POV-Ray : Newsgroups : povray.general : Outputting raw pixel data? Server Time
10 Sep 2025 14:33:28 EDT (-0400)
  Outputting raw pixel data? (Message 1 to 10 of 11)
Subject: Outputting raw pixel data?
Date: 31 Mar 2005 07:46:29
Message: <424bf125$1@news.povray.org>
I understand that POV uses double precision floating point numbers
internally, it then clips them to 0..1 and scales appropiately to save to a
24-bit bitmap.  If this is correct, is there any way to output the raw
double float values for each rendered pixel to a file?  Has anyone written a
patch to do this? It doesn't seem like it will be that hard.
I would like to use the raw full-precision values in a program I am writing,
so the format doesn't matter really.
Subject: Re: Outputting raw pixel data?
Date: 31 Mar 2005 08:42:59
Message: <424bfe63$1@news.povray.org>
Hash: SHA1
Mega pov 1.1...
http://megapov.inetart.net/manual-1.1/global_settings.html#post_processing
Using the RAW format (+FR switch)... but it was dropped from latest
official. I do not know if Megapov kept it.
Notice: PNG is not limited to 8 bits per channels. You can boost it up
to 16 bits per channel if you want. (yep, that's 48 RGB bits!)
PS: printf usually as an issue with double precision, do not expect all
the digits!
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCS/5is/YJ43cSjHIRAoASAJ9tifGrCf3IRBUA8l67Cg42njA5nACgi3aX
fCqrCZkkA3jP96ZnW8fvKDg=
=YoB9
-----END PGP SIGNATURE-----
Date: 31 Mar 2005 09:00:40
Message: <424c0288@news.povray.org>
> the digits!
  printf has no issues with double precision. It's just a question of
specifying the proper parameters.
    double d = 1.234567890123456789;
    printf("%.15f\n", d);
prints:
1.234567890123457
  And by the way, color values are calculated using single precision
floating points in povray.
Date: 31 Mar 2005 09:33:11
Message: <424c0a27@news.povray.org>
>> all the digits!
> prints:
> 1.234567890123457
I would probably just write the binary to a file, rather than use printf.
So in theory I can patch the source code to output these 32-bit floats for
each colour for each pixel rendered?
I found the following code in pvbmp.cpp:
 for (i = 0 ; i < width ; i++)
    out << (unsigned char) floor (line_data [i] [pBLUE] * 255.0) ;
    out << (unsigned char) floor (line_data [i] [pGREEN] * 255.0) ;
    out << (unsigned char) floor (line_data [i] [pRED] * 255.0) ;
So this line_data[i][pBLUE] is a single float value that I can just write
directly to a file rather than using *255.0 and floor()...
Date: 31 Mar 2005 21:33:22
Message: <Xns962B2D575F64Eraf256com@203.29.75.35>
jgr### [at] freefr news:424bfe63$1@news.povray.org
I few times suggested such extension as usable, and when finaly they added
it, then it was droped :( why in the gods name?
http://www.raf256.com/3d/
Computer Graphics
Date: 1 Apr 2005 01:57:30
Message: <424cf0da$1@news.povray.org>
Xns962B2D575F64Eraf256com@203.29.75.35...
The RAW format that was supported from POV-Ray 1.0 to 3.0 and dropped in
3.1. was just a regular 3 byte per pixel, 24 color data, and NOT a double
precision format. It was dropped because it was considered useless.
From the old raw.c code in POV-Ray 2.0:
*  (header:)
*    wwww hhhh       - Width, Height (16 bits, LSB first)
*  (each scanline:)
*    llll            - Line number (16 bits, LSB first)
*    rr rr rr ...    - Red data for line (8 bits per pixel,
*                       left to right, 0-255 (255=bright, 0=dark))
*    gg gg gg ...    - Green data for line (8 bits per pixel,
*    bb bb bb ...    - Blue data for line (8 bits per pixel,
G.
http://www.oyonale.com
- Graphic experiments
- Posters
> Rafal Maj 'Raf256', home page - http://www.raf256.com/me/
> Computer Graphics
Date: 1 Apr 2005 02:46:21
Message: <424cfc4d@news.povray.org>
"scott" <sco### [at] spamcom> schrieb im Newsbeitrag
news:424c0a27@news.povray.org...
If you compile a Win version with this, I'd be quite interested in it too...
Micha
Date: 1 Apr 2005 04:21:10
Message: <lb4q41p4uanhev8t1j4lnt6nf0tp37u9h7@4ax.com>
On 31 Mar 2005 21:33:22 -0500, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
+FR was added after your suggestion? 1st April joke?
Find your posts and reread threads to get answers :-)
ABX
Date: 1 Apr 2005 05:06:51
Message: <424D1E03.59B6B9BB@gmx.de>
Note such a patch will never make it into official POV or MegaPOV (the
reason has been explained multiple times in the past so i won't do it
again).  This does not mean there will not be any floating point format
output but certainly not in the way you describe it (which will not even
be portable between PC and Mac).
Also note in MegaPOV you can write those raw color values to a text file
using the camera_view pigment in a pigment function and evaluating it in
a loop.  Not exactly highly efficient but usable.
-- Christoph
Date: 1 Apr 2005 11:07:34
Message: <424d71c6@news.povray.org>
>> write directly to a file rather than using *255.0 and floor()...
> too...
OK, well all I did was to modify the pvbmp.cpp file to output floats instead
of bytes.  It's all a bit of a hack but I rarely use bmp output anyway.  It
does what I want (which will probably be explained around here somewhere at
some point...) but isn't very clean:
This is the updated BMP_Image::Write_Line function below, if you can't
compile it then drop me an email and I'll send you the windows .exe (i'm
scottgboham at hotmail.com).  Note that the file size is much bigger than
the BMP header suggests due to this...
void BMP_Image::Write_Line (COLOUR *line_data)
  int pad = (4 - ((width * 3) % 4)) & 0x03 ;
  int i;
  OStream& out = *out_file ;
  if (!out.seekg (14 + 40 + (height - 1 - line_number) * (12 * width )))
    Error ("Error seeking in BMP image.") ;
  unsigned long *t;
  float tmp;
  float *t2;
  t2 = &tmp;
  t  = (unsigned long *) &tmp;
    tmp = (float) line_data [i] [pBLUE];   out << ( *t ) ;
    tmp = (float) line_data [i] [pGREEN];  out << ( *t ) ;
    tmp = (float) line_data [i] [pRED];    out << ( *t ) ;
  if (!out)
    Error ("Error writing to BMP image.") ;
  line_number++;
  out.flush () ;
