POV-Ray : Newsgroups : povray.general : render time error Server Time
12 Sep 2025 15:58:23 EDT (-0400)
  render time error (Message 1 to 5 of 5)
Subject: render time error
Date: 28 Feb 2004 11:37:18
Message: <4040c3be$1@news.povray.org>
I am getting a render time error "too many nested textures".  Can anyone
explain what is happening?  How many are too many, and what does POV
consider to be a nested texture?  Afaik, I am not using syntax such as :
			transparent
What I am doing is:
union {
	mesh {
			transparent
	mesh {
			transparent
	... many many of these
But it seems odd that it happens at render time.
Thanks.
-Jim
Subject: Re: render time error
Date: 28 Feb 2004 12:01:04
Message: <cjameshuff-F4C3AD.12015828022004@news.povray.org>
In article <4040c3be$1@news.povray.org>,
It appears to be something to do with warping normals, something that
was added after 3.1. My first guess is that earlier versions didn't warp
normals when the texture was warped...this code was written to fix it,
but the programmer was lazy and it can only handle 100 textures at once.
It refers to nested texture evaluations, not nested textures...I'm
guessing you'll hit it if you have a chain of more than 100 evaluations
of transparent patterned textures along a ray.
http://tag.povray.org/
Date: 28 Feb 2004 13:47:06
Message: <4040e22a$1@news.povray.org>
Thankyou Christopher.  That makes sense. I think.  By normals you are
refering to the normals of the triangles in the mesh.
If I have:
mesh {
	triangle {}
	triangle {}
	triangle {}
	triangle {}
	texture a
Is that one evaluation, or up to four?
Date: 28 Feb 2004 13:49:34
Message: <4040e2be$1@news.povray.org>
>>> anyone explain what is happening?  How many are too many, and what
>>> does POV consider to be a nested texture?  Afaik, I am not using
>>> syntax such as :
>> warp normals when the texture was warped...this code was written to
>> fix it, but the programmer was lazy and it can only handle 100
>> textures at once. It refers to nested texture evaluations, not nested
>> textures...I'm guessing you'll hit it if you have a chain of more than
>> 100 evaluations of transparent patterned textures along a ray.
> If I have:
> mesh {
>     triangle {}
>     triangle {}
>     triangle {}
>     triangle {}
>     texture a
The reason I am curious is that I don't see how what I am doing is
significantly different form techniques that make foliage for trees by
using mesh with image_maps
Date: 28 Feb 2004 15:12:08
Message: <cjameshuff-4D5D97.15130228022004@news.povray.org>
In article <4040e22a$1@news.povray.org>,
No, I'm talking about texture normals. You have four triangles, so a ray
could intersect with four surfaces. If those surfaces have a non-solid
texture and have a warp (including any transformation), the code will do
up to four normal warps. More complex textures (for example, one with a
texture_map) will need to do more. I'm not really sure why the code was
written the way it was...but the nesting is from the point of view of a
ray progressing into the scene, not a nesting in the scene specification.
