POV-Ray : Newsgroups : povray.general : Some aid in physics required... Server Time
2 Mar 2026 12:06:54 EST (-0500)
  Some aid in physics required... (Message 1 to 10 of 41)
Subject: Some aid in physics required...
Date: 23 Feb 2004 11:32:04
Message: <403a2b04$1@news.povray.org>
I'm stuck: my new I/O Particle-System uses adaptive iteration to calculate
the path for a particle, along with object interaction. Now, when Particles
would normally roll on a surface, they oscillate heavily in my System:
Gravity pulls them down, object interaction puts them back on surface, only
the speed perpendicular to the surface-normal is retained. Thus, a particle
won't slow down when rolling along plane, but it will "hop" on the surface
hundreds of times (two of my particles reached more than 2500 iterations
that way...).
To avoid this, I want a particle to switch to "Rolling" when enough
iterations have been done, and thus the particle will just get moved along
the surface without "real" interaction. Now, if I'd just be dealing with a
plane, that'd be no problem, but since particles may also roll uphill, I
want to calculate how much velocity they'd lose when doing that. I know the
angle of the surface, the initial velocity and the distance the particle
will travel, now what's the formulae to calculate how much velocity is lost?
For simplicities sake, use a ball with 10km/h that starts rolling a 45
degree upward slope for 10 meters. Gravity is 10m/s. What'd be the velocity
after 5 meters? What's the formula for that?
Links, direct answers, anything will do. I've tried googling, but it seems
I'm using the wrong keywords...
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Subject: Re: Some aid in physics required...
Date: 23 Feb 2004 12:21:06
Message: <403a3682$1@news.povray.org>
> Ignoring friction and rotational energy, you'd simply be checking that
> your potential energy matches your kinetic energy, wouldn't you? The
> formulae for both are pretty straightforward.
Ehm, yeah, sure... Point is: I can't find those formulae. That aside, I just
want the velocity approach, not energies etc, cause I don't know anything
else of that particle beside it's velocity. Might be that I'm talking BS
because I don't know which formulae you're talking about, but, for example,
I've got a few formulae like "Height after object is thrown with that slope
and that velocity with earth's gravity". What I want is something along the
lines of "Velocity after object is rolled up/down a slope with that angle,
velocity and gravity".
I'm in a rush now, but I'll check on your energy-clues when I'm back, might
be that they'll lead me to exactly what I was looking for.
Tim
"Tim Nikias v2.0"
Date: 23 Feb 2004 12:24:57
Message: <403a3769@news.povray.org>
1) Does the ball have an initial rotation?
2) Should it be completely rolling (or is partial sliding allowed)?
3) if 1=true and 2=false, is a direction of rotation that is not
   parallel to vcross(velocity,middleOfBall-pointWhereBallTouchesSurface)
   allowed?
If 3 is true, the solution can get quite complicated, I think.
Lutz-Peter
Date: 23 Feb 2004 12:33:59
Message: <403a3986@news.povray.org>
> just want the velocity approach, not energies etc, cause I don't know
> anything else of that particle beside it's velocity. Might be that I'm
> talking BS because I don't know which formulae you're talking about, but,
> for example, I've got a few formulae like "Height after object is thrown
> with that slope and that velocity with earth's gravity". What I want is
> something along the lines of "Velocity after object is rolled up/down a
> slope with that angle, velocity and gravity".
Kinetic energy: 1/2 * m * v^2
Potential energy: g * m * h
Total energy must be constant.
If the particle has velocity v1 at height h1, then at height h2 it should
have:
1/2*m*(v1)^2 + g*m*(h1) = 1/2*m*(v2)^2 + g*m*(h2)
1/2*m*(v2)^2 = 1/2*m*(v1)^2 - g*m*(h2-h1)
(v2)^2 = (v1)^2 - 2*g*(h2-h1)
v2 = sqrt[ (v1)^2 - 2*g*(h2-h1) ]
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 23 Feb 2004 12:40:57
Message: <403a3b29@news.povray.org>
This is the correct solution for a sliding (or slipping?
what is the correct term?) particle, but not for a rolling ball.
Lutz-Peter
Date: 23 Feb 2004 12:42:29
Message: <403a3b85@news.povray.org>
You could use the law of conservation of energy if you want:
Ek = m*pow(v,2)
Ep= F*Height , F = m*a
E = Ek + Ep == constant
where m is a mass, v is the velocity, a is the gravity acceleration and at
any time E must be constant in a frictionless system. This way, you can
alway tell what should eb the speed at any point without simulating.
In practice, you may want to apply mechanics equation like this
v(n) = v(n-1) - at
pos(n) = pos(n-1) + vt + 0.5a*pow(t,2)
where t is the time step, a is the length of the horizontal component of the
gravity acceleration (cos A if A = 0 for horizontal plane) given the normal
of the surface.
If you dig in the vectorial aspect of Newtonian mechanics (High school level
I think), you should be able to solve your rolling problem by assigning a
matching vector component to the normal of the surface the particule is
rolling on in the first place.
Hope this helps, as well as the other posts sent while I was writing
this(...)
bongo
Date: 23 Feb 2004 12:58:03
Message: <dgrpg1-tmb.ln1@triton.imagico.de>
ate
cles
only
icle
ace
s
> that way...).
ong
h a
I
 the
e
lost?
In a particle system you usually describe the particles as point masses
so they won't roll (rolling means rotation and a point can't rotate).
The effect you get (hopping) is pretty normal but it will diminish if
you add damping (just imagine a glass marble falling on a carpet floor
instead of a massive steel block).  Damping can be modelled in different
ways - you can either continuously diminish the kinetic energy or you
slow down the particles during every collision.
city
y
depends on the friction between the ball and the surface (if you really
want it rolling you also have to take the moment of inertia into account)
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 23 Feb 2004 14:10:08
Message: <403a5010$1@news.povray.org>
I'm not sure I understand...
If, every time the particle is pulled down by gravity, it is brough back
up immediately (before the positions are represented on the screen),
then why is the hopping visible in the animation?
And if it isn't visible, then what is the reason that you want to avoid
it?
Rune
rune|vision:  http://runevision.com **updated Jan 29**
POV-Ray Ring: http://webring.povray.co.uk
Date: 23 Feb 2004 14:46:35
Message: <403a589a@news.povray.org>
It's a quick "ad-hoc" solution I wrote assuming no friction and no
rotational energy :)
Date: 23 Feb 2004 17:53:24
Message: <403a8464$1@news.povray.org>
Which is what I'm after, thank you very much. It's too late now, gotta go to
bed, but I'll sort through that complex-looking formula and see what I can
do.
Tim
"Tim Nikias v2.0"
