POV-Ray : Newsgroups : povray.general : Bug: final_frame not working as described in docs... Server Time
23 May 2026 10:02:38 EDT (-0400)
  Bug: final_frame not working as described in docs... (Message 1 to 10 of 11)
Subject: Bug: final_frame not working as described in docs...
Date: 2 Apr 2003 09:29:44
Message: <3e8af3d8$1@news.povray.org>
In the docs, it says following:
6.1.3.4.2
final_frame
This identifier reads the value set through the INI file option
Final_Frame=n or the command-line switch +KFFn.
But, in effect, final_frame returns the last frame rendered.
For example this:
+KFI1 +KFF150 +EF19
would return 19 for final_frame, instead of 150.
Is this behaviour correct and described wrong in the docs, or
the behaviour wrong and described correct in the docs?
I'm using POV-Ray for Windows 3.5, on Win98, 1.4GHz Athlon, 768 MB RAM.
Any confirmations?
Tim Nikias v2.0
Email: Tim### [at] gmxde
Subject: Re: final_frame not working as described in docs...
Date: 2 Apr 2003 09:32:01
Message: <3e8af461$1@news.povray.org>
Oh, here's minimum source:
//+KFI1 +KFF3 +EF2
#debug concat("final_frame:",str(final_frame,0,0),"\n")
Put the comment into the commandline.
Tim Nikias v2.0
> 6.1.3.4.2
> final_frame
> For example this:
> +KFI1 +KFF150 +EF19
> Any confirmations?
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
Date: 2 Apr 2003 15:38:39
Message: <3e8b4a4f$1@news.povray.org>
In article <3e8af461$1@news.povray.org> , "Tim Nikias v2.0"
> //+KFI1 +KFF3 +EF2
It used to work this way in MegaPOV 0.x before, and everybody was fine with
it, so I guess the current behavior is what is desired, but I don't know.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 2 Apr 2003 16:10:41
Message: <3e8b51d1$1@news.povray.org>
If it is the desired method, I think it would be
best to describe that in the docs. Additionally,
since POV-Ray is also used for animations,
it might be a consideration to add another two
floats. I've noticed that initial_frame also only
returns the number from Subset-Framing. So
perhaps it might be a good idea to add some
constant-floats which will return the actual
KFI and KFF values...
Tim Nikias v2.0
> > //+KFI1 +KFF3 +EF2
with
>     Thorsten
> Thorsten Froehlich
Date: 5 Apr 2003 12:20:04
Message: <web.3e8f0fd5b5b20e9e8ae0d1080@news.povray.org>
Tim Nikias v2.0 wrote:
> Additionally,
IIRC those values can be calculated using values of clock related
identifiers. In particular using frame_number + clock +
initial_clock/final_clock + clock_delta.
ABX
Date: 5 Apr 2003 19:40:42
Message: <3e8f778a@news.povray.org>
Hm, you're right, this should be possible. I'll
see if it'll work.
Nontheless, I do think that either initial_frame and
final_frame should return the actual values of
KFI and KFF respectively, or two new constant
float-identifiers should be introduced. To me they
seem to be essential for creating animation-includes.
Anyways, at least the Docs should be changed then.
Do I have to make a note in some other newsgroup
for that, I'm not sure sure...
Tim Nikias v2.0
> > Additionally,
> ABX
Date: 9 Apr 2003 02:33:25
Message: <p8f79vkntvlk3lnmh4af1a2l8146gtp8od@4ax.com>
On Sun, 6 Apr 2003 02:37:03 +0200, "Tim Nikias v2.0" <tim### [at] gmxde> wrote:
> two new constant
Isn't that you who said "I'm the kind of guy who wants to script his
own stuff"? It can be made via script, and with this thread it is already
documented for future references. Do not forget to post the code for less
experienced users.
ABX
Date: 9 Apr 2003 05:13:59
Message: <3e93e457$1@news.povray.org>
:-) Okay okay. I'll post some code shortly.
Tim Nikias v2.0
> > two new constant
> experienced users.
> ABX
Date: 9 Apr 2003 08:06:11
Message: <3e940cb3$1@news.povray.org>
Here's the code. It'll return the amount of frames of the
animation and set a variable if or if not the animation is cyclic.
#if ((final_frame-initial_frame)*clock_delta>=(final_clock-initial_clock))
 #declare Total_Frames=1/clock_delta+1;
 #declare Cyclic_Animation=off;
#else
 #declare Total_Frames=1/clock_delta;
 #declare Cyclic_Animation=on;
Tim
Tim Nikias v2.0
> Tim Nikias v2.0
> > > two new constant
already
less
> > experienced users.
> > ABX
Date: 9 Apr 2003 08:12:58
Message: <kd389vgut0n0i9m7tmohvtros8qor5n808@4ax.com>
On Wed, 9 Apr 2003 13:57:14 +0200, "Tim Nikias v2.0" <tim### [at] gmxde> wrote:
> #else
> #end
Are you sure ?
This seems only valid when ( final_clock - initial_clock ) = 1
ABX
