POV-Ray : Newsgroups : povray.general : Parse Warning: Camera vectors are not perpendicular. Server Time
25 Dec 2025 17:33:59 EST (-0500)
  Parse Warning: Camera vectors are not perpendicular. (Message 1 to 10 of 16)
Subject: Parse Warning: Camera vectors are not perpendicular.
Date: 8 Mar 2005 07:21:21
Message: <422d98c1$1@news.povray.org>
Why do I get this message when I use a perspective camera with a matrix
transformation ,e.g.:
         perspective
         right x * 4.0
         up y * 3.0
         matrix <0.9358968469314277, 1.862645149230957E-9,
-0.3522741496562958, 0.05264317989349365, 0.988771082367748,
0.1398586481809616, 0.348318487405777, -0.14943809807300568,
0.9253877382725477, -68.93845592397729, 101.72871539795597,
-174.07854648367464>
         angle 38.58009
The matrix just contains a rotation and a translation, so the vectors
are perpendicular and the warning message is obviously wrong.
Is there any workaround other than turning off vista buffers?
Thanks
-sascha
Subject: Re: Parse Warning: Camera vectors are not perpendicular.
Date: 8 Mar 2005 08:17:44
Message: <422da5f8@news.povray.org>
  But the values in the matrix may not be accurate enough.
  How about just using the rotations and translations directly?
Date: 8 Mar 2005 09:35:21
Message: <422db829$1@news.povray.org>
That's double precision (64bit)... How accurate does POV need them?
My program represents the camera orientation as quaternion - it coverts
it to matrix representaion before exporting it. If there already is a
matrix representation, POV should be able to use it :-/
Do you know how to convert orientations represented as quaternions or
axis-angle pairs into fixed-angle representations (for use in POV's
rotate <x,y,z> command)?
Thanks
-sascha
Date: 8 Mar 2005 12:06:38
Message: <cjameshuff-9CC8CB.12063708032005@news.povray.org>
In article <422db829$1@news.povray.org>,
No, that's decimal ASCII text. Those are *not* the exact values your
program computed. And the problem may still be in your computations,
simply using double precision is no guarantee that your numbers are
correct. Rounding error can easily accumulate and result in a
non-orthogonal final matrix.
<http://www.mathworks.com/access/helpdesk/help/toolbox/aeroblks/quaternio
nstoeulerangles.html>
You could also compute the camera basis vectors and tweak them to be
perpendicular inside POV. For example, find the inaccurate right and
direction vectors, use them to compute the correct up vector, then use
the direction and corrected up vectors to compute a working right vector.
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Date: 8 Mar 2005 12:42:27
Message: <422de403$1@news.povray.org>
> program computed.
Yes, sure, I know that representing (binary) floats as decimal is always
problematic, but I think that's about as accurate as possible...
I don't think that POV likes hexadecimal IEEE754 representations?
I've used the vecmath package from Java3D - All I do is creating a 4x4
matrix from a unit-quaternion... From looking at the images it renders
(with -UV) everything looks right.
Could it be that the test for perpendicular vectors in POV-Ray is a bit
too pedantic?
Thanks a lot for that link, I'll try that...
-sascha
Date: 8 Mar 2005 17:05:10
Message: <422e2195@news.povray.org>
  You could just apply the transformations to the location and
look_at vectors of the camera and write just those.
Date: 8 Mar 2005 18:30:35
Message: <cjameshuff-0C3787.18300808032005@news.povray.org>
In article <422e2195@news.povray.org>, Warp <war### [at] tagpovrayorg>
Not if you need the camera to roll. If you don't, though, that'd be the
easiest way to do it. And with a little more work, you could figure the
appropriate amount to roll the camera.
Date: 8 Mar 2005 18:39:31
Message: <422e37b2@news.povray.org>
  If you multiply the location, look_at and sky vectors with the
transformation matrix (with the sky vector translation should not
be performed) it should give the same result as if a direct matrix
transformation was added to the camera block.
Date: 8 Mar 2005 21:10:01
Message: <web.422e5a246a22aac652d573c20@news.povray.org>
> camera {
>          perspective
>          right x * 4.0
>          up y * 3.0
>          angle 38.58009
Are you sure about this Sascha ?
I.e. have you verified that this really is a rotation matrix ?
IIRC rotation matrices should be orthogonal (A^T*A = I or A^T = A^-1).
Thus their row (or column) vectors should form an orthonormal set of
vectors.
The row vectors in your matrix do not seem to satisfy that demand.
(See the output from the test script below.)
