POV-Ray : Newsgroups : povray.general : blummin Media headache again! Server Time
3 Oct 2024 20:22:33 EDT (-0400)
  blummin Media headache again! (Message 1 to 10 of 20)
Subject: blummin Media headache again!
Date: 1 Jul 2004 10:25:44
Message: <40e41ee8$1@news.povray.org>
Help before I climb the bell tower and start shooting!
please :-)
I have a simple radiosity scene, a cylinder with ambient 1 encased in a much
bigger cylinder filled with cylindrical media.  For some reason I cant
fathom, I cant see the media.  If there some setting that needs to be turned
on for radiosity and media to interact
Subject: Re: blummin Media headache again!
Date: 1 Jul 2004 10:31:08
Message: <40e4202c$1@news.povray.org>
> please :-)
Make sure the container cylinder is hollow.
Media on should be in the radiosity block.
Try a constant density to rule out the cylindrical pattern as being  the
cause.
Date: 1 Jul 2004 10:44:02
Message: <opsagq4xzuefp2ch@news.povray.org>
And lo on Thu, 01 Jul 2004 09:31:08 -0500, Mike Raiford
<mra### [at] hotmailcom> did spake, saying:
>>  please :-)
>> a much
>> turned
> cause.
I thought media would only function with a light_source producing a ray to
sample along as stated in 6.8, AFAIK ambient, like emission, doesn't
produce light in this way even using radiosity.
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 1 Jul 2004 10:45:01
Message: <web.40e422ab5304920a620840b30@news.povray.org>
> please :-)
For the radiosity to affect media, you need "media on" in the radiosity
block in the global_settings.
The cylindrical pattern have a radius of one (1), you have to scale it to
the radius of your big cylinder. Set your media as scattering and adjust
it's density if it's to light or dense. Also, the big cylinder need to have
the hollow attribute or no media will ever show inside of it.
Date: 1 Jul 2004 10:51:40
Message: <40e424fc$1@news.povray.org>
> to  sample along as stated in 6.8, AFAIK ambient, like emission,
> doesn't  produce light in this way even using radiosity.
D'oh. To think, I just got done meddling with the same stuff and came to
the conclusion that media *does* need a real light.
Hmm, for some reason the mention of an ambient 1 object escaped that
tiny little pea up there in my skull ;)
Date: 1 Jul 2004 10:56:17
Message: <40e42611$1@news.povray.org>
Erm.. Ambient does produce light, but the light does no react with the
media. Media affects radiosity, radiosity does not affect media.
Date: 1 Jul 2004 11:11:09
Message: <40e4298d@news.povray.org>
> cause.
"media on"  is showing my media ,thank you very much, I'll put the rifle
away for now...
Date: 1 Jul 2004 11:14:25
Message: <opsagsjia4efp2ch@news.povray.org>
And lo on Thu, 01 Jul 2004 09:56:17 -0500, Mike Raiford
*in this way* :)
3.7.5: "POV-Ray uses the ambient keyword to determine how much light
coming from the ambient light source is reflected by a surface" and
6.7.3.1 "Computing real ambient light would take far too much time, so we
simulate ambient light by adding a small amount of white light to each
texture whether or not a light is actually shining on that texture."
So if you think about it what is the location of the ambient light source
and how do you trace a ray along it it through the media to sample along?
Gods I've been fiddling with media to long :P
Phil Cook
Date: 1 Jul 2004 11:20:09
Message: <40e42ba9$1@news.povray.org>
> *in this way* :)
> we  simulate ambient light by adding a small amount of white light to
> each  texture whether or not a light is actually shining on that texture."
Doesn't radiosity attempt to approximate this?
Ambient has a totally different meaning in a radiosity scene. It emits
light, It will illuminate nearby objects...
> source  and how do you trace a ray along it it through the media to
> sample along?
Hmm.. Not sure how radiosity works, but ... that would be the means to
do it. I've lit entire scenes with an ambient sphere before. It's slow
as molasses, but it does work.
Heh. I just started messing around with media. I've picked it up a few
time before and prodded at it, but never really attempted to get the
hang of it. It's certainly more tricky than radiosity.
Date: 1 Jul 2004 11:26:42
Message: <opsags3z08efp2ch@news.povray.org>
And lo on Thu, 01 Jul 2004 16:12:44 +0100, Phil Cook
<phi### [at] nospamdeckingdealscouk> did spake, saying:
> *in this way* :)
> sample along?
And it's driving me nuts :)
In theory I suppose you could back-track for ambient light from the camera
to the surface and use that as a ray to sample along I don't know if
that's how ambient light interacts with media in povray
//simple code
global_settings{
radiosity{media on}}
//switch these round for comparision
//light_source{z*12 rgb 1}
cylinder{0,z*5 1 pigment{rgb 1} finish{ambient 1} translate z*10}
cylinder{0,z*7 8 pigment{rgbt 1} translate z*8 hollow
interior{media{scattering{3, rgb 0.1}}}}
//end code
note that if you lower the scattering rgb the ambient cylinder appears
brighter and vice versa, which indicates something is being altered by the
media, but you don't get the spread light effect as with the light-source.
Anyone know?
Phil Cook
