POV-Ray : Newsgroups : povray.general : Meshes and RAM. Server Time
6 Oct 2024 09:23:54 EDT (-0400)
  Meshes and RAM. (Message 1 to 10 of 13)
Subject: Meshes and RAM.
Date: 25 Sep 2002 12:52:03
Message: <3d91e9b3@news.povray.org>
I have about 350 megs of RAM. How many triangle faces will I likely be able
to use in a scene?
 -Shay
Megabyte byte byte megabyte one more.
One more megabyte memory.
One more mega megabyte for me.
Subject: Re: Meshes and RAM.
Date: 25 Sep 2002 14:40:38
Message: <chrishuff-4C1535.14380525092002@netplex.aussie.org>
In article <3d91e9b3@news.povray.org>, "Shay" <sah### [at] simcopartscom>
> to use in a scene?
As many as you can.
It depends on the meshes. Using two copies of a mesh, you can double it
with only a very small increase in memory use. Also, if multiple
triangles share a vertex, only one vertex is stored, so meshes with
different geometries but the same number of triangles can take up
different amounts of space. And then there is overhead, OS, other
programs, virtual memory, etc...
http://tag.povray.org/
Date: 25 Sep 2002 14:45:06
Message: <3d920432$1@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> As many as you can.
Could you even give a ballpark guess? I'm at the point in a scene where I
have to make some decisions based on what my computer's capabilities are. Do
you think I could handle 1 million vertices? Maybe if I purchased a little
more RAM?
 -Shay
Date: 25 Sep 2002 15:07:22
Message: <3d92096a@news.povray.org>
> to use in a scene?
  It depends a lot in the mesh.
  If all the triangles are separate (ie. they don't share vertex points with
any other triangle), then they will take more memory than if each triangle
shares each of its vertices with lots of other triangles.
Date: 25 Sep 2002 15:44:28
Message: <3d92121c$1@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3d92096a@news.povray.org...
with
I guess I should have asked how many vertices I might be able to use. Most
of my triangles share each vertex with 5 other triangles.
 -Shay
Date: 25 Sep 2002 15:54:15
Message: <3D921470.F20996FD@luxlab.com>
A mesh with 500 000 vertices and 1 000 000 triangles uses 200 MB of RAM.
_____________
Kari Kivisalo
Date: 25 Sep 2002 16:17:18
Message: <3d9219ce@news.povray.org>
Kari Kivisalo <pro### [at] luxlabcom> wrote in message
news:3D921470.F20996FD@luxlab.com...
OUCH!! Time to do some shopping and some re-thinking for my project. Thank
you for the data.
 -Shay
Date: 25 Sep 2002 16:31:23
Message: <Xns9294E4E76432Draf256com@204.213.191.226>
"Shay" <sah### [at] simcopartscom> wrote in news:3d9219ce@news.povray.org
>> RAM.
> Thank you for the data.
BUT the power of POV-RAY is to use shapes to describe many 'triangles'
i.e. nice sphere can use 256x256 = 65536 triangles in triangles-based-
renderer
whiel in POV it is 1 shape  < 1 kB
Date: 25 Sep 2002 16:56:10
Message: <LQEJ5AAGHik9EwsS@econym.demon.co.uk>
>to use in a scene?
I've got 376Mb of RAM, and the highest number of faces that I've managed
to use in a scene at once without the memory starting to swap is
481,868,158.
Some of the mesh2 objects that appear in the scene occur more than once.
One of them occurs 14,030 times. The actual number of distinct triangle
faces in the source code is only 73,376.
The resulting image is at
<http://www.econym.demon.co.uk/pictures/thecorporation.jpg>
Peak memory used: 211,619,975 bytes
Mike Williams
Gentleman of Leisure
Date: 25 Sep 2002 18:14:10
Message: <3d923532$1@news.povray.org>
> 481,868,158.
yeah, but how many FACES? ;)
-tgq
