POV-Ray : Newsgroups : povray.general : blob- No pigment type warning Server Time
4 Mar 2026 08:37:01 EST (-0500)
  blob- No pigment type warning (Message 1 to 10 of 17)
Subject: blob- No pigment type warning
Date: 17 Aug 2002 19:10:42
Message: <3d5ed7f2@news.povray.org>
blob{
    sphere{ -x/2, 1, 1 pigment{ red 1 } }
    sphere{ x/2, 1, 1 pigment{ green 1 } }
Pov 3.5 (and 3.1) complain no pigment type given. Am I missing
something simple? I've only just noticed this while updating an old
3.1 scene but docs 6.5.1.1 seem to say above is legal.
Alf
Subject: Re: blob- No pigment type warning
Date: 17 Aug 2002 20:57:25
Message: <3D5EF0F4.7040804@scifi-fantasy.com>
Alf Peake wrote:
> blob{
A sphere needs X, Y, Z, radius, and colour.  What you
have there is being interpreted as the first four of
those.
Tim Cook
Version: 3.12
Date: 17 Aug 2002 21:59:28
Message: <3d5eff80@news.povray.org>
"Alf Peake" <alf### [at] peake42freeservecouk> wrote in message
news:3d5ed7f2@news.povray.org...
> blob{
The "no pigment type given" message is just a warning.  Though the blob
itself has no pigment, what you have specified is perfectly legal.
Robert Chaffe
http://www.donovansweb.com/~chaffe/
Date: 17 Aug 2002 23:42:24
Message: <3d5f17a0@news.povray.org>
  Wrong. What a spherical blob component needs is: vector, float, float
Date: 17 Aug 2002 23:42:59
Message: <3d5f17c3@news.povray.org>
  It's just a harmless bug. Shouldn't affect rendering in any way.
Date: 18 Aug 2002 00:21:49
Message: <chrishuff-FC0680.23083917082002@netplex.aussie.org>
In article <3D5### [at] scifi-fantasycom>,
 "Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote:
> Alf Peake wrote:
> > blob{
> those.
That is not even close to correct. Spherical blob components take a
vector for the center and a float radius, like the sphere primitive, and
an additional strength float value. You can also specify a texture for
individual components. You do not specify a color, but you can specify
only the pigment of a texture. This is exactly what is specified here.
This warning (not an error) is caused by the fact that the blob shape on
the whole doesn't have a texture defined. This is usually a mistake, so
it produces a warning. The components themselves have textures, so it
will render fine.
http://tag.povray.org/
Date: 18 Aug 2002 04:01:36
Message: <3D5F545F.4050207@scifi-fantasy.com>
>>those.
 > components take a vector for the center and a float
 > radius, like the sphere primitive, and an additional
My statement, as it stands by itelf, is correct; I
misunderstood Alf's code because I'm not familiar
with blobs.  A SPHERE does need the five components
I mentioned.  However, what was being talked about
wasn't spheres, it was sphere COMPONENTS of a blob.
Tim Cook
Version: 3.12
Date: 18 Aug 2002 04:11:16
Message: <3D5F56A3.828D7867@gmx.de>
No, as Chris Huff said, a sphere needs a vector for the center and a float
for the radius.  A warning is issued if no texture is given in either the
sphere itself or in a wrapping CSG structure.
So nothing like 5 components, see also the docs, section 6.5.1.9:
SPHERE:
    sphere
        <Center>, Radius
        [OBJECT_MODIFIERS...]
Date: 18 Aug 2002 05:05:25
Message: <3D5F6355.2090302@scifi-fantasy.com>
> SPHERE:
>     sphere
>         <Center>, Radius
I counted the texture modifier as a single component;
center has 3 components (x, y, and z), then there's the
radius.  that leaves us with 5 components.
Tim Cook
Version: 3.12
Date: 18 Aug 2002 05:11:48
Message: <3D5F64D3.ECA3C521@gmx.de>
> > SPHERE:
> >     sphere
> >         <Center>, Radius
Not a very good idea, 'sphere { 0, 1 }' is perfectly legal and i don't see
any five components.
