POV-Ray : Newsgroups : povray.general : Subtle change in agate btw. 3.5->3.6? Server Time
1 Feb 2026 09:17:10 EST (-0500)
  Subtle change in agate btw. 3.5->3.6? (Message 1 to 10 of 17)
Subject: Subtle change in agate btw. 3.5->3.6?
Date: 22 Jun 2004 05:19:26
Message: <40d7f99e$1@news.povray.org>
Hi there!
Somehow I got the impression that the brief list of changes btw.
versions 3.5 and 3.6. on http://www.povray.org/download/features/ might
possibly be not too exhaustive...
OK, here's what I observerd: I am using POV-Ray for Windows as external
rendere for some kinda Myst-style 3D adventure game experiment. To this
end, I created a landscape based on a height field which uses the agate
pattern as underlying function (actually I more or less copied the code
from the scenes/advanced/landscape.pov demo file). I also randomly
placed a bunch of ellipsoids ("pebbles") onto the landscape. The
pebbles' x- and z-coordinates are created randomly, and the
corresponding y-coordinates are calculated by using the trace() function
in order to determine the height field's actual height at the pebbles'
x- and z-positions. To circumvent the need for going through the
time-consuming pebble creation process over and over again, I calculated
the pebble positions only once and stored them into an include file.
Now after switching from version 3.5 to 3.6 the pebbles suddenly began
to hover over the ground! Looks sort of mystic, but that's not what I
actually intended... ;-)
When re-running the pebble position calculation under 3.6, everything is
fine again -- the pebble's y-coordinates, however, really have changed
when compared to the include file created with 3.5!
So does anyone know what might be the reason for the observed
discrepancy? A change in how the agate function gets calculated? How
height fields get smoothed? Or how the trace function determines
intersections?
I wouldn't mind sticking with version 3.5 for now, it's just for the
sake of curiousity...
Thanks for any comments --
	Torsten
Subject: Re: Subtle change in agate btw. 3.5->3.6?
Date: 22 Jun 2004 05:55:02
Message: <cb8vjd$2u1$1@chho.imagico.de>
Torsten Crass wrote:
> Hi there!
You are probably using noise_generator 3, see:
Subject: Re: Changed media
Date: Sun, 13 Jun 2004 11:55:51 +0200
Newsgroups: povray.binaries.images
Apart from that i am not aware of any significant differences in
patterns.  If you post the code a more definite answer would be possible.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 22 Jun 2004 06:02:22
Message: <40d803ae@news.povray.org>
I'm curious, has it been discussed or explained why noise_generator 3
was changed in POV-Ray 3.6? And why isn't it in the list of changes?
Rune
rune|vision:  http://runevision.com **updated Apr 27**
POV-Ray Ring: http://webring.povray.co.uk
Date: 22 Jun 2004 06:20:01
Message: <cb90ta$347$1@chho.imagico.de>
This changed quite late in 3.6 development, probably as an unintended
side effect of a different change.  Note that NG 3 was always considered
as experimental (and still is) due to the regularities and the sad thing
is we now have an incompatibility without fixing this problem.
I assume it might be possible to track down the relevant change and
restore the previous behaviour (but don't take my word on this) but
since 3.6 is now released this would just introduce additional
confusion.  My suggestion would be not to use NG 3 at the moment.
Date: 22 Jun 2004 08:11:48
Message: <40d82204$1@news.povray.org>
Hi Chris,
well, I didn't actually change the global noise_generator setting, so it
should be type 2 (the default, at least according to both
documentations) in either case, shouldn't it?
OK, here comes some sample code (instructions below):
---8<---
// Set this to 1 to recalculate pebble positions and
// to store pebble definitions in "pebbles_test.inc";
// set to 0 to re-use previously generated pebbles file.
#declare recalculatePebblePositions = 1;
#include "transforms.inc"
#include "strings.inc"
// agate-based height field object
#declare Terrain =
height_field {
   function 200,200 {
       agate
       color_map {
         [0.0 color rgb 0.0]
         [0.3 color rgb 0.2]
         [0.7 color rgb 0.8]
         [1.0 color rgb 1.0]
       scale 0.5
       turbulence 0.1
   smooth
     pigment { color rgb <0.2, 0.8, 0.0> }
   translate <-0.5, 0, -0.5>
   scale <10000, 1000, 10000>
   translate <-500, 0, 0>
// This macro creates ellipsoids located randomly
// at the height-field's surface and stores their
// definitions in a file named "pebbles_test.inc"
#macro makePebbleFile()
   #fopen F "pebbles_test.inc" write
   #local randSeed = seed(1);
   // make 3000 pebbles
   #local i = 0;
   #while (i < 3000)
     // the height field's surface normal at the
     // intersection point; simultaneously a flag
     // for "intersection found" according to
     // documentation of trace function
     #declare intersectionNormal = <0, 0, 0>;
     // a parameter combining the height field's height
     // and slope at the intersection point
     #declare heightSlope = -1;
     // randomly create the pebble's x- and z-coordinate
     #local pebbleX = (rand(randSeed) - 0.5)*10000;
     #local pebbleZ = (rand(randSeed) - 0.5)*10000;
     // calculate intersection of a ray originating at the pebble's
     // x- and z-coordinates and propagating into y direction with
     // the height field
     #declare intersectionPoint = trace(Terrain, <pebbleX, 0, pebbleZ>,
y, intersectionNormal);
     // if an intersection was found, intersectionNormal should
     // contain the height field's surface normal at the intersection point
     #if (vlength(intersectionNormal) !=0)
       // calculate "degree of horizontalness"; s is
       //   0 at a horizontal plateau,
       //   1 at a vertical wall,
       //   2 at a horizontal overhang
       #local s = 0.5*(vdot(-intersectionNormal, y)+1);
       // relative height of intersection point
       #local h = intersectionPoint.y/800;
       // combination of horizontalness and height;
       // is low if both horizontalness and height are low.
