POV-Ray : Newsgroups : povray.general : Accuracy and unit choice? Server Time
31 Mar 2026 04:42:32 EDT (-0400)
  Accuracy and unit choice? (Message 1 to 10 of 12)
Subject: Accuracy and unit choice?
Date: 12 Dec 2003 05:17:28
Message: <3fd995b8$1@news.povray.org>
Hi!
Is it mentioned anywhere in the docs how much the chosen scale affects
accuracy? I am doing a simple room modeling and chosen an expected scale
of 1 unit = 1 metre. I get a few artifacts  and it looks like if I
multiply everything by 10 or 100 it can get rid of those. The smallest
objects in my scene have dimension of about 0.005 units.
So what is the preferred scale or the smallest preferable dimension? How
can one ensure that POV-Ray can be the most accurate?
Severi Salminen
Subject: Re: Accuracy and unit choice?
Date: 12 Dec 2003 09:53:51
Message: <3fd9d67f$1@news.povray.org>
Hi Severi,
this is a problem I've suffered from too. For some
extreme examples (and some hints) see in povray.general:
   Intersection with quartic: bug?   3 Sep. 2002
   Small is NOT BEAUTIFUL           11 Feb. 2003
The reason for this behavior are some 'Epsilon' values in the
Pov-Ray code which are neccessary (in this way some overlap is
created at corners to make them 'watertight', without such overlap
it would  sometimes be possible to look inside objects at corners
due to limited numerical precision), but these 'Epsilons' are a
little large.
   Sputnik
Date: 12 Dec 2003 10:10:57
Message: <3fd9da81$1@news.povray.org>
> little large.
Thanks for the info. I actually tried and multiplied everything in my
secene by 100 so that the smalles dimension is now about 0.5 units and
largest is about 600 units and it looks like all the artifacts
disappeared. I also noticed some very slight changes with radiosity but
I believe the result is now more accurate.
In my opinion this is something that should be mentioned in the
documents (if it is: good, then forget this) - if any rule of thumb can
be given in this matter. People might spend too much time searching
coincident surfaces when the problem is somewhere else.
Severi Salminen
Date: 12 Dec 2003 11:54:15
Message: <3fd9f2b7@news.povray.org>
"Severi Salminen" <sev### [at] NOT_THISsibafi> wrote in message
news:3fd9da81$1@news.povray.org...
for a similiar type of problem, try (modify the plane's translation to, say,
0.002, to fix it):
#version 3.5;
  location  <0.0, 1.0, -5.0>
  look_at   <0.0, 1.0,  0.0>
plane{y,-0.001 pigment{checker pigment{Black}, pigment{White}}}
sphere{0,1
  translate y*1
  pigment{rgbt 1}
Date: 12 Dec 2003 17:22:08
Message: <wk8ylhad0o.fsf@oook.m.uunet.de>
Severi Salminen <sev### [at] NOT_THISsibafi> reports:
> [...] I get a few artifacts  and it looks like if
> I multiply everything by 10 or 100 it can get rid of those. The
> smallest objects in my scene have dimension of about 0.005 units.
Don't make your objects too big, though.
Consider the following scene.  It should show nine spheres, each
ten times further away and ten times the size of its predecessor.
POV-Ray 3.5 says:
    "Scene contains 9 frame level objects; 5 infinite."
Not only does POV-Ray consider objects of size 10000 and above as
infinite.  If I render the scene, I see only seven spheres...
#declare R  =  1;
#declare A  =  -20;
#macro S()
  sphere {0,R
    texture {pigment {bumps} finish {ambient 1} translate y}
    translate 5*R*z
    rotate    A*y
light_source {<10,10,-100> color rgb 1}
camera       {location 0  look_at z}
#while (A <= 20)
  S()
  #declare R  = R * 10;
  #declare A  = A +  5;
Some months ago I tried to add the moon to a scene, with "correct"
diameter and distance, given in metres.  It took me some time to figure
out why it wasn't visible at all....
Cheers,
haj
Date: 13 Dec 2003 06:07:39
Message: <3fdaf2fb$1@news.povray.org>
Exactly. It would be nice to know what are these bounds, and are they
fixed or somehow relative to each other.
Severi
Date: 13 Dec 2003 08:33:16
Message: <3fdb151c$1@news.povray.org>
In article <wk8### [at] oookmuunetde> , Harald Joerg
<http://tag.povray.org/povQandT/languageQandT.html#largescaleproblems>
e-mail: tho### [at] trfde
Date: 13 Dec 2003 08:34:25
Message: <3fdb1561@news.povray.org>
In article <3fdaf2fb$1@news.povray.org> , Severi Salminen
This information would only confuse you, and some issues brought up in this
thread are completely unrelated anyway.  I would recommend not to jump to
any conclusions based on what has been said or mentioned in this thread...
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 13 Dec 2003 08:54:58
Message: <3fdb1a32$1@news.povray.org>
Oh, please don't make any guesses what would confuse me or what would
not. I'd be very grateful if you could provide the information to
clarify this matter. I might even be able to understand it :)
And in addition: how much is this a platform/system architecture
dependent thing?
Severi Salminen
Date: 13 Dec 2003 10:46:06
Message: <3fdb343e@news.povray.org>
In article <3fdb1a32$1@news.povray.org> , Severi Salminen
The very fact that you ask the question implies the probability you can
understand it is low simply because you lack the background.  This
information is not going to be made available in a general manner.  It will
only result in confusion by those who don't understand the implications of
the information or the background.  You can easily find out the details by
taking a look at the source code:  If you cannot find it there on your own,
you won't be able to make use of anything anybody can tell you about it
anyway.
    Thorsten
