POV-Ray : Newsgroups : povray.general : A NORMAL BUG in 3.6 final... Server Time
22 May 2026 09:34:42 EDT (-0400)
  A NORMAL BUG in 3.6 final... (Message 1 to 7 of 7)
Subject: A NORMAL BUG in 3.6 final...
Date: 10 Jun 2004 13:07:10
Message: <40c8953e@news.povray.org>
This bug is not corrected in last version of POV-Ray, why?
plane {
  y, 0
    pigment { color rgbf <0.2, 0.2, 0.2,0.9> }
     finish { reflection 0.3 diffuse 0.2 specular 0.2}
        normal { cells scale 0.5 }
    normal { hexagon
      normal { agate 3 scale 0.7 }
      normal { cells 3 scale 0.2 }
Subject: Re: A NORMAL BUG in 3.6 final...
Date: 10 Jun 2004 14:11:45
Message: <40c8a461$1@news.povray.org>
Because you did not report it properly at all?  You should have read the
thread with replies to your message in povray.binaries.images, then you
would know.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 10 Jun 2004 16:01:34
Message: <40c8be1e@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> ???????/???????? ? ????????
?????????: news:40c8a461$1@news.povray.org...
> would know.
>     Thorsten
> Thorsten Froehlich
What is the different how i report, the bug is in the source, and you as a
member of Pov-Team can correct it. I send the report to bug-reports section,
but it is moderate, and even now i can not see the report there. I think,
correct this small bug is not very hard(maybe i am not right). At all, i
only want to see a POV-Ray in perfect form, and as a perfect instument for
all us.
IkA.
Date: 10 Jun 2004 16:50:02
Message: <caahhd$rie$1@chho.imagico.de>
> all us.
What you post is not even approximately what could be understood as a
bug report.  It would resuire at least:
- a clear description of what you wanted to achieve with the code you
posted.
- a clear description of what result you get (render result, error
message or whatever else).
- what you expected to happen instead.
- the usual rest (see 'bug reporting' in p.a.f-a-q.): version of
POV-Ray, platform, ...
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 10 Jun 2004 22:57:11
Message: <8r7ic0t5su39enghvmf8i902l2o0hkei38@4ax.com>
  Hi, IkA.  I would have replied had you supplied a valid e-mail
address.  Here is your 'bug report':
>To: bug### [at] povrayorg
>Subject: FULL CRASH ON 3.6RC1 !!!
>From: "IkA" <ixi### [at] ntplxpovrayorg>
>Date: Sun, 6 Jun 2004 15:50:08 +0400
>A code:
>plane {
>  y, 0
>  texture {
>    normal { hexagon
  As others have pointed out, it is an incomplete report.  We appreciate
your taking the time to send a report but we need all of the information
outlined in the post, "How to post bug reports" in the group
povray.announce.frequently-asked-questions.
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 11 Jun 2004 08:31:27
Message: <40c9a61e@news.povray.org>
This is generally correct for bug reports.
I'm sure, IkA understood to follow what Christoph's post was saying
for his next bug report.
However, in this special case, we do not need to discuss this issue
any more here and no additional information is needed.
The bug is a null pointer deref; see my post in p.programming.
Wolfgang
Date: 11 Jun 2004 08:57:35
Message: <40c9ac3f@news.povray.org>
  You have to understand that the pov-team doesn't have the time to
jump to the source code and start searching for "bugs" based on some
random post saying "this doesn't work" which doesn't give enough
information about anything. That's why there's a proper bug-reporting
protocol.
  Also, possible bugs are usually first discussed and after there's
a consensus that it really is a bug, then it's taken as a genuine
bug report and will be looked in a certain timeframe (allowed by
the team's time schedule).
  If it is a genuine bug, be certain that it will be fixed in a future
version of POV-Ray.
