POV-Ray : Newsgroups : povray.general : interesting link Server Time
26 Dec 2025 06:33:33 EST (-0500)
  interesting link (Message 1 to 9 of 9)
Subject: interesting link
Date: 10 Oct 2004 12:24:48
Message: <41696250$1@news.povray.org>
Hello fellow raytracers,
A friend of me has send me this link:
http://www.saarcor.de/
I looks rather promissing, so i can't wait to see more improvement of this
project!
Greetings,
JWV
PS: I am not connected to this project (not even close :-) )
Subject: Re: interesting link
Date: 11 Oct 2004 04:09:13
Message: <416a3fa9@news.povray.org>
> project!
  So far the example images don't look any impressive to me. They don't seem
to contain anything that couldn't be done quite easily with current
scanline-rendering 3D cards.
  If you can't have smooth triangles (which you clearly can't at least
in the current prototype), raytracing is pretty useless.
Date: 11 Oct 2004 05:33:05
Message: <416a5351@news.povray.org>
>>project!
This was my thought, too.
But the idea to implement a raytracer in FPGAs is
interesting.
Sebastian H.
Date: 11 Oct 2004 21:07:16
Message: <416b2e44$1@news.povray.org>
news:416a3fa9@news.povray.org...
>> this
>> project!
> seem
Well, they are clearly using true reflections which are impossible with
current scanline
accelerators.  One more thing, is that scenes with upwards of 100 million
triangles
(like the sunflowers) may be approaching the point where raytracing becomes
more
efficient than scanline rendering - because of the log(n) cost of finding
intersecting
objects for a pixel may be faster than rasterizing all the polygons.
Date: 13 Oct 2004 04:57:10
Message: <416cede6@news.povray.org>
> current scanline
> accelerators.
  max_trace_level 2 reflections are possible with accelerators up to a
point. However, none of the example images really showed the advantages
of being able to have deeper reflection levels. This is because there
aren't smooth triangles.
Date: 13 Oct 2004 08:28:37
Message: <pan.2004.10.13.13.25.51.375709@uwaterloo.ca>
>> current scanline
>> accelerators.
Could you point me to an accelerator that has such support?  I know it can
be done by stretching the shading language to its limit and rendering in
passes like:
http://graphics.stanford.edu/papers/rtongfx/
This is not architectural support.
But I don't know of any mainstream graphics hardware that has support for
reflections.  Maybe you are thinking of reflections maps?  This is not a
true reflection, because it is only correct at a single point.  Also the
mirror reflection you see in games are also tricks.
Andrew
Date: 13 Oct 2004 09:20:02
Message: <416d2b82@news.povray.org>
> Maybe you are thinking of reflections maps?  This is not a true reflection
  What is a "true reflection" in your opinion?
  If a reflection looks good, then it's as "true" as it gets.
  If we start argumenting about what is "true" and what isn't, then nothing
POV-Ray or any other 3D engine does is "true". Everything is just an
approximation.
Date: 14 Oct 2004 00:48:28
Message: <pan.2004.10.14.05.45.43.386223@uwaterloo.ca>
>> reflection
Okay, I define it to be one that obeys the law of reflection at all points
(not just one).  Of course you can define it any way you'd like, but I
don't think you'd argue that this definition is "more true" than the way
reflection maps work :-)
Andrew
Date: 14 Oct 2004 03:32:31
Message: <416e2b8f@news.povray.org>
  Reflection maps work pretty well assuming that none of the reflected
scene is too close to the reflecting object.
  If the rest of the scene is far enough from the reflecting object,
there's practically no difference between reflection maps and reflection
by raytracing (give or take some pixelation).
  Reflection maps have the advantage that they are very fast to render
(it can be done in real-time) and many effects can be done for free with
them (eg. blurred reflection, phong highlights, etc).
  They have the disadvantage that they don't work well if an object
being reflected is too close to the reflecting object, and inter-reflection
between two or more reflecting surfaces is not trivial.
  (One could think that an additional disadvantage is that it only works
with flat polygons, but in fact that's not a limitation of reflection
maps: Nothing stops you from using reflection maps with any surface you
are eg. raytracing. Of course it often doesn't make sense, specially in
raytracing, but it's perfectly possible.)
