POV-Ray : Newsgroups : povray.general : Media interaction with Spotlights Server Time
24 May 2026 10:03:35 EDT (-0400)
  Media interaction with Spotlights (Message 1 to 10 of 14)
Subject: Media interaction with Spotlights
Date: 17 May 2002 17:55:02
Message: <3ce57c36@news.povray.org>
Hello All,
  Me again of course..
  I'm doign some testing with Media interaction.. so I made a line of
Spotlights, using a while statment.
  Inside the light_source  I have media_attenuation turned on
  Outside the block, I have atmospheric media create (I think).
    media {
        method 3
        scattering { 1, color rgb .02 }
    When I render the scene, the only change I see is that it renders
slower.. I don't see what I expected, which would be a cone of light from
the spotlight..
Anyone got any suggestions??
Thanks
Dave
Subject: Re: Media interaction with Spotlights
Date: 17 May 2002 20:37:46
Message: <3CE5A23B.85DE1A32@gmx.de>
I've run into that one some weeks ago.
Its about the intervals and samples and such. In an
infinite section, how do you calculate intervals?
This is somehow the reason why only spotlight don't
work, try a fading light... The algorithm of method 3 is,
as far as I know, an adaptive one. But it can only adapt
to things "it" sees. If it cannot spot them (intervals in infinity...),
it cannot adapt properly.
And thus POV probably thinks that the spotlights don't
add too much...
But that's just my interpretation of things, and I'm, no expert
on that. Someone just told me that infinite-space and method 3
don't work very well together on certain occasions.
Dave Bates wrote:
> Hello All,
>     media {
>         method 3
> the spotlight..
> Thanks
> Dave
Tim Nikias
Email: Tim### [at] gmxde
Date: 17 May 2002 21:09:00
Message: <3ce5a9ac$1@news.povray.org>
Think I should try a different method?
I heard 3 was the best, but I Can try 1 .. See what that does..
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3CE5A23B.85DE1A32@gmx.de...
> add too much...
Date: 17 May 2002 21:15:54
Message: <3ce5ab4a@news.povray.org>
Well no.. I tried to take out the samles and interaction, with and without,
method 1-3 everything seems the same.. these spots are Projecting on a Box..
It's long, but it's not infinate.. .. Any more suggestions Tim..
> add too much...
> Dave Bates wrote:
> > Hello All,
> >     media {
> >         method 3
from
> > the spotlight..
> > Thanks
> > Dave
> Tim Nikias
> Homepage: http://www.digitaltwilight.de/no_lights/index.html
Date: 17 May 2002 21:51:55
Message: <3ce5b3bb$1@news.povray.org>
I suggest you post the relevant parts of your source code: camera, light(s),
and all the media (and their container objects) that are having problems.
 - Slime
[ http://www.slimeland.com/ ]
Date: 17 May 2002 22:06:01
Message: <3ce5b709@news.povray.org>
Sure here you:
media {
//    method 3
//    intervals 1
    samples 5
    method 1
    location <-4, 3, -5>
    look_at .5
And here are the lights:
#declare spot_space=3.1;
#declare max_run=125;
#declare l_rad = 8;
#declare l_x = .25;
#declare l_z = -6;
#while (l_z < max_run)
    light_source {
        <l_x, 5, l_z>
        rgb <1,1,1>
        spotlight
        point_at <l_x, 0, l_z>
        radius l_rad
        falloff l_rad*2
        tightness 25
        media_attenuation on
    #declare l_z = l_z + spot_space;
This is projected to a BOX..
The spots all work fine, just the MEdia I'm having problems with.
"Slime" <slm### [at] slimelandcom> wrote in message
news:3ce5b3bb$1@news.povray.org...
light(s),
>  - Slime
Date: 18 May 2002 02:13:12
Message: <3ce5f0f8$1@news.povray.org>
Hi Norman--- er, Dave.
I don't see anything wrong here, using 3.5.beta.RC4.
Media method 3 is smooth with just your original scene script. Only thing
is, I needed to multiply your camera location by 3 in order to see a light
"cone" because of how close it is.
bob h
Date: 18 May 2002 06:22:04
Message: <3CE62B2C.8673A42C@gmx.de>
I traced your scene and played a little with it.
One thing I noticed is that you have to take
into account that scattering media also darkens
the image as too much dust may "eat" the light.
Another one: Looks at beta-test, there's
a post on the 6. May from with title
"Media broken?", in which I ran into
that same problem.
I am not really sure, what the nature of this
effect is. Its all about sampling, intervals,
scatterings affection on the colors ect, so
it might just be look if you hit the correct
combination.
Peter Popov told me there to look at "ratio",
which places more samples in lit areas than
in unlit ones. Altogether I think this subject
could be made more clear by someone
who actually wrote the code and has some
specific insight. I didn't fully understand
why spotlights are not infinite and may be
traced in infinite media better than pointlights
in infinite media etc.
"Dave Bates [{Norman}]" wrote:
> Sure here you:
> media {
> //    method 3
> //    intervals 1
>     samples 5
>     method 1
> camera {
>     look_at .5
> #declare l_rad = 8;
> #declare l_x = .25;
> #declare l_z = -6;
>     light_source {
>         <l_x, 5, l_z>
>         rgb <1,1,1>
>         spotlight
>         radius l_rad
>         falloff l_rad*2
>         tightness 25
> #end
> light(s),
> >  - Slime
Tim Nikias
Date: 18 May 2002 10:55:43
Message: <3ce66b6f$1@news.povray.org>
Bob,
    Okay here is my question.. I've played aroudn with this a bit.. I added
a "Container" box and see the Cone faintly.. but Is there a way to make it
more intense without raising the intesity of the light?
"bob h" <omn### [at] charternet> wrote in message
news:3ce5f0f8$1@news.povray.org...
> bob h
Date: 18 May 2002 11:43:41
Message: <3ce676ad@news.povray.org>
added
Scattering media is hard to manipulate well. You should either increase or
decrease the color of the scattering (which is currently .02 i believe).
Increasing it may help because there will be more media for the light to
reflect off of, so it will be brighter. But decreasing may help because
there will be less unlit media blocking the light that *is* reflecting.
If you are only interested in seeing the media where the fog is, you may
want to ditch the scattering media and replace it with emission media in a
cone shape that matches the spotlight.
 - Slime
