POV-Ray : Newsgroups : povray.general : Label on a Jar Server Time
23 Mar 2026 04:10:16 EDT (-0400)
  Label on a Jar (Message 1 to 8 of 8)
Subject: Label on a Jar
Date: 2 Sep 2002 17:25:00
Message: <3d73d72c$1@news.povray.org>
I'm adding an image map to a glass cylinder as a label on a jar.  The label
however does not wrap around the entire jar.  It's very small.  If I use
cylindrical mapping, it warps the small label around the entire jar, and I'm
not sure how to unwarp it back to proper size.  If I use planar mapping, I
get a label on both sides of the jar, since the planer extends in the z
direction infinitely.
What are my options here?  Am I missing something?
Andrew Wilcox
Subject: Re: Label on a Jar
Date: 2 Sep 2002 18:06:15
Message: <3d73e0d6@news.povray.org>
Try something like this:
  pigment
  { image_map { jpeg "label.jpg" once interpolate 2 }
    scale <.2,1,1>
    warp { cylindrical }
Date: 2 Sep 2002 18:12:21
Message: <3D73E22B.9030603@ibras.dk>
Make the label as a separate object, eg as a difference of two cylinders
intersected with a box, and put that on the jar.
/Ib
Date: 2 Sep 2002 18:35:48
Message: <Xns927DBC99CACCMIKAJustMeInc@204.213.191.226>
"Andrew Wilcox" <pov### [at] unpuzzledcom> wrote in
news:3d73d72c$1@news.povray.org:
> label however does not wrap around the entire jar.  It's very small.
> If I use cylindrical mapping, it warps the small label around the
> entire jar, and I'm not sure how to unwarp it back to proper size.  If
> I use planar mapping, I get a label on both sides of the jar, since
> the planer extends in the z direction infinitely.
> Andrew Wilcox
Just imagine that your jar label is part of a bigger transparent label.
when designing your jar label, design it on a larger image of which is
completely filled with the color (lets say index 0 of your bit-mapped
image palette) and use the following in your image_map declaration
(filter 0,1)
Marc
Date: 2 Sep 2002 19:06:12
Message: <3d73eee4@news.povray.org>
  That is probably a lot slower to render than my suggestion.
Date: 2 Sep 2002 19:07:02
Message: <3d73ef15@news.povray.org>
> (filter 0,1)
  Why waste memory needlessly, when you can get the same effect with a
simple scale and cylindrical warp?
Date: 3 Sep 2002 00:27:21
Message: <3d743a29@news.povray.org>
Yes, this worked great.
        image_map {
            png "AlienLabel2.png"
            once
            interpolate 2
         scale <1/(2*pi*jarRad),1/2,1> // My image happens to be half as
tall as wide thus the 1/2
         scale 1/3
          rotate -y*40
Thanks Warp!
news:3d73e0d6@news.povray.org...
>   pigment
>     scale <.2,1,1>
M()}}
Warp -
Date: 5 Sep 2002 16:42:42
Message: <3d77c1c2$1@news.povray.org>
>   pigment
>     scale <.2,1,1>
Hey! Smart... never thought about it... I've always used very large image maps...
Jonathan.
