POV-Ray : Newsgroups : povray.general : Is this a bug? Server Time
14 Jan 2026 17:33:48 EST (-0500)
  Is this a bug? (Message 1 to 5 of 5)
Subject: Is this a bug?
Date: 3 Jun 2005 19:35:03
Message: <42a0e927@news.povray.org>
#declare MyTexture = texture{ pigment {agate} }
#declare MyOtherTexture = texture{  MyTexture pigment{ granite} }
are legal, but
#declare MyTexture = texture{ uv_mapping pigment {agate} }
cause a parser error on the second declaration: no matching } in 'texture',
pigment found instead.
Is this a bug or there is some reason for things work this way?
I also found recently that POVRAY crashes on my system when using the old
tiles texture without specifying one (or both) textures of the list, e.g.
sphere{0.0, 1.0 texture{tiles {tile2}} }
results in a message box:
The POV-Ray core rendering threw an unhandled exception.
The backend thread has been shut down and will not be able to perform any
further renders.
Could someone please confirm it?
Thanks in advance,
Hugo.
Subject: Re: Is this a bug?
Date: 4 Jun 2005 11:18:01
Message: <42a1c629$1@news.povray.org>
Hugo wrote:
> Hi,
> are legal, but
Not sure about whether a bug.  You are overriding the pigment declared
in MyTexture with the definition that follows.  I guess once you
introduce uvmapping you can't do that.
This seems to work:
#declare MyTexture = texture {  pigment {agate} }
texture {  uv_mapping MyTexture  pigment { granite} }
Date: 4 Jun 2005 15:41:13
Message: <42a203d9$1@news.povray.org>
Well, it does work okay if not doing a texture, as in the following:
#declare UV_Pigment = pigment { uv_mapping agate }
#declare UVP_Changed = pigment { UV_Pigment granite }
sphere {0,1 texture {UVP_Changed}}
So this seems to be a problem with the way texture alone is done.
As for the 'tiles' error, that pattern type is only a vague memory to me.
Must be something going back to the earliest POV versions. I do get that
same problem in both 3.6 and 3.5. #version directive didn't help.
I'm not exactly sure how to write it. Looking at the documentation it would
seem correct to write it like so:
texture {tiles T1 tile2 T2}
with T1 and T2 being previously declared textures.
POV complains about a missing leading brace "{" and instead a texture
identifier found, yet I would have thought it were used like the checker
pattern.
Hugo, was that tiles usage taken from an earlier scene file? Or was it
you're own interpretation of how it the syntax for it is to be written.
Or... did you attempt following the error message suggestion that a { was
missing if leaving it out?
I'm curious how you happened across this problem, since it seems something
left in for backwards compatibility and not something people might be using
still today. Of course, regardless, anything in POV is certainly supposed to
be possible without a crash but I think the correct syntax needs to be
realized.
Bob Hughes
Date: 5 Jun 2005 03:54:08
Message: <42a2afa0@news.povray.org>
> would seem correct to write it like so:
In fact the correct syntax for the old tile texture is:
texture{ tiles{ T1 tile2 T2 } } , where T1 and T2 are complete texture
statements.
> using still today. Of course, regardless, anything in POV is certainly
> supposed to be possible without a crash but I think the correct syntax
> needs to be realized.
Actually I am working on a POV parser and I had to check if one could
omit the textures of the list, like with the others block pattern textures.
Thank you for your answers,
Hugo.
Date: 5 Jun 2005 19:42:00
Message: <42a38dc8@news.povray.org>
Hmmm...  Just curious.  Is there a published formal definition (BNF or
similar) for the POVRay SDL?  I'm sure the POVRay team has something
like that for their own use, but I'm not sure if that would be available
for the general public.  Of course, there's the standard documentation,
but I mean something more explicitly formal.  I've never checked into
this myself, and I wouldn't (or couldn't) use it if it were available.
But I just wondered...
      -=- Larry -=-
