POV-Ray : Newsgroups : povray.general : pov source gcc3 problem Server Time
24 May 2026 04:32:25 EDT (-0400)
  pov source gcc3 problem (Message 1 to 10 of 29)
Subject: pov source gcc3 problem
Date: 1 Aug 2002 19:59:28
Message: <3d49cb5f@news.povray.org>
HI all,
well, that's the time where I hate my fucking new system :(sorry:)
But it is as it is. I can't just unzip configur and compile the sources
because of some basic C++ standard issues. such as max and std::max. gcc
has been very loosely to the ANSI/ISO C++ standard in gcc 2.x. Most of
these issues has been fixed now and, what's now? lots of sources (such as
povray) can't be compiled.
That's now good :(
Will the developer fix that? or do we need to walk through the code and add
the namespace prefix (std::) to each standard function? This wouldn't be
nice since I'm pretty sure that I'm not the only one who should do exactly
the same as the others in that case.
Thanks,
Christian Parpart.
Subject: Re: pov source gcc3 problem
Date: 1 Aug 2002 20:40:30
Message: <slrnakjl7j.hmh.steve@zeropps.org.uk>
On Fri, 02 Aug 2002 01:59:28 +0200, Christian Parpart wrote:
> HI all,
No need to be sorry just don't swear it's that simple.
Have a look around in some other groups that you think may contain the
answer to your question, it so happens that your question was answered
some hours ago in povray.unix.
                                             or http://start.at/zero-pps
  1:35am  up 35 days, 11:57,  1 user,  load average: 1.29, 1.24, 1.21
Date: 1 Aug 2002 21:59:54
Message: <3d49e79a@news.povray.org>
Quick fix: Add 'using namespace std;' to config.h
  (Ugly perhaps, but who cares? At least it compiles.)
Date: 2 Aug 2002 08:53:53
Message: <3d4a80e1@news.povray.org>
I have no problem with it, but I do remember you going on about how it isn't
something you should grow accustomed to doing. I'm surprised you're the one
suggesting it. :)
Date: 2 Aug 2002 09:21:50
Message: <3d4a876e@news.povray.org>
Warp inspired the electrons to say:
Exactly. That's what I did. Quick'n'dirty.
And, as we was talking in povray.unix group about too (unfortunately).
Greets,
christian.
Date: 2 Aug 2002 17:25:38
Message: <3D4AF8A0.3050100@lincom-asg.com>
> HI all,
> That's now good :(
> Thanks,
> Christian Parpart.
Christian,
This simple thing works until that issue is fixed.
Put these lines in config.h:
#ifndef max
#define max(a,b) ( a > b ? a : b )
#endif
#ifndef min
#define min(a,b) ( a < b ? a : b )
#endif
This is easier than searching & prefacing all max
and min calls with std:: ,  eh?   ;-)
Bob Jamison
LinCom Corp
Date: 2 Aug 2002 20:34:28
Message: <3d4b2513@news.povray.org>
Bob Jamison <rja### [at] lincom-asgcom> wrote:
> #ifndef max
> #endif
> #ifndef min
> #endif
  How is it easier than writing 'using namespace std;' instead?
  Besides, your solution is very bad. Do you know why?
Date: 2 Aug 2002 21:52:29
Message: <slrnakmdr0.p47.ron.parker@fwi.com>
>> #ifndef max
>> #endif
>> #ifndef min
>> #endif
Oooh!  Oooh!  I know!  I know!
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 2 Aug 2002 22:11:13
Message: <3d4b3bc1@news.povray.org>
  But you are a professional. You can't participate. ;)
Date: 2 Aug 2002 23:02:01
Message: <Xns925F329772CB7raf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3d4b2513@news.povray.org
>> #ifndef max
>> #endif
>> #ifndef min
>> #endif
<rot13>
fbzr rkcerfvbaf jvyy abg or pnyphyngrq ng pbzcvyr-gvzr ?
