POV-Ray : Newsgroups : povray.general : Laser lines Server Time
24 Nov 2025 00:28:37 EST (-0500)
  Laser lines (Message 1 to 9 of 9)
Subject: Laser lines
Date: 17 Jul 2003 04:10:52
Message: <3f165a0c$1@news.povray.org>
How can i create a realistic laser line?
So far I just managed to create it by passing red light through a thin
gap...the result is not really sufficient.
Regards
Subject: Re: Laser lines
Date: 17 Jul 2003 09:15:23
Message: <3f16a16b@news.povray.org>
"zorni" <zor### [at] gmxat> wrote in message
news:3f165a0c$1@news.povray.org...
> Regards
    I believe that the common solution is to use a cylinder full of emitting
medium.
Cheers!
Chip Shults
Date: 17 Jul 2003 11:50:01
Message: <web.3f16c49c9a8fede761b99e900@news.povray.org>
>news:3f165a0c$1[at]news.povray.org...
>> Regards
>medium.
>Cheers!
>Chip Shults
>My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
Or if you want to model it close to the way it works, a cylinder light
passing
through a scattering medium should work (but it would also likely be
slower...)
I'd use emitting media for 'laser guns' and cylinder-lights through
scattering
media for 'scientific' lasers, probably (and especially if I wanted to
bounce
them off of mirrors).
--Chris
Date: 17 Jul 2003 12:28:32
Message: <cjameshuff-F24872.11261417072003@netplex.aussie.org>
In article <3f165a0c$1@news.povray.org>, "zorni" <zor### [at] gmxat>
What exactly do you mean by "laser line"? A laser beam that is spread
out to make a long line on a surface, as is used in some laser levels?
The visible line of scattered light a laser makes when travelling
through a scattering medium? The radial lines you some times get when
you take a picture with the laser going into the camera?
In what way is this not enough? It's difficult to give a better solution
when you don't say why the old solution isn't good enough.
Assuming you want a laser beam through a scattering medium: the simplest
and most accurate way is with photons deposited in scattering media. The
optics.pov demo scene gives a good example of this. For a laser, it
would be better to use a parallel cylinder light instead of the
halogen-like spotlight in that scene, but the technique is the same.
http://tag.povray.org/
Date: 17 Jul 2003 12:31:49
Message: <3f16cf75$1@news.povray.org>
In article <3f165a0c$1@news.povray.org> , "zorni" <zor### [at] gmxat>
I suppose you want it to be visible?  Take a look at optics.pov that comes
with POV-Ray 3.5.
    Thorsten
Date: 30 Oct 2003 06:15:01
Message: <web.3fa0f1b69a8fede7e9df71c0@news.povray.org>
Christopher James Huff wrote:
>In article <3f165a0c$1[at]news.povray.org>, "zorni" <zor### [at] gmxat>
That's the problem I am interested in.
What would solve my problem: if there was an option similar to
"cylinder", but constraining the light to the space between two
parallel planes.
When sending light through a small gap the width of the projected
line depends on the distance to the light-source/gap.
thanks,
Wolfgang
Date: 30 Oct 2003 13:19:23
Message: <cjameshuff-AC9E2A.13172830102003@netplex.aussie.org>
In article <web.3fa0f1b69a8fede7e9df71c0@news.povray.org>,
Hmm...use an ordinary point light, and a negative light at the same
position using projected_through with a union of two planes. The
negative light will only illuminate parts of the scene on the other
sides of the planes, cancelling out the actual light on all parts of the
scene "inside" the union of planes.
light_source {Point, Color}
light_source {Point, -Color
    projected_through {
        union {plane {y,-0.1} plane {-y,-0.1}}
Date: 22 Nov 2003 17:00:02
Message: <web.3fbfd9e59a8fede7cf187cb30@news.povray.org>
>    projected_through {
great idea!
But there is a problem with shadows,
as can be seen in the scene below.
Is this a bug in povray?
thank you,
Wolfgang
camera {location <0,20,20> look_at <0,0,0>}
light_source {<-14,20,30> White}
#declare LaserPoint = <0,0,20>;
light_source {LaserPoint, Red}
light_source {LaserPoint, -Red
    projected_through {
        union {plane {y,-0.3} plane {y,0.3}}
cylinder
{ <0,-3,0>, <0,3,0>, 8 open
  pigment {Yellow}
triangle
{ <12,-3,0> <16,-3,0> <14,3,0>
  pigment {Yellow}
// background plane showing green shadows!
plane {z,-10 pigment{White}}
Date: 22 Nov 2003 18:43:16
Message: <cjameshuff-7574B6.18380322112003@netplex.aussie.org>
In article <web.3fbfd9e59a8fede7cf187cb30@news.povray.org>,
Not a bug. Objects do not shadow light from a projected_through light
until it hits the projected_through object. The light still comes from a
single point, so while the positive light is getting shadowed, the
negative light is constantly leaking through the projected_through
planes past the shadowing object. Parallel lights will partially fix
this problem:
    parallel point_at -z
    projected_through {
        plane {z, 20 clipped_by {union {plane {-y,-0.3} plane {y,-0.3}}}}
However, they introduce a new one...all light rays are parallel, rather
than originating from a vertical line. This will affect shading and
shadowing, but may not be noticeable. You could approximate a "spread"
light by using multiple spot lights combined with this technique...