For me it seems that your matrix has been generated by using single
precision math.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Test for orthogonal matrix. (I.e. M^T*M = I or M^T = M^-1)
#version 3.6;
#declare Decimals = 17;
// The matrix elements
#declare M11 = 0.93589684693142770;
#declare M12 = 1.862645149230957E-9;
#declare M13 = -0.3522741496562958;
#declare M21 = 0.05264317989349365;
#declare M22 = 0.988771082367748;
#declare M23 = 0.1398586481809616;
#declare M31 = 0.34831848740577700;
#declare M32 = -0.14943809807300568;
#declare M33 = 0.9253877382725477;
#declare M41 = -68.93845592397729;
#declare M42 = 101.72871539795597;
#declare M43 = -174.07854648367464;
// Test camera transformation.  (Check output for warnings)
  perspective
  right 4*x
  up 3*y
  matrix <
    M11, M12, M13,
    M21, M22, M23,
    M31, M32, M33,
    M41, M42, M43
// Define row vectors and check if matrix is orthogonal.
// (Vector lengths should be 1 and dot products should be 0.)
#declare vR1 = <M11, M12, M13>;
#declare vR2 = <M21, M22, M23>;
#declare vR3 = <M31, M32, M33>;
#debug "nn"
#debug concat("nvR1: <", vstr(3, vR1, ", ", 0, Decimals), ">")
#debug concat("nvR2: <", vstr(3, vR2, ", ", 0, Decimals), ">")
#debug concat("nvR3: <", vstr(3, vR3, ", ", 0, Decimals), ">")
#debug "n"
#debug concat("nvlength(vR1): ", str(vlength(vR1), 0, Decimals))
#debug concat("nvlength(vR2): ", str(vlength(vR2), 0, Decimals))
#debug concat("nvlength(vR3): ", str(vlength(vR3), 0, Decimals))
#debug "n"
#debug concat("nvdot(vR1, vR2): ", str(vdot(vR1, vR2), 0, Decimals))
#debug concat("nvdot(vR2, vR3): ", str(vdot(vR2, vR3), 0, Decimals))
#debug concat("nvdot(vR3, vR1): ", str(vdot(vR3, vR1), 0, Decimals))
// Make new set of normalized and perpendicular row vectors
// and check if matrix is orthogonal now.
#declare vN1 = vnormalize(vR1);
#declare vN2 = vnormalize(vcross(vN1, vR2));
#declare vN3 = vcross(vN2, vN1);
#debug "nn"
#debug concat("nvN1: <", vstr(3, vN1, ", ", 0, Decimals), ">")
#debug concat("nvN2: <", vstr(3, vN2, ", ", 0, Decimals), ">")
#debug concat("nvN3: <", vstr(3, vN3, ", ", 0, Decimals), ">")
#debug "n"
#debug concat("nvlength(vN1): ", str(vlength(vN1), 0, Decimals))
#debug concat("nvlength(vN2): ", str(vlength(vN2), 0, Decimals))
#debug concat("nvlength(vN3): ", str(vlength(vN3), 0, Decimals))
#debug "n"
#debug concat("nvdot(vN1, vN2): ", str(vdot(vN1, vN2), 0, Decimals))
#debug concat("nvdot(vN2, vN3): ", str(vdot(vN2, vN3), 0, Decimals))
#debug concat("nvdot(vN3, vN1): ", str(vdot(vN3, vN1), 0, Decimals))
// Test camera with new transformation. (Check output for warnings)
#debug "nnnn"
#declare M11 = vN1.x;
#declare M12 = vN1.y;
#declare M13 = vN1.z;
#declare M21 = vN2.x;
#declare M22 = vN2.y;
#declare M23 = vN2.z;
#declare M31 = vN3.x;
#declare M32 = vN3.y;
#declare M33 = vN3.z;
  perspective
  right 4*x
  up 3*y
  matrix <
    M11, M12, M13,
    M21, M22, M23,
    M31, M32, M33,
    M41, M42, M43
Here is the output from POV-Ray 3.6.1 (g++ 3.4.1 @ i686-pc-linux-gnu):
vR1: <0.93589684693142772, 0.00000000186264515, -0.35227414965629578>
vR2: <0.05264317989349365, 0.98877108236774802, 0.13985864818096161>
vR3: <0.34831848740577698, -0.14943809807300568, 0.92538773827254772>
vlength(vR1): 0.99999999230612724
vlength(vR2): 0.99999999959349639
vlength(vR3): 0.99999998998475348
vdot(vR1, vR2): 0.00000000155646701
vdot(vR2, vR3): 0.00000000093214445
vdot(vR3, vR1): -0.00000000478968380
vN1: <0.93589685413209900, 0.00000000186264516, -0.35227415236664827>
vN2: <0.34831849532785164, -0.14943810049134260, 0.92538774572288385>
vN3: <0.05264317845820071, 0.98877108276968706, 0.13985864878611778>
vlength(vN1): 1.00000000000000000
vlength(vN2): 1.00000000000000000
vlength(vN3): 1.00000000000000000
vdot(vN1, vN2): 0.00000000000000006
vdot(vN2, vN3): 0.00000000000000000
vdot(vN3, vN1): -0.00000000000000000
Date: 9 Mar 2005 03:50:03
Message: <422eb8bb$1@news.povray.org>
That should work, but I suspect it will lead to the same result if the
matrix is somehow not accurate enough...
