POV-Ray : Newsgroups : povray.general : Meaning of rgbft? Server Time
21 Apr 2026 22:26:10 EDT (-0400)
  Meaning of rgbft? (Message 1 to 10 of 12)
Subject: Meaning of rgbft?
Date: 14 Feb 2003 09:30:10
Message: <3e4cfd71@news.povray.org>
I can imagine what it means if there is only filter and only transparency
defined at some point of the surface -- but what is the meaning if both
are?
That is given
P: a point on a surface
f: filter value at P
t: transparency at P
l: colour that would be the result from enlighting the point if t were zero
o: colour that is "coming from the other side of the surface", e.g. would be
the result if t=1 and f=0
what is the formula function(f,t,l,o) for calculating the resulting colour
in P? Anybody?
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Subject: Re: Meaning of rgbft?
Date: 14 Feb 2003 11:44:23
Message: <3e4d1ce7@news.povray.org>
Micha Riser wrote:
> That is given
> zero
> would be the result if t=1 and f=0
I forgot one variable
p: rgb colour of pigment at point P
for f=0 I would suggest (quite sure about this):
 resultingcolour = (1-t)*l + t*o
and for t=1 my guess is something like
 resultingcolour = f*(p*o) + (1-f)*o
where '*' is the componentwise multiplication
Date: 14 Feb 2003 12:15:29
Message: <3e4d2430@news.povray.org>
Micha Riser <mri### [at] gmxnet> wrote:
> but what is the meaning if both are?
  This is what I have wondered as well.
  They are both very useful separately since they give different
transparency used for different purposes. However, using them both
at the same time gives results which usually don't produce anything
nice. Well, perhaps with low values for one of them or both could
give some useful effect.
  Probably it was easier to allow them to be used at the same time than
explicitly disallowing it. Or something. I don't know. :)
Date: 14 Feb 2003 12:29:11
Message: <3e4d2767$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e4d2430@news.povray.org...
<snip>
seems to be a common trend at the moment - I fell asleep last night pondering on
this (ykybrtlw). I wasn't helped by what seemed a rather ambiguous statement in
the docs concerning filter (6.1.5):
"The color of the object is subtracted from the light passing through so this is
called subtractive transparency."
Does this sound right? It sounds as though rgbf<1,0,0,1> would subtract the red,
but allow the green and blue through, which, afaik, is not the case (or have I
just gone mad?).
Date: 14 Feb 2003 12:37:56
Message: <3e4d2974@news.povray.org>
one way I could think of filter is that it is like a thinn, strong layer of
scattering media behind the surface.. but I have no idea if the POV
developper had this in mind or this is consitient with POV (probably not)
following the media approach I came to following:
The scattering part would be (approx.): f*(o*p)*dl
(where dl is something like the length of the media.)
The part of light shining through the media layer:
 exp(-f*p*dl) * o
which can be approximated using exp(x) = 1+x to:
 (1-f*p*dl)*o
setting dl to 1 and summing up gives:
 f*(o*p) + (1-f*p)*o
Now this shines only through as much as the transparency of the surface is,
so the whole is multiplied by t. Including the "normal" lighting this
gives:
 (1-t)*l + t*o*( f*p + (1-f*p) )
Any comments?
- Micha
Date: 14 Feb 2003 12:41:51
Message: <3e4d2a5f@news.povray.org>
Oops, this simplifies to 1
:o
Date: 14 Feb 2003 12:49:39
Message: <3e4d2c33@news.povray.org>
> of scattering media behind the surface.. but I have no idea if the POV
I revise my model. NOT scattering but absorbing media only. So cancle out
the scattering amouth gives:
>  exp(-f*p*dl) * o
>  (1-f*p*dl)*o
setting dl to 1:
  f*(o*p) + (1-f*p)*o
> is, so the whole is multiplied by t. Including the "normal" lighting this
> gives:
  (1-t)*l + t*o*(1-f*p)
Hope this makes more sense now.
> Any comments?
- Micha
Date: 14 Feb 2003 13:28:59
Message: <3e4d356b$1@news.povray.org>
I believe that it's this:
color seen =
l*(1-t)*(1-f) // color of the surface minus transmittence and filter amounts
 + o*t // transmitted light
 + f*o*l // filtered light
This is only based off of observation and thought, not from the source code
or anything. If it's correct, then f + t should never be > 1 if you want to
be physically realistic.
 - Slime
[ http://www.slimeland.com/ ]
Date: 14 Feb 2003 14:01:15
Message: <3e4d3cfb@news.povray.org>
Among other things, Slime wrote:
> color seen =
> amounts
Is the filtering factor affected by external lighting? I mean, is the
filtered ligt f*l*o or f*p*o? (where p is the rgb colour of the surface and
l is the colour altered by any lighting/shadowing there might be).
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
Date: 14 Feb 2003 14:27:03
Message: <3e4d4307$1@news.povray.org>
and
Oh, it's probably f*p*o. Yeah, because a sphere with rgbf <1,0,0,1> against
a white background has no shading.
 - Slime
