POV-Ray : Newsgroups : povray.general : text on a cylinder Server Time
24 May 2026 04:32:39 EDT (-0400)
  text on a cylinder (Message 1 to 10 of 11)
Subject: text on a cylinder
Date: 4 Aug 2002 18:41:16
Message: <3d4dad8c@news.povray.org>
hi all,
I'm sure this must have been raised many times before, but how would I wrap
a text string around a cylinder. To clarify - the front of the letters
should be aligned normal to the cylinders curvature - like the letters on a
beer bottle label.
thanks in advance
jim
Subject: Re: text on a cylinder
Date: 4 Aug 2002 20:11:39
Message: <chrishuff-F8BF9B.19023704082002@netplex.aussie.org>
In article <3d4dad8c@news.povray.org>,
> beer bottle label.
If you want something like printing on a label, use a text object with
the object pattern, and the mapping warps to wrap it around the
cylinder. If you need actual objects for the text, you could get what
you want by modifying the Circle_Text() macro in shapes.inc.
Date: 4 Aug 2002 20:14:23
Message: <Xns9261162AEE1E7raf256com@204.213.191.226>
"James Taylor" <jim### [at] blueyondercouk> wrote in
news:3d4dad8c@news.povray.org
> hi all,
> wrap a text string around a cylinder. To clarify - the front of the
> letters should be aligned normal to the cylinders curvature - like the
> letters on a beer bottle label.
probably best result will give isosurface - using inside() function and
twist/rotate along Y axis.
object pattern/pigment will give totaly flat text, while ISO will give
grooved text
Date: 4 Aug 2002 22:27:32
Message: <chrishuff-E7A894.21182904082002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
Best?!? Slowest and most likely to produce artifacts, if it works at
all...isosurfaces don't like infinite gradients.
> grooved text
Don't know what you mean by "grooved" here. If you mean an engraved
appearance, the object pattern as a normal could work, the normal will
be perturbed at the boundaries of the object pattern. Or you could use
the pattern blurring techniques to get smoother transitions on the
edges, povray.binaries.scene-files has some work on this.
If a texture won't do and a real object is needed, the best thing would
be to construct a union of the individual letters rotated into a
circle...the Circle_Text() macro already does most of this, you just
need to modify it a bit. If you need the outer surfaces to be curved,
just intersect it with a cylinder.
Date: 5 Aug 2002 05:22:17
Message: <3d4e43c9@news.povray.org>
If an isosurface is being used only for the purpose of the inside()
function, it will be very fast and perfectly accurate. Only one function
evaluation is necessary.
 - Slime
[ http://www.slimeland.com/ ]
Date: 5 Aug 2002 07:43:13
Message: <3d4e64d1@news.povray.org>
thanks for the replies but I figured it out...heres my solution:
#macro Text_Cylinder(Text,Radius,Text_Size)
    #local fudge = 0.6;
    #local Length = strlen(Text);
    #local Width = Text_Space(font,Text, 1, 0);
    #local Angle = degrees(Text_Size/Radius*fudge)*Length;
    #local i=1;
    union {
    #while (i<=Length)
        #local temp_letter = substr(Text,i,1)
        text{
            ttf font,temp_letter,1*mm, 0
            scale Text_Size
            translate -Radius*z
            rotate -degrees(Text_Size/Radius*fudge)*y*i
            pigment{Black}
            finish{Glossy}
        #local i=i+1;
    rotate -90*y
    rotate Angle/2*y  //centres text
but why do I need to introduce the "fudge" factor?
thanks
jim
Date: 5 Aug 2002 07:47:34
Message: <Xns92618BB158E36raf256com@204.213.191.226>
Christopher James Huff <chr### [at] maccom> wrote in news:chrishuff-
E7A### [at] netplexaussieorg
for normal text{} - this intersection is almost true, but of course for
more complex objects the result of realy twisting it by ISO, or by
intersection will be totaly different.
Even for text, when looking above :
   *    <- center of cylinder
.     . 1 letter
. '-' . 1 letter + intersection
.     . <- this side line is straight | with is not totaly correct
 .'-'.  1 letter + true twist using ISO
/     \ <- this side wall is alsow turned
I will make POV to ilustrate this in evening
Date: 5 Aug 2002 12:21:58
Message: <chrishuff-5D7495.11114805082002@netplex.aussie.org>
In article <3d4e43c9@news.povray.org>, "Slime" <slm### [at] slimelandcom>
If it is being used only for that purpose, using an isosurface is
completely unnecessary...use the function directly as a pattern. And
since POV 3.5 has the mapping warps, using a function to do the same
thing is just making it unnecessarily difficult. But I think he was
talking about using it as an actual isosurface, since he mentioned an
engraved appearance.
Date: 5 Aug 2002 12:40:38
Message: <chrishuff-5FBCEC.11303205082002@netplex.aussie.org>
What are you talking about? The problem is about wrapping text around a
cylinder, see the subject: "text on a cylinder"
For more complex objects, intersect it with a more complex object...it
would work with cone, lathe or sor objects as well.
As for the straight sides, it is unlikely to be a problem or even to be
visible to someone looking for it if the letters are fairly small in
comparison to the cylinder. And you could use a technique similar to the
bevelled text macro to adjust this and still get a result that is faster
and more artifact-free than an isosurface.
Date: 6 Aug 2002 15:36:23
Message: <3d502536@news.povray.org>
It amazes me that no-one has yet given the best, easiest and most obvious
answer:
  Create an object pattern with the text and then apply a cylindrical warp
to this pattern. That's it.
