POV-Ray : Newsgroups : povray.general : transparency and media Server Time
23 May 2026 16:04:24 EDT (-0400)
  transparency and media (Message 1 to 10 of 13)
Subject: transparency and media
Date: 16 Dec 2002 12:30:13
Message: <3dfe0da5@news.povray.org>
Please don't shoot me if this is old news but ...
I've importrd an XFrog tree into Pov using mesh2. The leaves consist of a
square with an image of several leaves on it. Using image_pattern or
pigment_pattern or a tga with use alpha the non leaf part is made
transparent and the leaf section shows up nicely.
But if there is media behind the leaf (a sky in this case) the transparent
area displays the colour of the sky_sphere behind the media and ignores the
media colour completley so the squares show up.
This happens with image_pattern, pigment_pattern and tga with use alpha.
Is this a known bug? is there a fix?
Mick
Subject: Re: transparency and media
Date: 16 Dec 2002 12:50:51
Message: <chrishuff-C6C7A3.12472516122002@netplex.aussie.org>
In article <3dfe0da5@news.povray.org>,
It is not a bug. After the ray passes through the leaf, it is considered
"in" the leaf. The leaf isn't hollow, so it excludes media. The best
solution is to just make it hollow.
http://tag.povray.org/
Date: 16 Dec 2002 13:08:21
Message: <3dfe1695@news.povray.org>
Thanks I didn't think of that
Mick
Date: 17 Dec 2002 14:06:23
Message: <3dff75af@news.povray.org>
news: 3dfe1695@news.povray.org...
Note that there are cases where I was never able to get rid of this problem,
in spite of putting "hollow" keywords everywhere, making sure that
everything was really transparent etc. I ended up rendering the leaves
separately and using a mask to put them on the final image !
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 17 Dec 2002 14:40:02
Message: <chrishuff-446BA7.14353217122002@netplex.aussie.org>
In article <3dff75af@news.povray.org>,
Probably because the transparent surface was causing POV to sample two
shorter intervals instead of one long one. Raising the number of samples
might have reduced or eliminated the artifact, at the cost of slower
rendering.
Date: 17 Dec 2002 15:20:03
Message: <web.3dff7ff48a77e58da7778c0e0@news.povray.org>
Gilles Tran wrote:
>news: 3dfe1695[at]news.povray.org...
A similar question:
I wanted to use a hollow transparent sphere to give some curvature
to my leaf image map, and it works great except when the transparent
part of the leaf's sphere intersects a (non-transparent) surface
behind it. I get black pixels, like it's showing coincident surfaces,
though the sphere's surface is transparent at that point.
I was thinking that I could use the image to clip the sphere somehow
(instead of a another sphere as I'm currently doing), but I wonder
if there is a simpler (and faster rendering) solution?
Date: 17 Dec 2002 17:56:20
Message: <chrishuff-821356.17512917122002@netplex.aussie.org>
In article <web.3dff7ff48a77e58da7778c0e0@news.povray.org>,
If it is coincident with or intersects the surface, sometimes it will
get hit first and the transmitted ray will miss the other surface, so
you see the interior of the second object through the transparent one.
Since the interior is in shadow, it is dark.
The only way to avoid this in the intersecting surface case would be to
change the way POV handles non-refracting transparency.
Date: 17 Dec 2002 21:01:56
Message: <3DFFD7A5.8ADFF16E@pacbell.net>
Or he may need to increase the max_trace_level in the global settings block
a bit.
Ken Tyler
Date: 19 Dec 2002 09:50:03
Message: <web.3e01dc718a77e58d123e4a6e0@news.povray.org>
>a bit.
My first suspect was max_trace_level, but increasing it didn't help. Looks
like I'll have to keep my objects away from the wall or not use transparency
and mask off the non-leaf parts.
Since the wall is an isosurface, perhaps increasing the accuracy would help,
or (if it's an option) maybe making the wall shadowless.
Thanks Christopher and Ken for your help.
Date: 19 Dec 2002 10:17:33
Message: <3E01E30C.E4CEFBFA@my-deja.com>
> >a bit.
How do you create an alpha channel?  Can POV do it?  Or do you need to
use a picture editor?
Thanks.
Tom A.
"Archie!  You are headstrong.  I am imperious.  It's a miracle
we get along as well as we do." - Nero Wolf
Deja mail is gone.  Look for me at raugost at yahoo . com
