POV-Ray : Newsgroups : povray.general : interior statement. Server Time
29 Dec 2025 11:19:13 EST (-0500)
  interior statement. (Message 1 to 10 of 22)
Subject: interior statement.
Date: 5 Jul 2002 10:59:18
Message: <3d25b446$1@news.povray.org>
I keep getting warnings that IOR should be specified in interior statements,
but I have yet to see an example of how to do that, and I keep guessing
wrong.
Any pointers?
Subject: Re: interior statement.
Date: 5 Jul 2002 11:04:42
Message: <3D25B58A.71C425C7@gmx.de>
> wrong.
> Any pointers?
http://www.povray.org/working-docs/id000179.html
Last updated 30 Jun. 2002 _____./\/^>_*_<^\/\.______
Date: 5 Jul 2002 11:20:14
Message: <3d25b92e@news.povray.org>
news:3D25B58A.71C425C7@gmx.de...
statements,
> > wrong.
> > Any pointers?
Thanks.
I didn't see that in the release version docs.
So I took that out of the finish statements, and put it in the object
statements, as shown.
It still seems like a "finish" element to me..
In the old system, I define a part, then I apply a finish that says what
sort of material it is, and wether or not it has any transparency.
Now, I have to define everything about transparency EXCEPT refraction in the
finish, and put the refraction in on the object itself.   Very messy for
making objects transparent in one render, and not in the next.
Date: 5 Jul 2002 11:26:35
Message: <3d25baab$1@news.povray.org>
"Dave VanHorn" <dva### [at] cedarnet> wrote in message
news:3d25b92e@news.povray.org...
the
Well, it makes sense to me, as the IOR of a substance in reality is more
related to the INTERIOR of an object than just it's surface. Also, if IOR
was the only thing that could be defined in the interior {} block, then I'd
probably agree with you (that it should go in finish{}, but there's MEDIA
also, so an interior {} block makes sense.
All the best,
Andy Cocker
Date: 5 Jul 2002 11:34:31
Message: <3D25BC87.231199@gmx.de>
Dave VanHorn wrote:
> Thanks.
This part has not changed from 3.1.  Look for 'Refraction' in the 3.1 docs
and you will find the same text.
The reason is explained in 'Why are Interior and Media Necessary?' just a
few pages before the mentioned chapter:
http://www.povray.org/working-docs/id000176.html
Date: 5 Jul 2002 11:38:54
Message: <6tebiug2i6g18dlgc45p67hmd8a2dualvp@4ax.com>
On Fri, 5 Jul 2002 10:20:21 -0500, "Dave VanHorn" <dva### [at] cedarnet> wrote:
> sort of material it is...
The ior is element of interior{} and interior{} is part of material{}. Just
material{} statement is optional wrapper (also usefull with declarations).
> finish
Are you defining transparency in finish statement ????
You are puting ior as part of interior, not as part of object, for example you
can declare one interior and use it in various materials.
> Very messy for making objects transparent in one render, and not in the next.
I really don't understand how it is connected with rendering of animation.
ABX
Date: 5 Jul 2002 12:00:57
Message: <3d25c2b8@news.povray.org>
  How do you say in a finish block that the surface is transparent?
I have always thought that it is said in the pigment block.
  And IOR is not a property of the surface of the object, but its interior.
Finish defines properties of the surface of the object.
Date: 5 Jul 2002 12:03:41
Message: <3d25c35d@news.povray.org>
Could be because it has nothing to do with animation..
Date: 5 Jul 2002 12:08:51
Message: <3d25c493$1@news.povray.org>
"Andrew Cocker" <mai### [at] mariner9net> wrote in message
news:3d25baab$1@news.povray.org...
> the
I see that.
I'm thinking in terms of defining a part, then specifying what sort of
material it's to be shot in.
So I have textures like:
#declare ABS_Tex =   normal { bumps 0.160 scale 0.002 } //Depth, Diameter
#declare Gloss_Tex = normal { bumps 0.080 scale 0.500 } //Even gloss has
some bumpiness
#declare ABS_Gloss_Finish = finish  { ambient 0.2
                                      diffuse 0.30
                                      brilliance 1 //0.6767
                                      phong 0.68
                                      phong_size 80
                                      specular 0.2
                                      roughness 0.135
                                      reflection 0.2
// Normal bumps disturb the surfaces, and create the effect of
// bumpy surfaces, without the mathmatical complexity of actually modelling
// the surfaces as collections of packed spheres, or anything else.
some bumpiness
// Finishes are the surface details like reflectance, shine, etc.
                                      diffuse 0.30
                                      phong 0.68
                                      phong_size 80
                                      specular 0.2
                                      roughness 0.135
                                      reflection 0.2
#declare ABS_Finish = finish  { ambient 0.2
                                diffuse 0.30
                                brilliance 0.6767
                                phong 0.68
                                phong_size 80
                                specular 0.1
                                roughness 0.001 //135
                                reflection 0.1
#declare Lexan_Finish = finish  { ambient 0.15
                                  diffuse 0.250
                                  brilliance 0.8 //6767
                                  phong 0.68
                                  phong_size 80
                                  specular 0.05
                                  roughness 0.135
                                  reflection 0.05
                                  //ior 1.58
#declare Crystal_Clear_Gloss_Lexan = texture { pigment { color rgbf <0.95,
0.95, 0.95, 1>}
                                    normal { Gloss_Tex }
                                         finish  { Lexan_Finish }
As opposed to this, for a non-transparent plastic.
#declare Light_Blue_Gloss_ABS = texture { pigment { color rgb <0.7, 0.7, 1>
* .5}
                                     finish  { ABS_Gloss_Finish }
Date: 5 Jul 2002 12:09:53
Message: <f0hbiugrvsm559jlam1dvb87k208snipsa@4ax.com>
On Fri, 5 Jul 2002 11:03:48 -0500, "Dave VanHorn" <dva### [at] cedarnet> wrote:
Then it is even more strange how placement of ior makes difficoulties for you
to control transparency over different renders :-)
ABX
