POV-Ray : Newsgroups : povray.general : Photons Server Time
14 Jun 2026 19:59:26 EDT (-0400)
  Photons (Message 1 to 8 of 8)
Subject: Photons
Date: 7 Jul 2002 14:25:59
Message: <3d2887b7$1@news.povray.org>
What would cause light sources, located on the opposite side of opaque wall,
to illuminate the near side, as if they are shining through the wall?
I've been getting this since I switched to the beta version of POV, and put
in photons to my project.
One of the light sources.
//Leftmost LED
light_source { <0,0,0> color Red * LED_Brite
                photons { refraction on reflection on area_light }
                spotlight point_at <0,1,0> tightness 10 radius 0.1 falloff
20
                looks_like {Red_LED}     //Otherwise, they aren't visible
                translate<-2.6,0.2,-0.70>  //F-B U-D R-L Put the LEDs under
their pipes
Plastic wall
#include "slp_may10\top_housing.inc"
object {TOP_HOUSING
        photons{target reflection on refraction off collect on}
The view point is above the plastic looking down, the leds are below,
looking up.
I posted a section of the image in povray.binaries.images that shows the
problem.
Subject: Re: Photons
Date: 7 Jul 2002 14:46:33
Message: <chrishuff-621733.13441007072002@netplex.aussie.org>
In article <3d2887b7$1@news.povray.org>,
How thick is this wall? If it is just a shape surface, it is infinitely
thin, and POV might not be able to decide which side of the surface the
photons belong to. If you give the wall some actual thickness, this
might go away.
Date: 7 Jul 2002 17:08:43
Message: <3d28addb$1@news.povray.org>
> might go away.
It's just a surface made of triangles, translated from pro-engineer.
I don't know how I could convert it to have thickness.
I was sort of afraid this might be the case.
I've tried varying the intensity of the LEDs, it gets better with lower
intensities, but never goes away.  I guess I'll have to turn the photons off
on the LEDs, which is a pity.
Date: 7 Jul 2002 19:04:35
Message: <3d28c903@news.povray.org>
Try decreasing the 'radius' of the photons (in global_settings { photons{} })
Date: 8 Jul 2002 08:46:53
Message: <3d2989bd@news.povray.org>
wall,
put
> //Leftmost LED
> 20
under
> their pipes
> Plastic wall
> object {TOP_HOUSING
> looking up.
> problem.
if you don't need the photons to interact with the (whatever you call it),
you can add
photons{collect off}
to the object and it will ignore the photons.
-tgq
Date: 8 Jul 2002 18:31:42
Message: <3d2a12ce@news.povray.org>
news:3d28c903@news.povray.org...
photons{} })
Turning off photons on the LEDs solved it for me, but I've hit another
issue.
I get warning messages like
       "Cannot use pass through with refraction and high density photons".
Not sure how I got to "high density" photons..  I do want refraction and
photons though.
Also, as part of getting through this, I added a "split_union off" to the
final object, which is a union of the printer, table, and a pen. Now I get a
warning that the camera is inside a non-hollow object.
Could it be that I'm inside a bounding box?
Date: 8 Jul 2002 19:37:52
Message: <3d2a2250$1@news.povray.org>
"Dave VanHorn" <dva### [at] cedarnet> wrote...
> photons though.
That should say "cannot use pass through with refraction on a target."  So,
you have to either remove refraction, pass_through, or target.
-Nathan
Date: 9 Jul 2002 16:38:54
Message: <3d2b49de$1@news.povray.org>
"Nathan Kopp" <nat### [at] koppcom> wrote in message
news:3d2a2250$1@news.povray.org...
photons".
> > photons though.
So,
Well that certainly makes more sense.
Now I have to figure out to what it's referring.