       #declare heightSlope = s + 0.8*h;
     // if not too high and not too steep...
     #if ((heightSlope >= 0) & (heightSlope < 0.25))
       // set size to random values
       #local pebbleSizeX = rand(randSeed)+0.2;
       #local pebbleSizeZ = rand(randSeed)+0.2;
       // ensure the pebble is not higher than wide
       #local pebbleSizeY = rand(randSeed)*(min(pebbleSizeX,pebbleSizeZ));
       // combine individual size values into scaling vector
       #local pebbleSize = <pebbleSizeX, pebbleSizeY, pebbleSizeZ>;
       // now write to file the definition for a sphere scaled to size
vector...
       #write (F, "sphere { 0 20 texture {pigment { color rgb <1.0, 0.8,
0.5>} } scale ",VStr(pebbleSize))
       // ...rotated around y axis for a random angle...
       #write (F, " rotate y*",str(rand(randSeed)*360,0,0))
       // ...ensure it lies flat on a sloped surface...
       #write (F, " Point_At_Trans(",VStr(intersectionNormal))
       // ...and translate to determined intersection point
       #write (F, ") translate ",VStr(intersectionPoint)," +
y*",Str(pebbleSizeY),"/2 }\n")
       // another pebble has been placed
       #local i = i + 1;
   #fclose F
// introduce height field into scene
object {Terrain}
// if requested, re-calculate pebble positions
#if (recalculatePebblePositions)
   makePebbleFile()
// include previously calculated pebble positions
#include "pebbles_test.inc"
// blue sky
sky_sphere {
     gradient y
     color_map {
        [0.5 color rgb <0.8, 0.9, 1.0>]
        [1.0 color rgb <0.5, 0.8, 1.0>]
     scale 2
     translate -y
// we are standing somewhere in the landscape,
// looking south-south-east
   location  <-2000, 200, 0>
   up        y
   right     x*4/3
   look_at   <-1000, 0, -2000>
   angle 80
// main light
light_source { <100000, 100000, -100000>
   color rgb 1
// additional ambient light
light_source { <-100000, 100000, 100000>
   color rgb 0.5
   shadowless
---8<---
To reproduce the "hovering pebbles" effect, do the following:
1. Set recalculatePebblePositions to 1 (line 4)
2. Run the script using PovWin 3.5
3. Change recalculatePebblePositions to 0
4. Re-run the script using PovWin 3.6
See what I mean? ;-)
Regards --
	Torsten
Date: 22 Jun 2004 11:10:02
Message: <cb9hs6$67o$1@chho.imagico.de>
> Hi Chris,
That is more likely a difference in the way the function image type
works.  Since your heightfield is realtively low resulution such a
difference shows up more strongly than usual.  You could try using an
isosurface instead and see if it also leads to a difference - probably not.
Date: 22 Jun 2004 11:18:58
Message: <40d84de2$1@news.povray.org>
I see. Still funny it's not mentioned in the "changes from 3.5 -> 3.6"
list since it apparently isn't a mere bug fix or speed improvement.
Yep, I will try this, thanx. I hope it won't render significantly slower...?
	Torsten
Date: 22 Jun 2004 11:40:02
Message: <cb9jqa$6gk$1@chho.imagico.de>
I don't remember the details but it probably is a change to make the way
function images work more consistent.  I would not call it a bugfix
although IIRC there have been complaints that function images don't work
as expected in the past.
Date: 23 Jun 2004 13:30:56
Message: <40d9be50@news.povray.org>
In article <cb9jqa$6gk$1@chho.imagico.de> , Christoph Hormann
No, you are wrong here:  We fixed a long-existing bug in height-field
smoothing that is mentioned in the release notes (iirc).  In short,
height-field smoothing did not work correctly before and thus now is looks
"different" compared to older versions of POV-Ray because those versions
were simply buggy.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 23 Jun 2004 14:30:03
Message: <cbchvs$lmo$1@chho.imagico.de>
> were simply buggy.
That does not sound reasonable to me, the smoothing change would only
influence the normal vector returned by trace(), not the intersection
point.  The difference Thorsten Crass observed is in the intersection
points and not only in the normals.
