POV-Ray : Newsgroups : povray.general : Is anybody interested in beta testing JPatch (a 3d modeler)? Server Time
18 Aug 2025 12:26:52 EDT (-0400)
  Is anybody interested in beta testing JPatch (a 3d modeler)? (Message 1 to 10 of 12)
Subject: Is anybody interested in beta testing JPatch (a 3d modeler)?
Date: 6 Jun 2004 07:40:37
Message: <40c302b5$1@news.povray.org>
I hope this isn't too off-topic :-)
I'm about to release a new version of my 3d modeler, JPatch (version
0.3), but before releasing a public beta I'd like to get some feedback
from peoble who've got expirence with sPatch, hamaPatch or
Animation:Master, and of course POV-Ray ;-)
JPatch is open source, written in Java (tested on Windows, Linux and OS
X), and can export to POV-Ray and RenderMan. The new (but yet "hidden")
homepage for the new version can be previewed here:
http://www.jpatch.com/new/
If you're interested, please register to the forum - up to date
information on how to download the latest development snapshot can be
found in the "Beta" forum.
Thanks a lot!
-Sascha Ledinsky
Subject: Re: Is anybody interested in beta testing JPatch (a 3d modeler)?
Date: 8 Jun 2004 22:59:54
Message: <40c67d2a$1@news.povray.org>
One thing I'd like to do is to import a large handful of points in ASCII or
really in povray 3.5 SDL.  Then model away, having these points sitting out
there in space.  It would actually be the skeleton joints for my "blob
characters", only I'd instead be modelling with patches.
"Sascha Ledinsky" <sas### [at] opensyscoat> wrote in message
news:40c302b5$1@news.povray.org...
> Thanks a lot!
> -Sascha Ledinsky
Date: 9 Jun 2004 04:50:27
Message: <40c6cf53$1@news.povray.org>
Until now I focused on modeling. Animation (and thus a skeleton) is next
on my list.
Parsing POV-code is a bit tricky, but JPatch's file-format is XML based
now, and so the skeleton (once implemented) will be saved/loaded as XML
code too - so you could write a little e.g. perl script which parses
your pov blob-character and exports it in JPatchs's XML format...
Right now you could render orthographic views for front, side and top
views of your skeleton in POV-Ray and use the images as background
(rotoscopes) in JPatch...
-sascha
Date: 9 Jun 2004 13:23:06
Message: <40c7477a$1@news.povray.org>
>> ASCII or
>> sitting out
> on my list.
> -sascha
this should also work for an aircraft front, side and plan views, yes ?
perhaps you could explain 'rotoscopes' more fully
i've had a play with the beta, but i'm a total newbie with this program.
what i have noticed is the seeming lack of functionality compared with
version 2.x.x
what aspect of the beta do you particularly want looking at?
stephen
Date: 9 Jun 2004 15:24:50
Message: <40c76402$1@news.povray.org>
Sure, but the main focus of this program is character animation
(although there are _NO_ animation features implemented yet! :-/ )
It's easy to model "organic" shapes, but it lacks some features needed
to model e.g. architecture (and perhaps aircrafts too) - e.g. there's no
CSG or something like that.
In classical animation, a rotoscope projected previously shot live
action footage onto the animators drawing board, who could then simply
trace the projected shape.
In CG a "rotoscope" is just another term for background image, and it's
used for the same puropse.
> version 2.x.x
It's a complete rewrite, so it can't really be compared to version 0.2.
I'm about to add the last missing features before "officially" going
beta. If you're refering to the "add shapes" feature to create
primitives like spheres, etc - This isn't implemented yet, but it isn't
that important, because you can achieve the same effect easily by using
the lathe or extrude tool.
If you're refering to the different "layers" - I've abandoned that
concept - the new version allows to store an unlimited number of
selections, and you can hide all unselected points now.
Firstly bugs :-( If it locks up, messes up something, a change isn't
undoable, if it outputs any error messages (stack traces) on the
console, etc.
This page shows known bugs and missing features (the features marked as
"high priority" will be implemented in the "official" beta release)
http://www.jpatch.com/status.html
And of course any kind of feedback, ideas, feature requests, etc.
I've done some modeling to test it, here's my first try in modeling a
head: http://www.jpatch.com/new/?page=gallery - it's done entirely with
the latest development version and I haven't encountered any new bugs so
far, but I'm almost sure that they are hidden somewhere :-)
> stephen
Thanks for taking your time!
