![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi all,
I was just messing around with media densities using various probability
densities for the electron in a hydrogen atom. These things are usually
done in radial coordinates because the math is simpler.
The conversion from cartesian to radial coordiates is simple enough, and
functions.inc even includes f_r, f_th, and f_ph to help--which leads me to
my question.
From my experience in physics, it is conventional to define theta as the
angle from the vertical axis (latitude, ranging from zero at the north
pole to pi at the south pole), and phi as the longitudinal angle (ranging
from zero to 2*pi).
POV, it seems, defines these in the opposite manner. I was hoping that
someone in the know could tell me whether this is a mistake, or if the
convention is simply less well-defined than I believed. After all, we
usually use z-up cartesian coordinates in physics, too. :)
Anyway, I'm just curious...if it really bothered me, I'd just define my
own conversion functions.
Thanks,
Ed
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
pan### [at] iastate edu...
> Hi all,
But pov uses a left hand coordinate system: x-right, y-up, z -ahead
Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well to be complete you can set direct right hand coordinate system with
sky z
up z
in your camera definition
Then build your scene in a right hand system
Marc
3ec7430d$1@news.povray.org...
> Marc
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As you correctly describe there is no conversion function from cartesian
to spherical coordinates in POV-Ray, you have to create your own (and can
use the mentioned built-in functions for that). Depending on how you use
them you get different types of coordinate systems. The formulas of the
f_r, f_th and f_ph function can be found in the docs so it should not be a
problem to create whatever function is needed with them.
When you don't get what you are trying to achieve you probably messed with
the axes or the value ranges of the functions.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If I get it right, it seems to me that the base of the problem is that
POVRay uses indirect coordinate system (left hand), but it is not enough
to take z as the up direction, you should take -z. In a direct
coordinate system (u, v, w), the w vector should see u->v in the
trigonometric way (which is counter clock). Putting "-" in the right
places in your formulas should do it.
JC
Ed Jackson wrote:
> Hi all,
> my question.
> from zero to 2*pi).
> Thanks,
> Ed
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>JC
Actually, you want up to be +z, to be consistent with physics. Depending on
whether you do x or y as the "right" axis, you would have the following:
up z, right x, direction y
or
up z, right y, direction -x
The latter of the two is nice in that it is just a basic rotation (i.e.
quandrant I is in the same location) of the right-handed POV-Ray system: up
y, right x, dir -z. Just replace x with y, y with z, and z with x.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You're right, of course (as are other replies to my post, thanks!), but
the radial coordinates should be independent of the cartesian ones. That
is, theta is defined as the angle from the positive vertical axis whether
you name that axis "y" or "z" or "Jean-Pierre".
However, it is the function f_ph which returns this value. I was just
curious why it was defined that way, and thought that perhaps the
definitions of phi and theta were not exactly universal--much like the
question of y-up v. z-up or right-handed v. left-handed cartesian coordinate
systems. (Again, I could call it "phi" or "theta" or "Franz" and it
woudld be the same thing...)
Anyway, it's not really important so long as you know what's coming out of
the functions. Thanks, everyone, for your replies.
-Ed
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <pan### [at] iastate edu>,
There are several conventions in use. Mathematics usually uses a
different convention (theta = rotation or longitude, phi = elevation or
latitude) than physics or engineering, which swaps the meanings.
Sometimes they are even completely reversed, like < r, theta, phi> or
<r, phi, theta>. You just have to watch out for what system is being
used.
http://mathworld.wolfram.com/SphericalCoordinates.html
> much like the question of y-up v. z-up or right-handed v. left-handed
> cartesian coordinate systems.
The former, but not the latter. Right handed and left handed systems are
both well defined mathematically, it's their usage (like which dimension
is "up") that is disputed. For example, in the case of computer 2D
graphics, you already use "y" for height and "x" for side to side, so
"z" for depth is the simplest way to extend things to 3D.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
