POV-Ray : Newsgroups : povray.general : linux and windows version produce different output Server Time
12 Jun 2026 11:48:39 EDT (-0400)
  linux and windows version produce different output (Message 1 to 10 of 13)
Subject: linux and windows version produce different output
Date: 12 Nov 2003 10:34:21
Message: <3fb252fd$1@news.povray.org>
When using the 'fresnel' keyword in reflections, Linux (Redhat 7.3) and Windows (2000)
versions of POV-Ray produce different output!
This phenomenon caused a strange flickering in an animation rendered on the IMP
render-farm (which uses clients with different OS), after some experimentation I
discovered that it is caused by the fresnel reflection.
I wrote a short scene to demonstrate the effect. An image showing both outputs was
posted to p.b.images (fresnel.jpg).
For me the windows output looks "right". Any ideas what could case this effect (a bug
in the linux version?), or is something wrong with my material definition?
Is there a "workaround"?
POV-Ray for Windows: Version 3.5.icl.win32
POV-Ray for Linux: Version 3.5 Unix (.Linux.gcc)
Looking at the statiscics shows that different numbers of rays were
reflected/refracted (see below).
Ok, here's the test-scene, I've rendered it with "povray -F +D +P +H216 +W384
test.pov" on both machines.
/*-------------------------------------start----------------------------------*/
global_settings {
        max_trace_level 8
#local glass = material {
                pigment { transmit 1 }
                finish {
                        specular 10 roughness 0.001
                        conserve_energy
                        reflection { 1 fresnel }
        interior {
                ior 1.5
                caustics 5
                fade_distance 1
                fade_power 2
        location <0,0,-15>
        look_at <0,0,0>
        up y
        right x * 16/9
light_source {
        <-100,100,-100>
        color rgb 1
difference {
        cylinder { <0,-5,0>,<0,5,0>,5.5 }
        cylinder { <0,-5,0>,<0,5,0>,5 }
        material { glass }
plane {
        -z,-10
        pigment { color rgb 1 }
        finish { ambient 0.5 diffuse 0.5 }
/*-------------------------------------end----------------------------------*/
Statistics from linux version:
Statistics for test.pov, Resolution 384 x 216
Pixels:           82944   Samples:           82944   Smpls/Pxl: 1.00
Rays:            855752   Saved:            213640   Max Level: 8/8
Ray->Shape Intersection          Tests       Succeeded  Percentage
Cone/Cylinder                  2757604         1257284     45.59
CSG Intersection               1378802          777524     56.39
Plane                          1378802          391676     28.41
Calls to Noise:                  0   Calls to DNoise:             10
Shadow Ray Tests:          1515460   Succeeded:               384732
Reflected Rays:             386404
Refracted Rays:             386404
Smallest Alloc:                 14 bytes   Largest:            12296
Peak memory used:           155640 bytes
Time For Trace:    0 hours  0 minutes  11.0 seconds (10 seconds)
    Total Time:    0 hours  0 minutes  10.0 seconds (10 seconds)
Statistics from windows version:
Statistics for F:\test\test.pov, Resolution 384 x 216
Rays:            917012   Saved:            223932   Max Level: 8/8
Cone/Cylinder                  2972274         1354663     45.58
CSG Intersection               1486137          841641     56.63
Plane                          1486137          432504     29.10
Shadow Ray Tests:          1638610   Succeeded:               416873
Reflected Rays:             424768   Total Internal:           15468
Refracted Rays:             409300
Smallest Alloc:                 25 bytes   Largest:            12056
Peak memory used:           153837 bytes
Time For Trace:    0 hours  0 minutes   7.0 seconds (7 seconds)
    Total Time:    0 hours  0 minutes   7.0 seconds (7 seconds)
CPU time used: kernel 0.08 seconds, user 6.87 seconds, total 6.95 seconds
Render averaged 11934.40 PPS over 82944 pixels
POV-Ray finished
Subject: Re: linux and windows version produce different output
Date: 12 Nov 2003 10:55:31
Message: <qjl4rvgch9e5m9qp3sbj9naogcgb27nmfq@4ax.com>
On Wed, 12 Nov 2003 16:34:21 +0100, sascha <sas### [at] userssourceforgenet>
wrote:
> reflections ... produce different output!
Well, icl is not gcc. Intel compiler could utilize dedicated CPU/FPU commands
related to single floats used as color components which determine
reflection/refraction.
