interested to see how you would use the current background.*
> feature to get transparent background (apart from disabling the default
> checker code or adding support for some extra command / env var).
Quite simple: reserve a certain file name used for the background image
to be interpreted as plain transparent.  Same can be used for different
internally generated checkers.  See the ImageMagick built-in
Images/Patterns for what i mean.
Date: 18 Aug 2005 14:29:57
Message: <4304d3a5$1@news.povray.org>
> maintainability.
	I knew you would answer something around these lines, which is one reason
that motivated the cancelling of my post.  But too late apparently  :-p
	- NC
Date: 18 Aug 2005 14:38:00
Message: <4304d588@news.povray.org>
	Not something I find particularly elegant either.
	- NC
Date: 18 Aug 2005 15:00:02
Message: <de2lpr$15s$1@chho.imagico.de>
>> maintainability.
> reason
Just FYI: You have at most 5 minutes to cancel a post to prevent it from
becoming visible for me (because i suck news every 5 minutes). ;-)
I find it a fairly good concept.  You can have any number of internal
background patterns and the user has easy access to them without need to
handle a separate file for each of them.  The background image
reading/generation would be in the general code (in unix.cpp) and the
different display modes would simply access them with some function.
Date: 18 Aug 2005 15:45:09
Message: <4304e545@news.povray.org>
	I still don't quite understand how this would work from the user
standpoint (I'll look later at how imagemagick does) i.e. how the user
tell povray to use whatever image or pattern.
	Well probably too much coding of color bitmasks these last days...
	This is something I already wanted to do, so at least I agree
to this point  ;-)
	- NC