-sascha
Date: 10 Jun 2004 16:28:38
Message: <40c8c476$1@news.povray.org>
dear Sascha Ledinsky
well i found one undo that didn't work, the new button is not undoable
it only took me 2hrs to get the mesh in via multiple images in rotorscope
a feature that would be useful to me, would be too be able to 'hide' bits
explanation - i have a number of cross-sections as jpeg images
image1 as rotorscope in xy view, add a spline in great detail - ie the
max points i can have patience with
now extrude 'number of images' times along z
select 2nd extrude, set image2 as rotorscope
problem is selecting correct point - so i rescale in xy locking z
then i drag points to the new image outline
currently i try to keep the radial direction constant to avoid skewing
of the surface
being able to import other spt files would be nice, and being able to
specify an offset (x,y,z) even nicer
would it be possible to select a spline, in my case a cross-section,
and then further selecting a datum point for top point, select a second
point as a radial center, adjust the number of points in the spline ie
select a cross-section, further select the point on the center line and
enter NN (say 60), the spline is the sub-divided to provide 60 points
spaced at 6degres around the spline
being able to 'undisplay' the other extruded sections would be useful
and being able to 'hold constant plane' would be nice
i'm having a terminalogy problem with this, perhaps you understand what
i mean though
also it would be exceedingly useful to be able to import version 2 spt files
and maybe save as spt2 from v3 ?
(my logic is you probably already have most of the code :-)
as you've gone the xml route, would you consider importing paths from
gimp version 2, they save as svg(??) format
implementing that lot should keep you busy :-)
only if you think they're useful suggestions
stephen
Date: 11 Jun 2004 03:31:50
Message: <40c95fe6$1@news.povray.org>
You're right, I'll add a warning dialog.
It's implemented in the latest development version.
About extruding: Perhaps the X/Y/Z lock buttons can help.
I have also thought about a "rail extrude" feature, which would extrude
a curve along another one, or even "bi-rail extrude" (to extrude a curve
along two other curves, to create e.g. the hull of a ship), but these
features won't make it into the current version...
> files
Importing is implemented (in the file/import menu). Someone already
suggested that it should be smart enough to guess the file type from the
extension :) ...
Exporting is tricky, as sPatch neither supports hooks nor five-sided
patches.
I've no expirence with gimp, what is a path and what is it used for?
I'll continue to improve the modeler, but will also focus on animation
features...
> stephen
Thanks a lot!
-sascha
Date: 11 Jun 2004 15:02:22
Message: <40ca01be@news.povray.org>
> end
>> files
> extension :) ...
> patches.
> features...
>> stephen
> Thanks a lot!
> -sascha
no doubt someone with more gimp experience tha I will correct me if I'm
wrong
a path in gimp is a bezier spline and can be exported, in version 2 its
exported in svg format, which i believe is xml based
in version 1.2.x gimp, it was a different format and there exists
gimppath2pov.py python script to convert it to *a pov inc file
the
  cat is nuzzling the keyboard+
-*numpad+
end
stephen
Date: 11 Jun 2004 16:42:24
Message: <40ca1930@news.povray.org>
not tried this yet :-)
just pulled the devel version , about reports
JPatch experimental version pre0.3
compiled Wed Jun 09 16:04:06 CEST 2004
please find attached weird.spt, simple spline? extruded in side view
with y locked, by selecting block, press 'e', move centre yellow block
far right of window, otherwise it don't seem to let me move anything,
then drag top right side yellow corner to right, repeat a few times
it seems to scale for some reason, prob me getting it wrong
secondly at some point in the proceedings (number 3 or 4 extrude?) a
whole bunch of lines appeared between spline points and somewhere
outside top left corner of window.
snap to grid seems permanently enabled, is there another option apart
from grid spacing i've missed, enable/disable snap to grid?
stephen
Date: 11 Jun 2004 16:49:34
Message: <40ca1ade$1@news.povray.org>
thanks
again thanks
roll on version 0.4, 0.5, .....  1.00 :-)
>> files
sorry didn't realise it was 'spatch' file format, thought it was jpatch's
am i correct in thinking 0.3 saves in something xml'ish
and its diff to 0.2's ?
  stephen