ABX
Date: 12 Nov 2003 11:03:11
Message: <3fb259bf@news.povray.org>
Yes, but in this case the windows version shoots reflected rays where the linux
version does not,
and the results look completely different - the problem disappears if you change the
term
reflection { 0,1 fresnel }
to
reflection { 0,1 falloff 2 }
for example. In this case both versions produce absolute identical results...
Btw, in my test-scene the 'difference' produces coincident surfaces by accident, but
this is not related to the problem described, linux and windows versions output will
still look different if this is fixed...
-sascha
> ABX
Date: 12 Nov 2003 11:22:02
Message: <bs2a81-rin.ln1@triton.imagico.de>
> Windows (2000) versions of POV-Ray produce different output!
> the IMP render-farm (which uses clients with different OS), after some
> experimentation I discovered that it is caused by the fresnel reflection.
> outputs was posted to p.b.images (fresnel.jpg).
> effect (a bug in the linux version?), or is something wrong with my
To me the linux version seems right, it reflects the black background at
  areas where the reflection coefficient is high.  But in fact if i
should guess i'd say neither is correct.
The difference is most likely caused by a math function being called
with parameters out of the allowed range.  Math libraries of Linux and
Windows handle this differently.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 12 Nov 2003 11:29:42
Message: <24n4rvc7kdfgu7pamhd11ge2fl0t6opk2q@4ax.com>
On Wed, 12 Nov 2003 17:03:10 +0100, sascha <sas### [at] userssourceforgenet>
version does not
Somehow I missed 'fresnel' keyword, sorry. In case of 'fresnel' there was a
problem related to equation I also found. This is a line:
  g = sqrt(Sqr(ior) + Sqr(cos_angle) - 1);
in lighting.cpp (in determine_reflectivity()). For some cases (also official
benchmark) it caused evaluation of sqrt for negative values. Depending on
compiler it could behave different.
And this is _not_ fixed yet. Any ideas would be appreciated for sure.
ABX
Date: 12 Nov 2003 11:41:45
Message: <3FB262C9.6070200@free.fr>
	I quickly tested your script with the current developmental version
of POV-Ray under Linux (compiled with gcc 3.3.1) and obtain the exact same
statistics as your windows binary compiled with icl:
Image Resolution 384 x 216
	and the image looks like that you obtain under windows. On the other
hand, using a custom compile of 3.50c (with a gcc version I don't remember)
gives the same "wrong" image but with different statistics. I can't tell
whether it means gcc is the reason of these discrepancies. But at the end,
it seems that the next version of povray should give consistent results
between platforms  :-)  [well, the last post of ABX seems to pretend the
opposite though...]
	- NC
Date: 13 Nov 2003 03:30:01
Message: <web.3fb33fefdf2bb6e4ca7812b30@news.povray.org>
>ABX
That line appears to be calculating the cosine of the angle of refraction
from the cosine of the angle of incidence - you can derive the expression by
writing Snell's law of refraction in terms of cosines. Negative values in
that sqrt will correspond to total internal reflection, I think. I don't see
a simple solution (unless you trap internally reflected rays somewhere
already?)
Date: 15 Nov 2003 00:56:40
Message: <3fb5c018$1@news.povray.org>
That is cos(beta).
So if ior^2+cos_angle^2-1 < 0 total interreflection should occur.
But just setting F=1 would perhaps be the wrong solution (though it
would still be much better than the current situation), since
that would still be clipped to [reflectionmin, reflectionmax].
There are some other references to total interreflection in that file so
maybe this case is _supposed_ to be caught earlier?
Lutz-Peter
Date: 17 Nov 2003 13:00:01
Message: <web.3fb90bc3df2bb6e4541c87100@news.povray.org>
TIR certainly is caught (detected in Refract_Guts() and flagged by return
value through Refract() and BackTraceRefract()) and the proper arrangements
made for reflected rays in compute_backtrace_texture() and
compute_lighted_texture(). However, determine_reflectivity() is called
before all this in both of the compute_*_texture functions, so the
information isn't yet available when determine_reflectivity is called and
the Fresnel calculations made.
I have no idea what the best solution would be. Is it such a bad idea to
obey the user-specified reflection_min/max even in the case of TIR?
Date: 17 Nov 2003 17:38:07
Message: <3fb94dcf$1@news.povray.org>
After thinking about it, it is probably the best thing to do.
While it is not realistic to do so, it is also not realistic to use
reflection_min/max other then 0/1 for fresnel reflectivity, so the user
specifically asked for it...
Btw, IMHO the docs should mention that for realistic reflection, the
fresnel keyword should be used together with reflection_min/max of 0/1.
For someone who doesn't the fresnel function and/or it's implementation
in POV this isn't obvious.
Lutz-Peter
