POV-Ray : Newsgroups : povray.general : changing output file in script Server Time
23 Nov 2025 01:55:11 EST (-0500)
  changing output file in script (Message 1 to 8 of 8)
Subject: changing output file in script
Date: 13 May 2004 02:27:12
Message: <40a31540$1@news.povray.org>
First question: is there a way to change the output file name from
within a POV file... perhaps during a preprocessor directive? Doing it
from within an INI will not work either as I want the output file to
depend on the clock variable if possible.
Another question is if I can somehow access a list of files in a
directory. The purpose of this would be to put 100 different textures
into a directory and loop through rendering a single script/object but
using a different texture each time. Hopefully this could be done again
with the clock variable, if not, what is the best way to do this without
having to manually type in all the files one by one?
Subject: Re: changing output file in script
Date: 13 May 2004 08:00:02
Message: <c7vnnk$594$1@chho.imagico.de>
You are probably trying to do something really ugly that would better be
  done in a different way.  The clock variable can't be set from within
the POV-SDL file so there is no reason to set the output file name
depending on it from there either.  Both can only be specified as
command line/ini file options.
There are dozens of possible ways to accomplish this, the most simple
probably is (as shell script, should be possible as Windows batch file
as well):
for TEXTURE in *.jpeg ; do
   echo "#declare TEXTURE_FILE=\"$TEXTURE\"" > image_file.inc
done
Where scene.pov of course #includes image_file.inc and uses TEXTURE_FILE
then.
Using the internal animation loop of POV-Ray would be possible as well
but somewhat more complicated (generating an array of image file names
would be possible as well as writing a file list to be read via #read).
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 13 May 2004 11:05:01
Message: <web.40a38d9ea683fab02e6949d0@news.povray.org>
Off-topic; sorry about this.
Sally, I couldn't get your email to work, so here is the letter:
http://www.geocities.com/fcmodelview/sally.txt
Date: 13 May 2004 18:01:42
Message: <40a3f046@news.povray.org>
I dont need to change the clock variable in the .pov file, its changing
normally as I want it, but I want the texture to depend on it. I could
have a huge "switch" like statement with each filename, but then it
doesn't adapt to each file automatically.
And I'd prefer not to use batch files but its so far the only solution I
have seen (and ty for that solution by the way).
Date: 13 May 2004 19:06:10
Message: <fqv7a0t316tuf6ru6mkq2lspg4qpv5dl5d@4ax.com>
On Thu, 13 May 2004 15:59:43 -0600, "Sally"
Would something like this do?
#declare Cycle02_Max = 120;   //      Number of textures in the cycle.
#declare F_Name = "My_Texture_"       ;       // Base name of your
Texture
#declare Cycle02Pos =  mod (frame_number, Cycle02_Max);
// This should repeat the cycle if the number of frames is a multiple
of the number of textures.
#declare
Texture_clock=concat(F_Name,str(int(Cycle02Pos),-1,0),".txt");
box {
    <-1, 0,   -1>,
    < 1, 0.5,  3>
      Texture_clock
Where
My_Texture_01.txt
My_Texture_02.txt
My_Texture_03.txt
Etc.
Is the list of textures
I use this sort of logic to create animations with sequentially
numbered meshes. Actually I do the opposite to what you want. One
texture for different objects.
I've not tested this as I'm running an animation.
Regards
Date: 13 May 2004 19:12:28
Message: <40a400dc@news.povray.org>
Sally nous apporta ses lumieres ainsi en ce 2004/05/13 17:59... :
Name your images files with names such as: Pic00.png, pic01.png ...
In your cene, use a string concatenation: #local PicName =
concat("Pic",str(int(clock *100),-2,0),".png");
//I put the int() to ensure strictly integer values.
//I use a lenght of -2 in the str() to pad to 2 characters with leading 0s.
Then use PicName in your texture.
It should use your images in sequance, one per frame for your 100
frames. If you change to 200 frames, each images will be used twice. If
you use less frames, then some images will be skipped.
Date: 14 May 2004 04:10:02
Message: <c81uol$21i$2@chho.imagico.de>
What does this have to do with changing the *output* file name from
within the scene?
As said you can use the internal animation loop but you would need to
handle the list of image files you want to read somehow (either via
#read function or as an array of strings)
Date: 14 May 2004 06:05:13
Message: <40a499d9$1@news.povray.org>
Christoph Hormann nous apporta ses lumieres ainsi en ce 2004/05/14
04:07... :
> within the scene?
If you do an animation, then POV Ray will sequantialy change the image
file's name by apending a number to the name.
> Christoph
Or construct the name by concatenation using the clock value.
